Hi all,
I’m trying to write a class for my robot based on the code used for the Jetbot class, and I try to use it in the Hello Robot turtorial similarly to how the Jetbot class is used. I created a new folder in isaac_sim-2021.2.1/exts
which is a copy of omni.isaac.jetbot
folder, called it omni.isaac.link
, and changed all of the files in this directory to from to for my Link robot. For some reason, the simulation doesn’t recognize the directory and generate this error:
2022-03-06 19:44:07 [184,109,573ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.isaac.examples.tests. Error: No module named 'omni.isaac.link'. Traceback:
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py", line 65, in import_module
return importlib.import_module(name)
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/omni/isaac/examples/tests/__init__.py", line 17, in <module>
from .test_hello_world import *
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/omni/isaac/examples/tests/test_hello_world.py", line 18, in <module>
from omni.isaac.examples.hello_world import HelloWorld
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/omni/isaac/examples/hello_world/__init__.py", line 9, in <module>
from omni.isaac.examples.user_examples.hello_world import HelloWorld
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/omni/isaac/examples/user_examples/__init__.py", line 1, in <module>
File "/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/omni/isaac/examples/user_examples/hello_world.py", line 90, in <module>
from omni.isaac.link import Link
ModuleNotFoundError: No module named 'omni.isaac.link'
2022-03-06 19:44:07 [184,109,573ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.examples.tests' in '/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/.' failed to load.
At:
/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(169): startup_all_extensions_in_module
/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2): <module>
2022-03-06 19:44:07 [184,109,573ms] [Error] [omni.ext.plugin] [ext: omni.isaac.examples-0.1.17] Failed to process python module extension in '/home/USER/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.examples/.'.
I added the class to omni.isaac.examples.tests
but it didn’t help.
I am very new to Isaac Sim and trying to learn my way around it. Please let me know if I miss something.
Thank you!
