Isaac Sim 2020.1 (Unity 3D) - Unable to open sample project
Hi, I’m having problems opening the sample project with Unity Editor. My current unity editor version is 2019.3.15f1 and Isaac Sim version is 2020.1.
When I run the following command,
Unity/Hub/Editor/2019.3.15f1/Editor/Unity -projectPath isaac_sim_unity3d/projects/sample -logfile
I get an error
CreateDirectory '' failed:  (current dir: )
in terminal. A popup window which states “Opening Project in Non-Matching Editor Installation” appears, and I click continue. However, the project does not open and is stuck at the starting unity splash screen.
Trying the same steps with the terminal command
Unity/Hub/Editor/2019.3.15f1/Editor/Unity -projectPath isaac_sim_unity3d/projects/sample -logfile /dev/stdout
displays the following in terminal.
[LicensingClient] ERROR Failed to connect to local IPC
[Licensing::Module] Failed to connect to channel: LicenseClient-samfang
[Licensing::Module] Successfully launched the LicensingClient
[Licensing::Module] Successfully connected to LicensingClient on channel: LicenseClient-samfang
[SignatureVerifier] Application signature verification not supported on this platform.
[Licensing::Module] Successfully launched and connected to LicensingClient
Entitlement-based licensing initiated
[LicensingClient] Licenses Updated successfully in LicensingClient
Desktop is 1920 x 1080 @ 60 Hz
[Licensing::Module] Serial number assigned to: "F4-GUVR-9JEQ-T8PG-TVES-XXXX"\n[Package Manager] Server::Start -- Port 56874 was selected
 COMMAND LINE ARGUMENTS:
-projectPath
-logfile
/dev/stdout
Successfully changed project path to: /home/samfang/isaac_sim_unity3d/projects/sample
Using Asset Import Pipeline V2.
Gtk-Message: 19:16:45.892: GtkDialog mapped without a transient parent. This is discouraged.
Adding genesis user token Adding genesis user token [Package Manager] Done resolving packages in 1.65s seconds
[Package Manager] Done checking package constraints in 0.00s seconds
(Unity:10781): Gtk-CRITICAL **: 19:16:48.524: gtk_container_foreach: assertion 'GTK_IS_CONTAINER (container)' failed
[Package Manager]
Registered 57 packages:
  Packages from [https://packages.unity.com]:
    com.unity.ads@3.4.5 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.ads@3.4.5)
    com.unity.analytics@3.3.5 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.analytics@3.3.5)
    com.unity.collab-proxy@1.2.16 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.collab-proxy@1.2.16)
    com.unity.ide.rider@1.1.4 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.ide.rider@1.1.4)
    com.unity.ide.vscode@1.2.0 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.ide.vscode@1.2.0)
    com.unity.multiplayer-hlapi@1.0.4 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.multiplayer-hlapi@1.0.4)
    com.unity.postprocessing@2.3.0 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.postprocessing@2.3.0)
    com.unity.purchasing@2.0.6 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.purchasing@2.0.6)
    com.unity.test-framework@1.1.14 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.test-framework@1.1.14)
    com.unity.textmeshpro@2.0.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.textmeshpro@2.0.1)
    com.unity.timeline@1.2.10 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.timeline@1.2.10)
    com.unity.xr.legacyinputhelpers@2.1.4 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.xr.legacyinputhelpers@2.1.4)
    com.unity.render-pipelines.high-definition@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.render-pipelines.high-definition@7.3.1)
    com.unity.render-pipelines.universal@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.render-pipelines.universal@7.3.1)
    nuget.mono-cecil@0.1.5-preview (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/nuget.mono-cecil@0.1.5-preview)
    com.unity.ext.nunit@1.0.0 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.ext.nunit@1.0.0)
    com.unity.render-pipelines.core@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.render-pipelines.core@7.3.1)
    com.unity.shadergraph@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.shadergraph@7.3.1)
    com.unity.visualeffectgraph@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.visualeffectgraph@7.3.1)
    com.unity.render-pipelines.high-definition-config@7.3.1 (location: /home/samfang/isaac_sim_unity3d/projects/sample/Library/PackageCache/com.unity.render-pipelines.high-definition-config@7.3.1)
  Built-in packages:
    com.unity.2d.sprite@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.2d.sprite)
    com.unity.2d.tilemap@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.2d.tilemap)
    com.unity.ugui@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.ugui)
    com.unity.modules.ai@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.ai)
