Isaac sim Docker Installation Issue
I’m trying to install the NVIDIA Isaac-Sim Docker version.
I’ve already completed the authorization step. However, when I run the following command:
sudo docker pull nvcr.io/nvidia/isaac-sim:2023.1.1
I encounter the following error:
Error response from daemon: unauthorized: <html>
<head><title>401 Authorization Required</title></head>
<body>
<center><h1>401 Authorization Required</h1></center>
<hr><center>nginx/1.22.1</center>
</body>
</html>
Could you help me fix this problem?
Please refer to Container Installation — Omniverse IsaacSim latest documentation
I think you should login to nvcr.io, and you have to generate NGC API Key when you login to nvcr.io.
I’ve already completed all the previous steps in order, but I’m still encountering this error.
I found a solution mentioned in a forum, but it seems like it didn’t resolve the issue for me.
Is there any alternative solution to fix this problem?
I really appreciate your continued help.
Hi. It could be issues when running docker with sudo. What is your output after running sudo docker login nvcr.io?
Have you also tried re-generating your NGC API key?
when I attempted sudo docker login nvcr.io, nothing significant occured. The server returned a Login Succeeded message. However, when I tried to execute the following command, an error occured:
docker run --name isaac-sim --entrypoint bash -it --gpus all -e "ACCEPT_EULA=Y" --rm --network=host \
    -e "PRIVACY_CONSENT=Y" \
    -v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache:rw \
    -v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw \
    -v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw \
    -v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw \
    -v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw \
    -v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw \
    -v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw \
    -v ~/docker/isaac-sim/documents:/root/Documents:rw \
The error was
Unable to find image 'nvcr.io/nvidia/isaac-sim:2023.1.1' locally
docker: Error response from daemon: unauthorized: <html>
<body>
</body>
</html>.
See 'docker run --help'.
What should I do to resolve this issue?
Do you solve this problem? met it too
Have you tried re-generating the NGC API key?
