Isaac Sim 3D lidar vertical FOV does not have any effect
I am trying to use the 3D lidar pointcloud in Isaac over ROS. I noticed that the data coming across the /pointcloud topic is the same as the data coming across the /scan topic. When making changes to the vertacle FOV, nothing changes on the pointcloud topic. See screenshot for more info:
Check the highLod box and that will enable 3d lidar
Thank you!!!
