Isaac Sim 4.5.0 Benchmark
I’m evaluating my hardware’s performance using the following guide:
Isaac Sim Benchmarks
When I run the SDG images per second (complex) benchmark:
./python.sh standalone_examples/benchmarks/benchmark_sdg.py \
  --num-cameras 2 --resolution 1280 720 --asset-count 100 \
  --annotators all --disable-viewport-rendering \
  --skip-write --headless
I get a mean FPS of 1.56. Do you know why the FPS is so low?
Spec:
Ubuntu 22.04
GPUs: 2ADA6000 + 2 A5000
CPU: AMD® Ryzen threadripper pro 3975wx 32-cores × 64
RAM: 256 Go
Here is the output from my terminal:
2025-03-24 13:10:12 [33,979ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2025-03-24 13:10:16 [38,128ms] [Warning] [isaacsim.benchmark.services.recorders] Detected multiple GPU types: ['NVIDIA RTX 6000 Ada Generation', 'NVIDIA RTX 6000 Ada Generation', 'NVIDIA RTX A5000', 'NVIDIA RTX A5000'].
2025-03-24 13:10:16 [38,128ms] [Warning] [isaacsim.benchmark.services.recorders] Only recording GPU 0 type: NVIDIA RTX 6000 Ada Generation
[SDG Benchmark] Starting SDG..
2025-03-24 13:10:16 [38,259ms] [INFO] [isaacsim.benchmark.services.base_isaac_benchmark] Starting phase: benchmark
Module omni.replicator.core.ogn.python._impl.nodes.OgnSemanticSegmentation a0ffa74 load on device 'cuda:0' took 0.47 ms  (cached)
Module omni.replicator.core.ogn.python._impl.nodes.OgnSemanticSegmentation a0ffa74 load on device 'cuda:2' took 0.38 ms  (cached)
Module omni.replicator.core.ogn.python._impl.nodes.OgnPointCloudGenerator 1f4060b load on device 'cuda:0' took 0.43 ms  (cached)
Module omni.replicator.core.ogn.python._impl.nodes.OgnPointCloudGenerator 1f4060b load on device 'cuda:2' took 0.35 ms  (cached)
2025-03-24 13:16:44 [425,942ms] [Warning] [isaacsim.benchmark.services.recorders] Detected multiple GPU types: ['NVIDIA RTX 6000 Ada Generation', 'NVIDIA RTX 6000 Ada Generation', 'NVIDIA RTX A5000', 'NVIDIA RTX A5000'].
2025-03-24 13:16:44 [425,942ms] [Warning] [isaacsim.benchmark.services.recorders] Only recording GPU 0 type: NVIDIA RTX 6000 Ada Generation
2025-03-24 13:16:44 [426,094ms] [INFO] [isaacsim.benchmark.services.base_isaac_benchmark] Stopping
2025-03-24 13:16:44 [426,095ms] [INFO] [isaacsim.benchmark.services.base_isaac_benchmark] Writing metrics data.
2025-03-24 13:16:44 [426,095ms] [INFO] [isaacsim.benchmark.services.base_isaac_benchmark] Metrics type = OmniPerfKPIFile
2025-03-24 13:16:44 [426,095ms] [INFO] [isaacsim.benchmark.services.metrics.backend]
loading Metrics:
workflow_name: benchmark_sdg
num_frames: 600
num_cameras: 2
width: 1280
height: 720
asset_count: 100
annotators: all
num_gpus: 4
phase: loading
System Memory RSS: 10.263 GB
System Memory VMS: 209.412 GB
System Memory USS: 10.212 GB
GPU Memory Tracked: 7.521 GB
GPU Memory Dedicated: 2.487 GB
System CPU iowait: 0.0 %
System CPU system: 4.0 %
System CPU user: 9.0 %
System CPU idle: 87.0 %
num_cpus: 64
gpu_device_name: NVIDIA RTX 6000 Ada Generation
Runtime: 19454.56 ms
benchmark Metrics:
num_frames: 600
num_cameras: 2
width: 1280
height: 720
asset_count: 100
annotators: all
num_gpus: 4
phase: benchmark
System Memory RSS: 10.497 GB
System Memory VMS: 258.225 GB
System Memory USS: 10.444 GB
GPU Memory Tracked: 7.506 GB
GPU Memory Dedicated: 2.476 GB
System CPU system: 9.0 %
System CPU user: 27.0 %
System CPU idle: 64.0 %
num_cpus: 64
Mean App_Update Frametime: 640.85 ms
Stdev App_Update Frametime: 7.12 ms
Min App_Update Frametime: 626.13 ms
Max App_Update Frametime: 654.89 ms
Mean Physics Frametime: 0.18 ms
Stdev Physics Frametime: 0.01 ms
Min Physics Frametime: 0.16 ms
Max Physics Frametime: 0.19 ms
Mean GPU Frametime: 12.23 ms
Stdev GPU Frametime: 0.78 ms
Min GPU Frametime: 10.82 ms
Max GPU Frametime: 13.98 ms
Mean FPS: 1.56 FPS
Real Time Factor: 1.008
Runtime: 384643.526 ms
2025-03-24 13:16:44 [426,096ms] [INFO] [isaacsim.benchmark.services.metrics.backend] Writing metrics to /tmp/kpis_benchmark_sdg.json
|                   Summary Report                   |
| workflow_name: benchmark_sdg                       |
| num_frames: 600                                    |
| num_cameras: 2                                     |
| width: 1280                                        |
| height: 720                                        |
| asset_count: 100                                   |
| annotators: all                                    |
| num_gpus: 4                                        |
| num_cpus: 64                                       |
| gpu_device_name: NVIDIA RTX 6000 Ada Generation    |
| Phase: loading                                     |
| System Memory RSS: 10.263 GB                       |
| System Memory VMS: 209.412 GB                      |
| System Memory USS: 10.212 GB                       |
| GPU Memory Tracked: 7.521 GB                       |
| Runtime: 19454.56 ms                               |
| Phase: benchmark                                   |
| System Memory RSS: 10.497 GB                       |
| System Memory VMS: 258.225 GB                      |
| System Memory USS: 10.444 GB                       |
| GPU Memory Tracked: 7.506 GB                       |
| Mean FPS: 1.56 FPS                                 |
| Real Time Factor: 1.008                            |
| Runtime: 384643.526 ms                             |
| Frametimes (ms):    mean |  stdev |   min |   max  |
| App_Update        640.85 |   7.12 | 626.13 | 654.89 |
| Physics             0.18 |   0.01 |  0.16 |  0.19  |
| GPU                12.23 |   0.78 | 10.82 | 13.98  |
2025-03-24 13:16:45 [427,270ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
Thanks for sharing your benchmark results. We understand your concern about the performance you’re seeing with the complex task.
Currently, seeing performance under 3 FPS for such a complex task is within the expected range. We are still awaiting the results of our internal testing. Once we have those results, we’ll be able to provide a more comprehensive update on this.
