This is my first time to come here for asking for help.
I had meet a problem, I think it is related with my apt upgrade
operation.
In that day, I just upgraded the apt library.
But I can’t open Isaac Sim anymore.
The log of Isaac Sim is below:
11:54:56.788 › Logged in.
11:55:00.944 › (node:15251) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, access ‘/home/archy/.nvidia-omniverse/config/auth.toml’
11:55:00.944 › (node:15251) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag--unhandled-rejections=strict
(see Command-line API | Node.js v21.2.0 Documentation). (rejection id: 2)
11:55:02.914 › Running “/home/archy/.local/share/ov/pkg/isaac_sim-2022.2.1/isaac-sim.selector.sh”
11:55:05.945 › (node:15251) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, access ‘/home/archy/.nvidia-omniverse/config/auth.toml’
11:55:05.945 › (node:15251) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag--unhandled-rejections=strict
(see Command-line API | Node.js v21.2.0 Documentation). (rejection id: 3)
And the log of apt upgrade is below:
Start-Date: 2023-09-25 13:24:27
Commandline: apt-get upgrade
Requested-By: chengqi (1001)
Upgrade: ros-rolling-ament-cmake-flake8:amd64 (0.15.0-1jammy.20230428.185008, 0.15.2-1jammy.20230821.155737), ros-rolling-ament-cpplint:amd64 (0.15.0-1jammy.20230428.184434, 0.15.2-1jammy.20230821.161154), ros-rolling-mcap-vendor:amd64 (0.23.0-1jammy.20230429.125644, 0.24.0-1jammy.20230821.160536), ros-rolling-rosidl-typesupport-introspection-cpp:amd64 (4.1.0-1jammy.20230428.200317, 4.3.1-1jammy.20230821.172051), containerd.io:amd64 (1.6.21-1, 1.6.24-1), libignition-math6-dev:amd64 (6.14.0-1~jammy, 6.15.0-1~jammy), docker-compose-plugin:amd64 (2.18.1-1~ubuntu.22.04~jammy, 2.21.0-1~ubuntu.22.04~jammy), libxnvctrl0:amd64 (530.30.02-0ubuntu1, 535.104.05-0ubuntu1), ros-rolling-qt-gui-cpp:amd64 (2.5.0-1jammy.20230428.200756, 2.7.0-1jammy.20230821.172932), ros-rolling-ament-cppcheck:amd64 (0.15.0-1jammy.20230428.184003, 0.15.2-1jammy.20230821.154823), ros-rolling-rosidl-cmake:amd64 (4.1.0-1jammy.20230428.194058, 4.3.1-1jammy.20230821.163651), ros-rolling-orocos-kdl-vendor:amd64 (0.4.0-1jammy.20230428.193157, 0.4.1-1jammy.20230821.161626), ros-rolling-interactive-markers:amd64 (2.5.0-1jammy.20230428.231345, 2.5.1-1jammy.20230823.214845), ros-rolling-ros2lifecycle:amd64 (0.26.0-1jammy.20230428.233019, 0.29.0-1jammy.20230823.220008), ros-rolling-ament-package:amd64 (0.16.0-1jammy.20230428.183045, 0.16.2-1jammy.20230512.142902), docker-ce-cli:amd64 (5:24.0.2-1~ubuntu.22.04~jammy, 5:24.0.6-1~ubuntu.22.04~jammy), ros-rolling-ros-core:amd64 (0.10.0-2jammy.20230428.233438, 0.10.0-2jammy.20230823.220339), ros-rolling-ament-cmake-gen-version-h:amd64 (2.1.0-1jammy.20230428.184428, 2.2.2-1jammy.20230821.155300), ros-rolling-ament-index-cpp:amd64 (1.6.0-1jammy.20230428.193615, 1.7.0-1jammy.20230821.161543), ros-rolling-libcurl-vendor:amd64 (3.3.0-1jammy.20230428.191009, 3.3.1-1jammy.20230821.155929), ros-rolling-rviz-rendering:amd64 (12.5.0-2jammy.20230428.194900, 