Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: NVIDIA RTX 5070 Laptop GPU
- Driver Version: 591.74
Topic Description
[Isaac Sim 6.0.0] USD to URDF export produces empty robot name attribute, breaks re-import
Detailed Description
When exporting a robot USD to URDF using File > Export to URDF in Isaac Sim 6.0.0, the generated URDF file has an empty robot name attribute (<robot name="">). This makes the exported URDF invalid, because re-importing it into Isaac Sim fails with a parsing error stating the robot name is required.
I was trying to export Isaac Sim’s built-in robot USD assets (e.g. UR3, UR10e) to URDF in order to compare with other similar urdfs. I expected the exported URDF to contain a valid robot name, as it does in Isaac Sim 5.1.0. Instead, the name field is exported empty, and the file cannot be re-imported without manual editing.
The same export workflow in Isaac Sim 5.1.0 correctly populates the robot name (e.g. <robot name="ur3_usd">) and the resulting URDF imports without any issue.
Steps to Reproduce
- Open Isaac Sim 6.0.0
- Add a robot from the content browser to the stage (e.g. UR3 from Isaac/Robots/UniversalRobots)
- Delete the fixed root_link,
root_joint(andee_jointif present) so the export proceeds - Go to File > Export to URDF, set the root prim path, and export
- Open the exported
.urdfin a text editor — the<robot name="">attribute is empty - Attempt to re-import the same URDF via File > Import — import fails
Error Messages
Failed to convert assets ['C:/dev/USD_to_URDF/ur3_isaac6.urdf'] since importer failed with Error parsing XML: robot: name is required (line: 2).
Additional Information
- Isaac Sim version: 6.0.0.0 (Full)
- OS: Windows 11
- GPU: NVIDIA RTX 5070 Laptop GPU
What I’ve Tried
Manually editing the exported URDF to add a robot name (changing <robot name=""> to <robot name="ur3">) resolves the issue — the URDF then imports successfully. This confirms the only problem is the missing name attribute at export time. The same robot exported from Isaac Sim 5.1.0 includes a valid name automatically.
Additional Context
This appears to be a regression in the 6.0.0 USD-to-URDF exporter compared to 5.1.0 only the robot name attribute is affected.