    com.unity.modules.androidjni@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.androidjni)
    com.unity.modules.animation@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.animation)
    com.unity.modules.assetbundle@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.assetbundle)
    com.unity.modules.audio@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.audio)
    com.unity.modules.cloth@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.cloth)
    com.unity.modules.director@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.director)
    com.unity.modules.imageconversion@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.imageconversion)
    com.unity.modules.imgui@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.imgui)
    com.unity.modules.jsonserialize@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.jsonserialize)
    com.unity.modules.particlesystem@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.particlesystem)
    com.unity.modules.physics@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.physics)
    com.unity.modules.physics2d@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.physics2d)
    com.unity.modules.screencapture@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.screencapture)
    com.unity.modules.terrain@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.terrain)
    com.unity.modules.terrainphysics@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.terrainphysics)
    com.unity.modules.tilemap@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.tilemap)
    com.unity.modules.ui@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.ui)
    com.unity.modules.uielements@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.uielements)
    com.unity.modules.umbra@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.umbra)
    com.unity.modules.unityanalytics@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unityanalytics)
    com.unity.modules.unitywebrequest@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unitywebrequest)
    com.unity.modules.unitywebrequestassetbundle@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unitywebrequestassetbundle)
    com.unity.modules.unitywebrequestaudio@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unitywebrequestaudio)
    com.unity.modules.unitywebrequesttexture@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unitywebrequesttexture)
    com.unity.modules.unitywebrequestwww@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.unitywebrequestwww)
    com.unity.modules.vehicles@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.vehicles)
    com.unity.modules.video@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.video)
    com.unity.modules.vr@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.vr)
    com.unity.modules.wind@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.wind)
    com.unity.modules.xr@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.xr)
    com.unity.modules.subsystems@1.0.0 (location: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/PackageManager/BuiltInPackages/com.unity.modules.subsystems)
  Local packages:
    com.nvidia.isaac_sim_core@file:/home/samfang/isaac_sim_unity3d/packages/Nvidia/Core (location: /home/samfang/isaac_sim_unity3d/packages/Nvidia/Core)
    com.nvidia.isaac_sim_samples@file:/home/samfang/isaac_sim_unity3d/packages/Nvidia/Samples (location: /home/samfang/isaac_sim_unity3d/packages/Nvidia/Samples)
[Subsystems] No new subsystems found in resolved package list.
[Package Manager] Done registering packages in 0.00s seconds
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/cellular_concrete.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
(Filename: ./Modules/SubstanceEditor/SubstanceImporter.cpp Line: 37)
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/limestone_azul_valverde.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/ceramic_tiles_brazilian.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/concrete_raw_smooth.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/limestone_brava_mix.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/basalt_brick_wall.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/concrete_raw_soft.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/ceramic_tiles_copper.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/paint_satin.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Packages/com.nvidia.isaac_sim_samples/ThirdParty/SubstanceSource/ceramic_tiles_dark_grey.sbsar: Built-in support for Substance Designer materials has been removed from Unity. To continue using Substance Designer materials, you will need to install Allegorithmic's external importer from the Asset Store.
Refreshing native plugins compatible for Editor in 56.98 ms, found 0 plugins.
Preloading 0 native plugins for Editor in 0.00 ms.
