Isaac Sim 5.0 Crashes Immediately When Adding Ground Plane via UI (RTX 5090, Driver 580.82, Ubuntu 22.04)
Isaac Sim Version
☑️ 5.0.0
(Other options unchecked)
Operating System
☑️ Ubuntu 22.04
GPU Information
Model: NVIDIA GeForce RTX 5090D
Driver Version: 580.82.09
Topic Description
Isaac Sim crashes with a segmentation fault immediately after adding a Ground Plane via the UI menu.
Detailed Description
I was attempting to set up a basic simulation scene by adding a physics-enabled ground plane using the built-in UI workflow. I expected a flat static collider to appear in the stage, as it does in previous versions or on other hardware. Instead, the application crashes instantly with a segmentation fault the moment I select Create → Physics → Ground Plane. The crash appears to originate in low-level CUDA memory management during USD/Hydra scene delegate initialization.
Steps to Reproduce
  1. Launch Isaac Sim 5.0.0 on Ubuntu 22.04 with RTX 5090 and driver 580.82.09.
  2. Wait for the empty stage to load successfully.
  3. Click the top menu: Create → Physics → Ground Plane.
  4. Application immediately crashes with Segmentation fault (core dumped).
Error Messages
[9.732s] Isaac Sim Full App is loaded.
2025-10-14T07:39:38Z [35,907ms] [Warning] [usdrt.hydra.fabric_scene_delegate.plugin] using high frequency span with attrs is disabled
2025-10-14T07:39:39Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-10-14T07:39:39Z [35ms] [Error] [carb.crashreporter-breakpad.plugin] 'crashreport.gui' exited with code 2
2025-10-14T07:39:39Z [36ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/zanyue/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/0efc64e2-caf5-4bff-3a6cad96-50312422.dmp'
2025-10-14T07:39:39Z [37ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: '/home/zanyue/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/0efc64e2-caf5-4bff-3a6cad96-50312422.dmp'
2025-10-14T07:39:39Z [38ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     dump file size is 4513272 bytes, file is readable.
2025-10-14T07:39:39Z [39ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 111945 thread 111945
2025-10-14T07:39:39Z [39ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-10-14T07:39:39Z [40ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  BuildGitlabJobID = '182268558'
2025-10-14T07:39:39Z [41ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '206.4+release.9396.3c6f8191.gl'
2025-10-14T07:39:39Z [42ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Tue Oct 14 07:39:39 2025 GMT'
2025-10-14T07:39:39Z [42ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2025-10-14T07:39:39Z [43ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = '0efc64e2-caf5-4bff-3a6cad96-50312422'
2025-10-14T07:39:39Z [44ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  LastUploadStatus = '0'
2025-10-14T07:39:39Z [45ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2025-10-14T07:39:39Z [45ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zanyue/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/0efc64e2-caf5-4bff-3a6cad96-50312422.py.txt''
2025-10-14T07:39:39Z [110ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2025-10-14T07:39:39Z [111ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/isaacsim'
2025-10-14T07:39:39Z [112ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 111945 backtrace follows:
2025-10-14T07:39:39Z [155ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2025-10-14T07:39:39Z [159ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libcuda.so.1!+0x1c4c83
2025-10-14T07:39:39Z [164ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcuda.so.1!cuMemSetMemPool+0x1bd42 (??:?)
2025-10-14T07:39:39Z [168ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libcuda.so.1!cuMemPoolSetAccess+0x20 (??:?)
2025-10-14T07:39:39Z [170ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libusdrt.hydra.fabric_scene_delegate.plugin.so!absl::hash_internal::CityHash64WithSeed(char const*, unsigned long, unsigned long)+0x6d24 (??:?)
2025-10-14T07:39:39Z [172ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libusdrt.hydra.fabric_scene_delegate.plugin.so!absl::hash_internal::CityHash64WithSeed(char const*, unsigned long, unsigned long)+0x4e756 (??:?)
2025-10-14T07:39:39Z [174ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libusdrt.hydra.fabric_scene_delegate.plugin.so!std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release()+0xdfee (??:?)
2025-10-14T07:39:39Z [176ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libusdrt.hydra.fabric_scene_delegate.plugin.so!std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release()+0xe4e3 (??:?)
2025-10-14T07:39:39Z [178ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libusdrt.hydra.fabric_scene_delegate.plugin.so!std::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_release()+0xea09 (??:?)
