I am trying to get isaac sim working with jupyter notebook, but it seems like it errors with Cannot run the event loop while another loop is running
. I tried solving that with
import nest_asyncio
nest_asyncio.apply()
and the error went away, but then running the below code it gets stuck and never reaches the print(1)
import nest_asyncio
import os
from omni.isaac.python_app import OmniKitHelper
import carb
import omni
CONFIG = {
"experience": f'{os.environ["EXP_PATH"]}/omni.isaac.sim.python.kit',
"width": 1280,
"height": 720,
"sync_loads": True,
"headless": False,
"renderer": "RayTracedLighting",
kit = OmniKitHelper(config=CONFIG)
print(1)
Isaac sim opens, but the UI is messed up.
The last line in the console log is this:
2021-10-25 18:37:24 [Info] [omni.ui] Added dataSource connection for prefix '/'
Also, what is the currently intended way of connecting to a running headless instance of isaac sim via python API? All examples I can find are of starting the instance from python itself.