IsTimeToCheckForNewEditor: Update time 0 current 1591183008
Initialize engine version: 2019.3.15f1 (59ff3e03856d)
[Subsystems] Discovering subsystems at path /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Resources/UnitySubsystems
[Subsystems] Discovering subsystems at path /home/samfang/isaac_sim_unity3d/projects/sample/Assets
[vulkan] LoadVulkanLibrary libvulkan.so.1[vulkan] Loaded instance function vkGetInstanceProcAddr
[vulkan] Loaded instance function vkCreateInstance
[vulkan] Loaded instance function vkEnumerateInstanceExtensionProperties
[vulkan] Loaded instance function vkEnumerateInstanceLayerProperties
[vulkan] Loaded instance function vkEnumerateInstanceVersion
[Vulkan init] extensions: count=15
[Vulkan init] extensions: name=VK_KHR_device_group_creation, enabled=0
[Vulkan init] extensions: name=VK_KHR_display, enabled=1
[Vulkan init] extensions: name=VK_KHR_external_fence_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_memory_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_semaphore_capabilities, enabled=0
[Vulkan init] extensions: name=VK_KHR_get_physical_device_properties2, enabled=0
[Vulkan init] extensions: name=VK_KHR_get_surface_capabilities2, enabled=0
[Vulkan init] extensions: name=VK_KHR_surface, enabled=1
[Vulkan init] extensions: name=VK_KHR_xcb_surface, enabled=0
[Vulkan init] extensions: name=VK_KHR_xlib_surface, enabled=1
[Vulkan init] extensions: name=VK_EXT_acquire_xlib_display, enabled=0
[Vulkan init] extensions: name=VK_EXT_debug_report, enabled=1
[Vulkan init] extensions: name=VK_EXT_debug_utils, enabled=0
[Vulkan init] extensions: name=VK_EXT_direct_mode_display, enabled=0
[Vulkan init] extensions: name=VK_EXT_display_surface_counter, enabled=0
[vulkan] Loaded instance function vkDestroyInstance
[vulkan] Loaded instance function vkGetPhysicalDeviceProperties
[vulkan] Loaded instance function vkGetPhysicalDeviceProperties2
[vulkan] Loaded instance function vkEnumeratePhysicalDevices
Vulkan detection: 2
[vulkan] Loaded instance function vkGetDeviceProcAddr
[vulkan] Loaded instance function vkGetPhysicalDeviceFeatures
[vulkan] Loaded instance function vkGetPhysicalDeviceFormatProperties
[vulkan] Loaded instance function vkGetPhysicalDeviceImageFormatProperties
[vulkan] Loaded instance function vkGetPhysicalDeviceQueueFamilyProperties
[vulkan] Loaded instance function vkGetPhysicalDeviceMemoryProperties
[vulkan] Loaded instance function vkCreateDevice
[vulkan] Loaded instance function vkEnumerateDeviceExtensionProperties
[vulkan] Loaded instance function vkEnumerateDeviceLayerProperties
[vulkan] Loaded instance function vkGetPhysicalDeviceSparseImageFormatProperties
[vulkan] Loaded instance function vkDestroySurfaceKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceSurfaceSupportKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceSurfaceCapabilitiesKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceSurfaceFormatsKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceSurfacePresentModesKHR
[vulkan] Loaded instance function vkCreateSwapchainKHR
[vulkan] Loaded instance function vkDestroySwapchainKHR
[vulkan] Loaded instance function vkGetSwapchainImagesKHR
[vulkan] Loaded instance function vkAcquireNextImageKHR
[vulkan] Loaded instance function vkQueuePresentKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceDisplayPropertiesKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceDisplayPlanePropertiesKHR
