Hey,
I’m running Isaac Sim and I’m searching how to do the camera path, I found in some videos the plugin of camera animation “omni.anim.camera tool” do you know guys where i can install this plugin ?is there another alternative ? The sequencer can be used also for the camera path? if yes how I can implement it in Isaac Sim ? I’m using right now the movie capture plugin but with no camera path option.
Additional extensions like the sequencer or time sample editor can be enabled from the Window->Extensions panel.