2025-10-14T07:39:39Z [181ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libusdrt.hydra.fabric_scene_delegate.plugin.so!std::__shared_count<(__gnu_cxx::_Lock_policy)2>::__shared_count<usdrt::hydra::SceneDelegate::MeshInfo, std::allocator<usdrt::hydra::SceneDelegate::MeshInfo>>(usdrt::hydra::SceneDelegate::MeshInfo*&, std::_Sp_alloc_shared_tag<std::allocator<usdrt::hydra::SceneDelegate::MeshInfo> >)+0x2472d (??:?)
2025-10-14T07:39:39Z [182ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libusdrt.hydra.fabric_scene_delegate.plugin.so!void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<gsl::details::span_iterator<char const> >(gsl::details::span_iterator<char const>, gsl::details::span_iterator<char const>)+0x4b6b7 (??:?)
2025-10-14T07:39:39Z [184ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libusdrt.hydra.fabric_scene_delegate.plugin.so!void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<gsl::details::span_iterator<char const> >(gsl::details::span_iterator<char const>, gsl::details::span_iterator<char const>)+0x67991 (??:?)
2025-10-14T07:39:39Z [186ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libusdrt.hydra.fabric_scene_delegate.plugin.so!void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<gsl::details::span_iterator<char const> >(gsl::details::span_iterator<char const>, gsl::details::span_iterator<char const>)+0x6884e (??:?)
2025-10-14T07:39:39Z [188ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libusdrt.hydra.fabric_scene_delegate.plugin.so!omniCarbStartup+0x7b6 (??:?)
2025-10-14T07:39:39Z [192ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: librtx.hydra.so!std::pair<std::_Rb_tree_iterator<unsigned long>, bool> std::_Rb_tree<unsigned long, unsigned long, std::_Identity<unsigned long>, std::less<unsigned long>, std::allocator<unsigned long> >::_M_insert_unique<unsigned long>(unsigned long&&)+0x646f (??:?)
2025-10-14T07:39:39Z [195ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: librtx.hydra.so!std::unique_lock<std::shared_mutex>::unlock()+0x13b0e (??:?)
2025-10-14T07:39:39Z [198ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.usd.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_rehash(unsigned long, unsigned long const&)+0xe6ff (??:?)
2025-10-14T07:39:39Z [202ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.usd.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_rehash(unsigned long, unsigned long const&)+0x12108 (??:?)
2025-10-14T07:39:39Z [206ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.usd.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_rehash(unsigned long, unsigned long const&)+0x14542 (??:?)
2025-10-14T07:39:39Z [210ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.usd.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_rehash(unsigned long, unsigned long const&)+0x1593c (??:?)
2025-10-14T07:39:39Z [213ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libomni.usd.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_rehash(unsigned long, unsigned long const&)+0x16b96 (??:?)
2025-10-14T07:39:39Z [219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libcarb.eventdispatcher.plugin.so!carbOnPluginRegisterEx+0x3441 (??:?)
2025-10-14T07:39:39Z [222ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libomni.kit.loop-isaac.plugin.so!void std::__detail::__to_chars_10_impl<unsigned int>(char*, unsigned int, unsigned int)+0x1a48d (??:?)
2025-10-14T07:39:39Z [226ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libomni.kit.app.plugin.so!+0x235e1
2025-10-14T07:39:39Z [232ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libomni.kit.app.plugin.so!carbOnPluginPreStartup+0x1fa0 (??:?)
2025-10-14T07:39:39Z [233ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: kit!+0x3cd3
2025-10-14T07:39:39Z [266ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2025-10-14T07:39:39Z [300ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2025-10-14T07:39:39Z [302ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: kit!_start+0x25 (??:?)
Additional Information
What I’ve Tried
  • Verified only one physical GPU is active (via nvidia-smi).
  • Confirmed system has ample RAM (64 GB) and VRAM (>22 GB free).
  • Launch command:./isaac-sim.sh --enable omni.isaac.ros2_bridge
  • The crash occurs even when no ROS 2 nodes are running—suggesting the issue is in core rendering/physics initialization, not the bridge.
@565942185 i am just another user, but could you try reverting the driver down to R570 and see if the same behavior persists?
Thank you very much for your reply, but currently the official website only provides the 580-series driver, so it’s not possible to downgrade to version 570.
could give this a shot per Unix Drivers | NVIDIA -
Thank you very much! I’m going to try it right away.
Hello!
Best regards,