[vulkan] Loaded instance function vkGetDisplayPlaneSupportedDisplaysKHR
[vulkan] Loaded instance function vkGetDisplayModePropertiesKHR
[vulkan] Loaded instance function vkCreateDisplayModeKHR
[vulkan] Loaded instance function vkGetDisplayPlaneCapabilitiesKHR
[vulkan] Loaded instance function vkCreateDisplayPlaneSurfaceKHR
[vulkan] Loaded instance function vkCreateSharedSwapchainsKHR
[vulkan] Loaded instance function vkCreateXlibSurfaceKHR
[vulkan] Loaded instance function vkGetPhysicalDeviceXlibPresentationSupportKHR
[vulkan] Loaded instance function vkSetHdrMetadataEXT
[Vulkan init] Graphics queue count=1
[Vulkan init] extensions: count=89
[Vulkan init] extensions: name=VK_KHR_8bit_storage, enabled=0
[Vulkan init] extensions: name=VK_KHR_16bit_storage, enabled=0
[Vulkan init] extensions: name=VK_KHR_bind_memory2, enabled=0
[Vulkan init] extensions: name=VK_KHR_create_renderpass2, enabled=0
[Vulkan init] extensions: name=VK_KHR_dedicated_allocation, enabled=1
[Vulkan init] extensions: name=VK_KHR_depth_stencil_resolve, enabled=0
[Vulkan init] extensions: name=VK_KHR_descriptor_update_template, enabled=1
[Vulkan init] extensions: name=VK_KHR_device_group, enabled=0
[Vulkan init] extensions: name=VK_KHR_draw_indirect_count, enabled=0
[Vulkan init] extensions: name=VK_KHR_driver_properties, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_fence, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_fence_fd, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_memory, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_memory_fd, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_semaphore, enabled=0
[Vulkan init] extensions: name=VK_KHR_external_semaphore_fd, enabled=0
[Vulkan init] extensions: name=VK_KHR_get_memory_requirements2, enabled=1
[Vulkan init] extensions: name=VK_KHR_image_format_list, enabled=1
[Vulkan init] extensions: name=VK_KHR_imageless_framebuffer, enabled=0
[Vulkan init] extensions: name=VK_KHR_maintenance1, enabled=1
[Vulkan init] extensions: name=VK_KHR_maintenance2, enabled=1
[Vulkan init] extensions: name=VK_KHR_maintenance3, enabled=0
[Vulkan init] extensions: name=VK_KHR_multiview, enabled=1
[Vulkan init] extensions: name=VK_KHR_pipeline_executable_properties, enabled=0
[Vulkan init] extensions: name=VK_KHR_push_descriptor, enabled=0
[Vulkan init] extensions: name=VK_KHR_relaxed_block_layout, enabled=0
[Vulkan init] extensions: name=VK_KHR_sampler_mirror_clamp_to_edge, enabled=1
[Vulkan init] extensions: name=VK_KHR_sampler_ycbcr_conversion, enabled=0
[Vulkan init] extensions: name=VK_KHR_shader_atomic_int64, enabled=0
[Vulkan init] extensions: name=VK_KHR_shader_draw_parameters, enabled=0
[Vulkan init] extensions: name=VK_KHR_shader_float16_int8, enabled=0
[Vulkan init] extensions: name=VK_KHR_shader_float_controls, enabled=0
[Vulkan init] extensions: name=VK_KHR_storage_buffer_storage_class, enabled=0
[Vulkan init] extensions: name=VK_KHR_swapchain, enabled=1
[Vulkan init] extensions: name=VK_KHR_swapchain_mutable_format, enabled=0
[Vulkan init] extensions: name=VK_KHR_timeline_semaphore, enabled=0
[Vulkan init] extensions: name=VK_KHR_uniform_buffer_standard_layout, enabled=0
[Vulkan init] extensions: name=VK_KHR_variable_pointers, enabled=0
[Vulkan init] extensions: name=VK_KHR_vulkan_memory_model, enabled=0