13.0.0-1jammy.20230821.184516), ros-rolling-joy:amd64 (3.1.0-3jammy.20230428.225241, 3.1.0-3jammy.20230823.213749), ros-rolling-geometry2:amd64 (0.32.0-1jammy.20230428.231110, 0.33.0-1jammy.20230823.221617), ros-rolling-rmw-fastrtps-cpp:amd64 (7.2.0-1jammy.20230428.204955, 7.4.0-1jammy.20230823.193039), ros-rolling-sqlite3-vendor:amd64 (0.23.0-1jammy.20230429.124858, 0.24.0-1jammy.20230821.160218), ros-rolling-action-tutorials-interfaces:amd64 (0.28.0-1jammy.20230428.203257, 0.31.0-1jammy.20230821.183304), ros-rolling-rosidl-runtime-c:amd64 (4.1.0-1jammy.20230428.194835, 4.3.1-1jammy.20230821.170821), ros-rolling-ament-uncrustify:amd64 (0.15.0-1jammy.20230428.192617, 0.15.2-1jammy.20230821.160459), ros-rolling-rosidl-typesupport-fastrtps-cpp:amd64 (3.1.0-1jammy.20230428.200834, 3.2.0-1jammy.20230821.172656), ros-rolling-rosbag2-transport:amd64 (0.23.0-1jammy.20230429.132513, 0.24.0-1jammy.20230823.224154), ros-rolling-rqt-py-common:amd64 (1.4.0-1jammy.20230428.213952, 1.4.1-1jammy.20230823.202605), ros-rolling-rosidl-typesupport-introspection-c:amd64 (4.1.0-1jammy.20230428.195221, 4.3.1-1jammy.20230821.171127), ros-rolling-statistics-msgs:amd64 (1.7.0-1jammy.20230428.203336, 1.7.0-1jammy.20230821.183242), ros-rolling-ros2bag:amd64 (0.23.0-1jammy.20230429.134448, 0.24.0-1jammy.20230823.230451), google-chrome-stable:amd64 (117.0.5938.88-1, 117.0.5938.92-1), ros-rolling-rcl:amd64 (6.1.0-1jammy.20230428.205940, 7.1.0-1jammy.20230823.195238), ros-rolling-rmw:amd64 (7.2.0-1jammy.20230428.200142, 7.2.1-1jammy.20230821.172015), ros-rolling-ros2cli:amd64 (0.26.0-1jammy.20230428.213931, 0.29.0-1jammy.20230823.202535), ros-rolling-ros2cli-common-extensions:amd64 (0.3.0-1jammy.20230428.233247, 0.3.0-1jammy.20230823.220217), ros-rolling-tf2:amd64 (0.32.0-1jammy.20230428.205503, 0.33.0-1jammy.20230821.185042), ros-rolling-tf2-kdl:amd64 (0.32.0-1jammy.20230428.230746, 0.33.0-1jammy.20230823.214450), ros-rolling-rosidl-dynamic-typesupport:amd64 (0.1.0-1jammy.20230428.195245, 0.1.1-1jammy.20230821.171128), ros-rolling-ament-cmake-export-definitions:amd64 (2.1.0-1jammy.20230428.185244, 2.2.2-1jammy.20230821.154802), ros-rolling-teleop-twist-keyboard:amd64 (2.3.2-4jammy.20230428.214007, 2.3.2-4jammy.20230823.202614), ros-rolling-rclpy:amd64 (4.2.0-1jammy.20230428.211911, 5.0.1-1jammy.20230823.201600), ros-rolling-ament-flake8:amd64 (0.15.0-1jammy.20230428.184104, 0.15.2-1jammy.20230821.154948), ros-rolling-desktop:amd64 (0.10.0-2jammy.20230429.135334, 0.10.0-2jammy.20230823.235201), ros-rolling-ament-cmake:amd64 (2.1.0-1jammy.20230428.190512, 2.2.2-1jammy.20230821.155505), ros-rolling-rosidl-core-generators:amd64 (0.2.0-1jammy.20230428.201717, 0.2.0-1jammy.20230821.181451), ros-rolling-tf2-ros:amd64 (0.32.0-1jammy.20230428.225254, 0.33.0-1jammy.20230823.213456), ros-rolling-tlsf:amd64 (0.9.0-1jammy.20230428.193427, 0.9.0-1jammy.20230821.163152), ros-rolling-visualization-msgs:amd64 (5.1.0-1jammy.20230428.210005, 5.2.0-1jammy.20230821.185834), ros-rolling-builtin-interfaces:amd64 (1.7.0-1jammy.20230428.201809, 1.7.0-1jammy.20230821.181709), ros-rolling-ros2pkg:amd64 (0.26.0-1jammy.20230428.214143, 0.29.0-1jammy.20230823.203004), libdebuginfod-common:amd64 (0.186-1build1, 0.188-1~bpo22.04.1), ros-rolling-quality-of-service-demo-cpp:amd64 (0.28.0-1jammy.20230428.222732, 0.31.0-1jammy.20230823.212912), ros-rolling-ros2run:amd64 (0.26.0-1jammy.20230428.214436, 0.29.0-1jammy.20230823.203254), ros-rolling-ament-lint-common:amd64 (0.15.0-1jammy.20230428.192835, 0.15.2-1jammy.20230821.161317), ros-rolling-tf2-eigen-kdl:amd64 (0.32.0-1jammy.20230428.205935, 0.33.0-1jammy.20230821.185324), ros-rolling-ament-cmake-auto:amd64 (2.1.0-1jammy.20230428.192603, 2.2.2-1jammy.20230821.155618), ros-rolling-dummy-robot-bringup:amd64 (0.28.0-1jammy.20230428.231525, 0.31.0-1jammy.20230823.215021), ros-rolling-gmock-vendor:amd64 (1.10.9005-1jammy.20230428.184155, 1.11.9000-1jammy.20230821.154838), ros-rolling-examples-rclpy-executors:amd64 (0.19.0-1jammy.20230428.212506, 0.19.1-1jammy.20230823.202227), ros-rolling-ament-cmake-uncrustify:amd64 (0.15.0-1jammy.20230428.192722, 0.15.2-1jammy.20230821.160611), libignition-math6:amd64 (6.14.0-1~jammy, 6.15.0-1~jammy), ros-rolling-pcl-conversions:amd64 (2.4.0-4jammy.20230428.225834, 2.4.0-4jammy.20230823.212159), ros-rolling-example-interfaces:amd64 (0.11.0-1jammy.20230428.203303, 0.12.0-1jammy.20230821.183252), ros-rolling-ros2node:amd64 (0.26.0-1jammy.20230428.214141, 0.29.0-1jammy.20230823.203000), ros-rolling-depthimage-to-laserscan:amd64 (2.5.0-4jammy.20230428.225158, 2.5.1-1jammy.20230823.213724), ros-rolling-rmw-implementation-cmake:amd64 (7.2.0-1jammy.20230428.193156, 7.2.1-1jammy.20230821.162420), ros-rolling-rviz-default-plugins:amd64 (12.5.0-2jammy.20230428.233933, 13.0.0-1jammy.20230823.222332), ros-rolling-image-transport:amd64 (4.3.0-1jammy.20230428.225430, 4.5.0-1jammy.20230823.212154), ros-rolling-yaml-cpp-vendor:amd64 (8.2.0-1jammy.20230428.192521, 8.3.0-1jammy.20230821.160343), ros-rolling-rqt-topic:amd64 (1.7.0-1jammy.20230428.214914, 1.7.0-1jammy.20230823.203311), ros-rolling-urdfdom:amd64 (3.1.1-1jammy.20230428.194003, 3.1.1-1jammy.20230821.161933), ros-rolling-lifecycle-msgs:amd64 (1.7.0-1jammy.20230428.203316, 1.7.0-1jammy.20230821.183300), ros-rolling-ros2topic:amd64 (0.26.0-1jammy.20230428.214239, 0.29.0-1jammy.20230823.203151), ros-rolling-qt-gui:amd64 (2.5.0-1jammy.20230428.193510, 2.7.0-1jammy.20230821.163712), ros-rolling-rclcpp:amd64 (21.1.0-1jammy.20230428.211241, 22.1.0-1jammy.20230823.200523), ros-rolling-rosidl-generator-py:amd64 (0.19.0-1jammy.20230428.201310, 0.20.0-1jammy.20230821.173547), ros-rolling-rosidl-parser:amd64 (4.1.0-1jammy.20230428.193841, 4.3.1-1jammy.20230821.162425), ros-rolling-rmw-fastrtps-shared-cpp:amd64 (7.2.0-1jammy.20230428.204108, 7.4.0-1jammy.20230823.192400), ros-rolling-rttest:amd64 (0.16.0-1jammy.20230428.193221, 0.16.0-1jammy.20230821.162601), ros-rolling-tf2-ros-py:amd64 (0.32.0-1jammy.20230428.213422, 