Hi ,
I have try 4 times to install on windows 10 but after download finish it start to install and stop with this message :
Error occurred during installation of Isaac Sim: EBUSY: resource busy or locked, open ‘D:\prog\omniverse\pkg\isaac_sim-2022.1.0\exts\omni.isaac.motion_planning\omni\isaac\motion_planning_motion_planning.cp37-win_amd64.pyd’
I have try to run as administrator too , same issue at the end :(
Thank you for your answer :)
But solution was simpler than that ;) … here on vacation i use a 4 year old asus rog strix that don’t have RTX but GTX graphic card built in.
Because of this omniverse stop at the 1st error concerning the RTX during installation and delete the more than 4gb zip file from isaac sim …
One improvement will be to not delete this file so long everything is not installed correctly , so we don’t have to download the 4gb file each time ;)
I found why it was not ok to install in executing each batch file one after the other and see the error passing when it was executing the scripts ;)
I’m finally back to home for test this on my desktop PC with this setup :
AMD Ryzen 9 3950x
ROG Strix RTX2080TI 11Gig
48gb of RAM
This time i get this error at installing isaac sim : Error occurred during installation of Isaac Sim: EBUSY: resource busy or locked, open ‘E:\nvidia_omniverse\pkg\isaac_sim-2022.1.0\exts\omni.isaac.motion_planning\omni\isaac\motion_planning_motion_planning.cp37-win_amd64.pyd’
I successfully installed ‘create’ , ‘kit’ ,‘usdview’ and ‘view’ with no issue :)
To be sure about python , i uninstalled it from my system before installing omniverse , so isaac sim will use the one in it’s own package ;)