[Vulkan init] extensions: name=VK_EXT_blend_operation_advanced, enabled=0
[Vulkan init] extensions: name=VK_EXT_buffer_device_address, enabled=0
[Vulkan init] extensions: name=VK_EXT_calibrated_timestamps, enabled=0
[Vulkan init] extensions: name=VK_EXT_conditional_rendering, enabled=0
[Vulkan init] extensions: name=VK_EXT_conservative_rasterization, enabled=0
[Vulkan init] extensions: name=VK_EXT_depth_clip_enable, enabled=0
[Vulkan init] extensions: name=VK_EXT_depth_range_unrestricted, enabled=0
[Vulkan init] extensions: name=VK_EXT_descriptor_indexing, enabled=0
[Vulkan init] extensions: name=VK_EXT_discard_rectangles, enabled=0
[Vulkan init] extensions: name=VK_EXT_display_control, enabled=0
[Vulkan init] extensions: name=VK_EXT_fragment_shader_interlock, enabled=0
[Vulkan init] extensions: name=VK_EXT_global_priority, enabled=0
[Vulkan init] extensions: name=VK_EXT_host_query_reset, enabled=0
[Vulkan init] extensions: name=VK_EXT_index_type_uint8, enabled=0
[Vulkan init] extensions: name=VK_EXT_inline_uniform_block, enabled=0
[Vulkan init] extensions: name=VK_EXT_line_rasterization, enabled=0
[Vulkan init] extensions: name=VK_EXT_memory_budget, enabled=0
[Vulkan init] extensions: name=VK_EXT_pci_bus_info, enabled=0
[Vulkan init] extensions: name=VK_EXT_pipeline_creation_feedback, enabled=0
[Vulkan init] extensions: name=VK_EXT_post_depth_coverage, enabled=0
[Vulkan init] extensions: name=VK_EXT_sample_locations, enabled=0
[Vulkan init] extensions: name=VK_EXT_sampler_filter_minmax, enabled=0
[Vulkan init] extensions: name=VK_EXT_scalar_block_layout, enabled=0
[Vulkan init] extensions: name=VK_EXT_separate_stencil_usage, enabled=0
[Vulkan init] extensions: name=VK_EXT_shader_demote_to_helper_invocation, enabled=0
[Vulkan init] extensions: name=VK_EXT_shader_subgroup_ballot, enabled=0
[Vulkan init] extensions: name=VK_EXT_shader_subgroup_vote, enabled=0
[Vulkan init] extensions: name=VK_EXT_shader_viewport_index_layer, enabled=0
[Vulkan init] extensions: name=VK_EXT_subgroup_size_control, enabled=0
[Vulkan init] extensions: name=VK_EXT_texel_buffer_alignment, enabled=0
[Vulkan init] extensions: name=VK_EXT_transform_feedback, enabled=0
[Vulkan init] extensions: name=VK_EXT_vertex_attribute_divisor, enabled=0
[Vulkan init] extensions: name=VK_EXT_ycbcr_image_arrays, enabled=0
[Vulkan init] extensions: name=VK_NV_clip_space_w_scaling, enabled=0
[Vulkan init] extensions: name=VK_NV_dedicated_allocation, enabled=0
[Vulkan init] extensions: name=VK_NV_dedicated_allocation_image_aliasing, enabled=0
[Vulkan init] extensions: name=VK_NV_device_diagnostic_checkpoints, enabled=0
[Vulkan init] extensions: name=VK_NV_fill_rectangle, enabled=0
[Vulkan init] extensions: name=VK_NV_fragment_coverage_to_color, enabled=0
[Vulkan init] extensions: name=VK_NV_framebuffer_mixed_samples, enabled=0
[Vulkan init] extensions: name=VK_NV_coverage_reduction_mode, enabled=0
[Vulkan init] extensions: name=VK_NV_geometry_shader_passthrough, enabled=0
[Vulkan init] extensions: name=VK_NV_sample_mask_override_coverage, enabled=0
[Vulkan init] extensions: name=VK_NV_shader_sm_builtins, enabled=0
[Vulkan init] extensions: name=VK_NV_shader_subgroup_partitioned, enabled=0
[Vulkan init] extensions: name=VK_NV_viewport_array2, enabled=0
[Vulkan init] extensions: name=VK_NV_viewport_swizzle, enabled=0
