Isaac Sim 6.x Acoustic WPM – Access to Path Length, Custom Ray Properties, and CUDA Trace Results
Hello NVIDIA Isaac Sim team,
I am investigating the RTX Acoustic Sensor and Wave Propagation Model (WPM) in Isaac Sim 6.x for a 1.2 MHz underwater 3D sonar simulation.
To adapt the existing Acoustic Sensor to seawater, I need to apply a sound speed of approximately 1500 m/s and frequency-dependent acoustic absorption. This requires access to the total propagation path length and the contribution amplitude for each received acoustic path.
After reviewing the WPM and Material Manager documentation, I found NvMatRayProps, customPropsSize, distPrevHit, and IWpm::getTraceResult().
I would appreciate clarification on the following questions:
  1. Custom ray properties: Can a custom field, such as accumulated path length, be added to NvMatRayProps and preserved across multiple WPM ray bounces?
  2. TraceResult structure: Does getTraceResult() expose per-path information such as total path length, receiver ID, contribution amplitude, material ID, or ray/path identifiers?
  3. GPU memory access: Can the TraceResult or contribution buffers be accessed directly from a custom CUDA kernel without copying all intermediate ray data to CPU memory?
  4. Acoustic Sensor integration: Can these features be used while retaining the built-in Acoustic Sensor, or would a custom WPM sensor model be required?
  5. Sound speed: Is there a supported API for changing the background acoustic propagation speed to approximately 1500 m/s?
My goal is to preserve RTX/WPM multi-bounce tracing while applying underwater propagation and statistical surface-scattering corrections efficiently on the GPU.
If possible, could you point me to relevant public C++ headers, SDK examples, or sample implementations?
Thank you for your time and assistance.
Hi, thanks for posting your questions. Here is how the current WPM / Acoustic Sensor implementation behaves for each point.
Yes. NvMatRayProps is designed to be extended. You derive your own struct from it (the built-in Acoustic Sensor already does this to carry its transmitter ID and channel). Then you set Config::customRayPropsSize = sizeof(YourProps) on the WPM and fill the initial values per primary ray in TraceDefinition::rayProps2D. On every bounce, WPM passes the parent ray’s props to the material shader as NvMatInput::incRayProps, with customPropsSize set. The material shader is responsible for copying the full blob into the reflected/transmitted/lookup output props and for modifying the amplitude in vector. The NVIDIA materials copy the full customPropsSize, so your extra fields are preserved across bounces. Any custom material you write must do the same.
You don’t need a custom field just for path length, though. WPM already accumulates it per ray and reports it per contribution (see 2). distPrevHit is only the length of the last segment. It is given to the material in case you want to apply per-segment effects such as absorption inside the BSDF.
2. TraceResult contents
getTraceResult() returns a TraceResult with:
  • contributions2D: struct-of-arrays indexed as [receiverIdx * maxNumBouncesPerReceiver + bounceIdx], with isValid, numBounces, rtDistance (total path length from transmitter through all bounces to the receiver, in meters), rtVelocity (optional), pos (hit point in the receiver frame), deltaTimeNs, materialId, cosAngle, accumBeamRangeDivergence, and optionally the hit triangle vertices.
  • rayProps2D: your custom ray properties for each contribution, using the same indexing. The contribution amplitude is in NvMatRayProps::vector (the acoustic model uses vector.x).
  • maxNumBouncesPerReceiver.
The receiver ID is implicit in the index, and the material ID and total path length are explicit. There is no built-in primary-ray/path identifier. If you need one, store it in your custom ray props when you build the trace definition. Note that you get one contribution per bounce per receiver, not the full list of intermediate bounce points for each path.
Yes. When the WPM runs on a CUDA device, all TraceResult arrays are device pointers. A sensor model can pass the TraceResult straight into its own CUDA kernels without a host copy, which is how the built-in Acoustic Sensor builds its waveforms. This only works for the sensor model that owns the WPM instance, though. The built-in Acoustic Sensor does not expose its internal trace result to external code. It only publishes the processed outputs (signal-way waveforms / GenericModelOutput).
4. Using the built-in Acoustic Sensor
For a 1.2 MHz underwater sonar, the built-in Acoustic Sensor is unlikely to be suitable as-is, even with parameter changes. It is calibrated for in-air ultrasonic parking sensors (~50 kHz). The speed of sound, the waveform sample period, the maximum range, and the amplitude/close-range calibration are all fixed in the model. It has no absorption term and no hook for inserting your own processing between the trace result and the waveform. Your use case would need a custom sensor model built on the RtxSensor + WPM APIs, plus suitable acoustic materials for a water medium. The current acoustic material computes reflection/transmission against air impedance.
5. Sound speed
There is currently no API or USD attribute to change the propagation speed. The Acoustic Sensor uses a fixed speed of sound for air (343.21 m/s), and it applies to both time-of-flight and the acoustic material model. In a custom WPM-based model, this isn’t a blocker: rtDistance is purely geometric (meters), so you can compute time of flight with c = 1500 m/s and apply frequency-dependent absorption as a function of rtDistance in your own CUDA kernel.
References