0.33.0-1jammy.20230823.203106), ros-rolling-rqt-reconfigure:amd64 (1.4.0-1jammy.20230428.215041, 1.4.0-1jammy.20230823.203332), ros-rolling-rqt-graph:amd64 (1.5.0-1jammy.20230428.214927, 1.5.1-1jammy.20230823.203159), ros-rolling-rosbag2-storage-mcap:amd64 (0.23.0-1jammy.20230429.125846, 0.24.0-1jammy.20230823.221855), ros-rolling-tf2-tools:amd64 (0.32.0-1jammy.20230428.213739, 0.33.0-1jammy.20230823.203254), ros-rolling-keyboard-handler:amd64 (0.2.0-1jammy.20230428.193006, 0.2.0-1jammy.20230821.162343), ros-rolling-pcl-msgs:amd64 (1.0.0-7jammy.20230428.210051, 1.0.0-7jammy.20230821.190124), ros-rolling-examples-rclpy-minimal-action-client:amd64 (0.19.0-1jammy.20230428.212610, 0.19.1-1jammy.20230823.202207), ros-rolling-examples-rclpy-minimal-subscriber:amd64 (0.19.0-1jammy.20230428.212607, 0.19.1-1jammy.20230823.202326), ros-rolling-ament-cmake-pytest:amd64 (2.1.0-1jammy.20230428.184255, 2.2.2-1jammy.20230821.155212), ros-rolling-rqt-py-console:amd64 (1.2.0-1jammy.20230428.215017, 1.2.0-1jammy.20230823.203233), ros-rolling-ament-cmake-target-dependencies:amd64 (2.1.0-1jammy.20230428.184055, 2.2.2-1jammy.20230821.154852), ros-rolling-ament-cmake-python:amd64 (2.1.0-1jammy.20230428.183916, 2.2.2-1jammy.20230821.154757), ros-rolling-rosbag2-storage:amd64 (0.23.0-1jammy.20230429.125531, 0.24.0-1jammy.20230823.221347), libdebuginfod1:amd64 (0.186-1build1, 0.188-1~bpo22.04.1), ros-rolling-rqt-publisher:amd64 (1.7.0-1jammy.20230428.214937, 1.7.0-1jammy.20230823.203217), ros-rolling-rcl-logging-interface:amd64 (2.6.0-1jammy.20230428.195459, 2.6.0-1jammy.20230821.171430), ros-rolling-rosidl-typesupport-fastrtps-c:amd64 (3.1.0-1jammy.20230428.201042, 3.2.0-1jammy.20230821.172958), ros-rolling-ament-cmake-cppcheck:amd64 (0.15.0-1jammy.20230428.185011, 0.15.2-1jammy.20230821.155734), ros-rolling-ros2doctor:amd64 (0.26.0-1jammy.20230428.214141, 0.29.0-1jammy.20230823.203001), ros-rolling-ros2multicast:amd64 (0.26.0-1jammy.20230428.214246, 0.29.0-1jammy.20230823.202706), ros-rolling-rosidl-adapter:amd64 (4.1.0-1jammy.20230428.193653, 4.3.1-1jammy.20230821.161453), ros-rolling-libstatistics-collector:amd64 (1.6.0-1jammy.20230428.211025, 1.6.2-1jammy.20230823.200250), python3-catkin-pkg-modules:amd64 (0.5.2-1, 1.0.0-1), ros-rolling-stereo-msgs:amd64 (5.1.0-1jammy.20230428.210003, 5.2.0-1jammy.20230821.190200), ros-rolling-service-msgs:amd64 (1.7.0-1jammy.20230428.202235, 1.7.0-1jammy.20230821.182233), ros-rolling-urdf:amd64 (2.9.0-1jammy.20230428.200805, 2.9.0-1jammy.20230821.172508), ros-rolling-ament-cmake-export-dependencies:amd64 (2.1.0-1jammy.20230428.184045, 2.2.2-1jammy.20230821.154850), ros-rolling-rqt-gui-py:amd64 (1.4.0-1jammy.20230428.214253, 1.4.1-1jammy.20230823.202942), ros-rolling-rosidl-generator-cpp:amd64 (4.1.0-1jammy.20230428.195614, 4.3.1-1jammy.20230821.171435), ros-rolling-foonathan-memory-vendor:amd64 (1.3.0-3jammy.20230428.185251, 1.3.1-1jammy.20230821.160358), ros-rolling-shape-msgs:amd64 (5.1.0-1jammy.202
Can you give me any information?
A lot of thanks!