[Vulkan init] extensions: name=VK_NVX_device_generated_commands, enabled=0
[Vulkan init] extensions: name=VK_NVX_multiview_per_view_attributes, enabled=0
[Vulkan init] extensions: name=VK_NV_ray_tracing, enabled=0
[vulkan] Loaded device function vkDestroyDevice
[vulkan] Loaded device function vkGetDeviceQueue
[vulkan] Loaded device function vkQueueSubmit
[vulkan] Loaded device function vkQueueWaitIdle
[vulkan] Loaded device function vkDeviceWaitIdle
[vulkan] Loaded device function vkAllocateMemory
[vulkan] Loaded device function vkFreeMemory
[vulkan] Loaded device function vkMapMemory
[vulkan] Loaded device function vkUnmapMemory
[vulkan] Loaded device function vkFlushMappedMemoryRanges
[vulkan] Loaded device function vkInvalidateMappedMemoryRanges
[vulkan] Loaded device function vkGetDeviceMemoryCommitment
[vulkan] Loaded device function vkBindBufferMemory
[vulkan] Loaded device function vkBindImageMemory
[vulkan] Loaded device function vkGetBufferMemoryRequirements
[vulkan] Loaded device function vkGetImageMemoryRequirements
[vulkan] Loaded device function vkGetImageSparseMemoryRequirements
[vulkan] Loaded device function vkQueueBindSparse
[vulkan] Loaded device function vkCreateFence
[vulkan] Loaded device function vkDestroyFence
[vulkan] Loaded device function vkResetFences
[vulkan] Loaded device function vkGetFenceStatus
[vulkan] Loaded device function vkWaitForFences
[vulkan] Loaded device function vkCreateSemaphore
[vulkan] Loaded device function vkDestroySemaphore
[vulkan] Loaded device function vkCreateEvent
[vulkan] Loaded device function vkDestroyEvent
[vulkan] Loaded device function vkGetEventStatus
[vulkan] Loaded device function vkSetEvent
[vulkan] Loaded device function vkResetEvent
[vulkan] Loaded device function vkCreateQueryPool
[vulkan] Loaded device function vkDestroyQueryPool
[vulkan] Loaded device function vkGetQueryPoolResults
[vulkan] Loaded device function vkCreateBuffer
[vulkan] Loaded device function vkDestroyBuffer
[vulkan] Loaded device function vkCreateBufferView
[vulkan] Loaded device function vkDestroyBufferView
[vulkan] Loaded device function vkCreateImage
[vulkan] Loaded device function vkDestroyImage
[vulkan] Loaded device function vkGetImageSubresourceLayout
[vulkan] Loaded device function vkCreateImageView
[vulkan] Loaded device function vkDestroyImageView
[vulkan] Loaded device function vkCreateShaderModule
[vulkan] Loaded device function vkDestroyShaderModule
[vulkan] Loaded device function vkCreatePipelineCache
[vulkan] Loaded device function vkDestroyPipelineCache
[vulkan] Loaded device function vkGetPipelineCacheData
[vulkan] Loaded device function vkMergePipelineCaches
[vulkan] Loaded device function vkCreateGraphicsPipelines
[vulkan] Loaded device function vkCreateComputePipelines
[vulkan] Loaded device function vkCreatePipelineLayout
[vulkan] Loaded device function vkDestroyPipelineLayout
[vulkan] Loaded device function vkCreateSampler
[vulkan] Loaded device function vkDestroySampler
[vulkan] Loaded device function vkCreateDescriptorSetLayout
[vulkan] Loaded device function vkDestroyDescriptorSetLayout
[vulkan] Loaded device function vkCreateDescriptorPool
[vulkan] Loaded device function vkDestroyDescriptorPool
[vulkan] Loaded device function vkResetDescriptorPool
[vulkan] Loaded device function vkAllocateDescriptorSets
[vulkan] Loaded device function vkFreeDescriptorSets
