Isaac Sim Crash on Startup Windows 11
Isaac Sim Version
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 4070 TI
  • Driver Version: 552.44
Topic Description
Hi All,
I’ve been really struggling to get Isaac Sim to startup on Windows 11. Here’s what the compatibility checker looks like for my system:
I’ve tried all the recommended drivers: 537.58, 576.80, 552.44 (current), but still no luck. The app usually crashes sometime after “app ready.” Depending on the arguments, I can end up with different crashes. Running with “–clear-cache --clear-data --reset-user --/renderer/activeGpu=0” results in a crash while running the SetLightingMenuModeCommand. Here’s the crash logs for both Vulkan and DirectX:
isaac_sim_crask_directX.txt (32.4 KB)
isaac_sim_crask_vulkan.txt (30.8 KB)
If I just use -/renderer/activeGpu=0, then it will usually trip a BSOD and I’ve been unable to recover logs in that case. As part of all this, I’ve also done a clean install of windows. At this point I’m pretty lost, and I’d really appreciate any advice in what to try next.
Update: I am now able to successfully boot Isaac Sim after re-flashing the graphics card firmware. I guess it got corrupted at some point.
