isaac sim Connect to ROS drive robot error
How should I set up articulation_controller?
Hi @904798869,
I think this is best asked in the Omniverse->Isaac Sim category. I move your post over.
Hi @904798869
This link may help:
(…) You can either keep
usePath
checked and type in the path to the robot articulation in therobotPath
, or you can uncheckusePath
and then clickAdd Targets
near the top of the pane forinput:targetPrim
, and select the robot articulation in the pop up window.
Do you have a detailed example? My car has a four-wheel differential and I don’t know how to set it up,thanks
Hi @904798869 , for the articulation controller to work, you need to setup the robot as an articulation. Here is a link to an Isaac Sim tutorial which has more details.
Hope this helps!