[vulkan] Loaded device function vkUpdateDescriptorSets
[vulkan] Loaded device function vkCreateFramebuffer
[vulkan] Loaded device function vkDestroyFramebuffer
[vulkan] Loaded device function vkCreateRenderPass
[vulkan] Loaded device function vkDestroyRenderPass
[vulkan] Loaded device function vkGetRenderAreaGranularity
[vulkan] Loaded device function vkCreateCommandPool
[vulkan] Loaded device function vkDestroyCommandPool
[vulkan] Loaded device function vkResetCommandPool
[vulkan] Loaded device function vkAllocateCommandBuffers
[vulkan] Loaded device function vkFreeCommandBuffers
[vulkan] Loaded device function vkBeginCommandBuffer
[vulkan] Loaded device function vkEndCommandBuffer
[vulkan] Loaded device function vkResetCommandBuffer
[vulkan] Loaded device function vkCmdBindPipeline
[vulkan] Loaded device function vkCmdSetViewport
[vulkan] Loaded device function vkCmdSetScissor
[vulkan] Loaded device function vkCmdSetLineWidth
[vulkan] Loaded device function vkCmdSetDepthBias
[vulkan] Loaded device function vkCmdSetBlendConstants
[vulkan] Loaded device function vkCmdSetDepthBounds
[vulkan] Loaded device function vkCmdSetStencilCompareMask
[vulkan] Loaded device function vkCmdSetStencilWriteMask
[vulkan] Loaded device function vkCmdSetStencilReference
[vulkan] Loaded device function vkCmdBindDescriptorSets
[vulkan] Loaded device function vkCmdBindIndexBuffer
[vulkan] Loaded device function vkCmdBindVertexBuffers
[vulkan] Loaded device function vkCmdDraw
[vulkan] Loaded device function vkCmdDrawIndexed
[vulkan] Loaded device function vkCmdDrawIndirect
[vulkan] Loaded device function vkCmdDrawIndexedIndirect
[vulkan] Loaded device function vkCmdDispatch
[vulkan] Loaded device function vkCmdDispatchIndirect
[vulkan] Loaded device function vkCmdCopyBuffer
[vulkan] Loaded device function vkCmdCopyImage
[vulkan] Loaded device function vkCmdBlitImage
[vulkan] Loaded device function vkCmdCopyBufferToImage
[vulkan] Loaded device function vkCmdCopyImageToBuffer
[vulkan] Loaded device function vkCmdUpdateBuffer
[vulkan] Loaded device function vkCmdFillBuffer
[vulkan] Loaded device function vkCmdClearColorImage
[vulkan] Loaded device function vkCmdClearDepthStencilImage
[vulkan] Loaded device function vkCmdClearAttachments
[vulkan] Loaded device function vkCmdResolveImage
[vulkan] Loaded device function vkCmdSetEvent
[vulkan] Loaded device function vkCmdResetEvent
[vulkan] Loaded device function vkCmdWaitEvents
[vulkan] Loaded device function vkCmdPipelineBarrier
[vulkan] Loaded device function vkCmdBeginQuery
[vulkan] Loaded device function vkCmdEndQuery
[vulkan] Loaded device function vkCmdResetQueryPool
[vulkan] Loaded device function vkCmdWriteTimestamp
[vulkan] Loaded device function vkCmdCopyQueryPoolResults
[vulkan] Loaded device function vkCmdPushConstants
[vulkan] Loaded device function vkCmdBeginRenderPass
[vulkan] Loaded device function vkCmdNextSubpass
[vulkan] Loaded device function vkCmdEndRenderPass
[vulkan] Loaded device function vkCmdExecuteCommands
[vulkan] Loaded device function vkGetImageMemoryRequirements2KHR
[vulkan] Loaded device function vkGetBufferMemoryRequirements2KHR
[vulkan] Loaded device function vkGetImageSparseMemoryRequirements2KHR
[vulkan] Loaded device function vkCreateDescriptorUpdateTemplateKHR
[vulkan] Loaded device function vkDestroyDescriptorUpdateTemplateKHR
