Isaac Sim / Carter localization using Particle Filter
If I want to use IMU in order to improve the accuracy of localization by Particle filter, do I need to use DifferentialBaseWheelImuOdometry instead DifferentialBaseOdometry inside of the segway_odometry node? Thanks
Hi Seyed,
Please ask these questions in the SDK forum, you will get a better answer there.
We can answer simulation questions hee.
Thanks,
Liila
It is about the carter simulation.
Hi Seyed,
The segway_odometry node is a SDK node.
All Sim does is providing the ground truth pose the rest of the calculation is done in the SDK.
Thanks,
Liila