[vulkan] Loaded device function vkUpdateDescriptorSetWithTemplateKHR
[vulkan] Failed to load device function vkDebugMarkerSetObjectTagEXT
[vulkan] Loaded instance function vkDebugMarkerSetObjectTagEXT
[vulkan] Failed to load device function vkDebugMarkerSetObjectNameEXT
[vulkan] Loaded instance function vkDebugMarkerSetObjectNameEXT
[vulkan] Failed to load device function vkCmdDebugMarkerBeginEXT
[vulkan] Loaded instance function vkCmdDebugMarkerBeginEXT
[vulkan] Failed to load device function vkCmdDebugMarkerEndEXT
[vulkan] Loaded instance function vkCmdDebugMarkerEndEXT
[vulkan] Failed to load device function vkCmdDebugMarkerInsertEXT
[vulkan] Loaded instance function vkCmdDebugMarkerInsertEXT
Vulkan API version 1.1.0 (1.1.119 supported by driver)
Vulkan vendor=[NVIDIA] id=[10de]
Vulkan renderer=[GeForce GTX 1060 6GB] id=[1c03]
Vulkan device type 2
Vulkan driverversion=[0x6e148000] uint=[1846837248]
Vulkan PSO: cache data not found [path=/tmp/NVIDIA/IsaacSim Unity3D/vulkan_pso_cache.bin]
Initialize mono
Mono path[0] = '/home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/Managed'
Mono path[1] = '/home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/MonoBleedingEdge/lib/mono/unityjit'
Mono config path = '/home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/MonoBleedingEdge/etc'
Using monoOptions --debugger-agent=transport=dt_socket,embedding=1,server=y,suspend=n,address=127.0.0.1:56781
ImportWorker Server TCP listen port: 35445
Begin MonoManager ReloadAssembly
Registering precompiled unity dll's ...
Register platform support module: /home/samfang/Unity/Hub/Editor/2019.3.15f1/Editor/Data/PlaybackEngines/LinuxStandaloneSupport/UnityEditor.LinuxStandalone.Extensions.dll
Registered in 0.001446 seconds.
Native extension for LinuxStandalone target not found
Refreshing native plugins compatible for Editor in 41.03 ms, found 0 plugins.
Mono: successfully reloaded assembly
- Completed reload, in  1.138 seconds
Registering precompiled user dll's ...
Registered in 0.102387 seconds.
Platform modules already initialized, skipping
Validating Project structure ... 0.002374 seconds.
Shader import version has changed; will reimport all shaders...
Upgrading shader files ...0.002392 seconds.
However, the same issue occurs. It gets stuck on the unity splash screen and no further messages are logged in terminal.
I have also tried using the 2019.3.0f6 version of unity, as well as downloading and extracting isaac sim 2020 again.
Does anybody know what the issue could be?
same problem.
I hit the same issue also, after some investigation it appears that the core and sample packages contain a third_party_notices.txt file that is a symlink. This causes a recursive import and unity will lock up.
To correct this issue delete the following files from isaac_sim_unity3d :-
isaac_sim_unity3d/packages/Nvidia/Core/ThirdParty/third_party_notices.txt
isaac_sim_unity3d/packages/Nvidia/Core/ThirdParty/third_party_notices.txt.meta
isaac_sim_unity3d/packages/Nvidia/Samples/ThirdParty/third_party_notices.txt
isaac_sim_unity3d/packages/Nvidia/Samples/ThirdParty/third_party_notices.txt.meta
After doing this, start unity again and the import should now succeed.
This solved my issue. Thank you!
Solved my issue too. Thx.
I had the same issue, this solved it. Thanks
The other reason may be the license of Unity is not activated.
