Isaac Sim is not working in AWS cloud via NICE DCV
Isaac Sim Version
4.2.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: NVIDIA A10G
  • Driver Version: 550.54.15
AWS Instance
  • AMI : Nvidia Omniverse GPU
Hello, I am trying to working with Isaac Sim in the AWS cloud via Nice DCV. Bascially to work with Isaac Sim through a GUI interface on the cloud.
When I launch the Isaac Sim via omniverse launcher, I get this :
If I launch via CLI, I get “Segmentation fault (core dumped)”:
Full Error:
[Info] [carb] Logging to file: /home/ubuntu/.nvidia-omniverse/logs/Kit/Isaac-Sim/4.2/kit_20241105_182717.log
[0.257s] [ext: omni.blobkey-1.1.2] startup
[0.262s] [ext: omni.kit.async_engine-0.0.1] startup
[4.742s] [ext: omni.stats-1.0.1] startup
[4.744s] [ext: omni.datastore-0.0.0] startup
[4.810s] [ext: omni.client-1.2.0] startup
[4.848s] [ext: omni.ujitso.default-1.0.0] startup
[4.857s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[4.862s] [ext: omni.hsscclient-1.1.1] startup
[4.869s] [ext: omni.assets.plugins-0.0.0] startup
[4.871s] [ext: omni.gpu_foundation-0.0.0] startup
[4.881s] [ext: carb.windowing.plugins-1.0.0] startup
[4.896s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 550.54.15     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA A10G                      | Yes: 0 |     | 23028   MB | 10de      | 0          |
|     |                                  |        |     |            | 2237      | 45864731.. |
|     |                                  |        |     |            | 0         |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.5.0-1018-aws
| XServer Vendor: NICE S.r.l., XServer Version: 2688000
| Processor: AMD EPYC 7R32 | Cores: 4 | Logical: 8
| Total Memory (MB): 31714 | Free Memory: 29354
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2024-11-05 18:27:23 [5,676ms] [Warning] [gpu.foundation.plugin] ECC is enabled on physical device 0
[5.983s] [ext: omni.kit.pipapi-0.0.0] startup
[5.985s] [ext: omni.kit.pip_archive-0.0.0] startup
[5.985s] [ext: omni.pip.compute-1.4.0] startup
[5.986s] [ext: omni.materialx.libs-1.0.4] startup
[5.998s] [ext: omni.kit.telemetry-0.5.0] startup
[6.062s] [ext: omni.pip.cloud-1.1.3] startup
[6.072s] [ext: omni.isaac.core_archive-2.3.0] startup
[6.074s] [ext: omni.usd.config-1.0.4] startup
[6.080s] [ext: omni.gpucompute.plugins-0.0.0] startup
[6.088s] [ext: omni.usd.libs-1.0.1] startup
[6.213s] [ext: omni.iray.libs-0.0.0] startup
[6.388s] [ext: omni.mdl.neuraylib-0.2.8] startup
[6.398s] [ext: omni.mdl-55.0.1] startup
[6.464s] [ext: omni.kit.usd.mdl-1.0.1] startup
[6.896s] [ext: omni.kit.loop-isaac-1.2.0] startup
[6.897s] [ext: omni.kit.test-1.1.0] startup
[7.069s] [ext: omni.isaac.ml_archive-2.0.1] startup
[7.070s] [ext: omni.appwindow-1.1.8] startup
[7.078s] [ext: omni.kit.renderer.core-1.0.2] startup
2024-11-05 18:27:24 [7,097ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2024-11-05 18:27:24 [7,097ms] [Error] [carb.graphics-vulkan.plugin] vkCreateSwapchainKHR failed.
2024-11-05 18:27:24 [7,097ms] [Error] [carb.graphics-vulkan.plugin] Failed to create a swapchain.
2024-11-05 18:27:24 [7,097ms] [Error] [omni.kit.renderer.plugin] createSwapchain failed. Width: 1440, height: 830, Format: 9
2024-11-05 18:27:24 [7,098ms] [Error] [omni.kit.renderer.plugin] Failed to initialize graphics environment.
[7.180s] [ext: omni.kit.renderer.capture-0.0.0] startup
[7.185s] [ext: omni.kit.renderer.imgui-1.0.1] startup
2024-11-05 18:27:24 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-11-05 18:27:25 [26ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip' for upload.
2024-11-05 18:27:25 [176ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp' with 10 retries remaining.
2024-11-05 18:27:25 [178ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.toml' with 10 retries remaining.
'crashreport.gui' exited with code 1272024-11-05 18:27:25 [197ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip'
2024-11-05 18:27:25 [199ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:'/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip' svr:'https://services.nvidia.com/submit'
2024-11-05 18:27:25 [200ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-11-05 18:27:25 [202ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'BuildGitlabJobID' = '110521993'
2024-11-05 18:27:25 [203ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'CarbSdkVersion' = '173.5+release.6562.3a7379eb.gl'
2024-11-05 18:27:25 [205ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'CrashTime' = 'Tue Nov  5 18:27:24 2024 GMT'
2024-11-05 18:27:25 [206ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'DriverShaderCacheWrapper' = 'disabled'
2024-11-05 18:27:25 [207ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'DumpId' = '09d9750c-314c-409b-d2e1a18b-0fdde60f'
2024-11-05 18:27:25 [209ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'LastUploadStatus' = ''
2024-11-05 18:27:25 [210ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'ProductName' = 'OmniverseKit'
2024-11-05 18:27:25 [212ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'PythonTracebackStatus' = ''py-spy' successfully wrote info to '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.py.txt''
2024-11-05 18:27:25 [213ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'RetryCount' = '0'
2024-11-05 18:27:25 [215ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'StartupTime' = '1730831237'
2024-11-05 18:27:25 [216ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UploadSuccessful' = '0'
2024-11-05 18:27:25 [218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UptimeSeconds' = '8'
2024-11-05 18:27:25 [219ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UserStory' = ''
2024-11-05 18:27:25 [220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UserStoryStatus' = ''crashreport.gui' exited with code 127'
2024-11-05 18:27:25 [224ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'Version' = '106.1.0+release.140981.10a4b5c0.gl'
2024-11-05 18:27:25 [225ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_enabled' = '1'
2024-11-05 18:27:25 [227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_flags' = '3'
2024-11-05 18:27:25 [228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_status' = 'auto-enabled'
2024-11-05 18:27:25 [230ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_version' = '2024.1'
2024-11-05 18:27:25 [231ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appName' = 'Isaac-Sim'
2024-11-05 18:27:25 [233ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appState' = 'startup'
2024-11-05 18:27:25 [234ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appVersion' = '4.2.0'
2024-11-05 18:27:25 [235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'autoloadExts' = ''
2024-11-05 18:27:25 [237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildBranch' = 'release'
2024-11-05 18:27:25 [239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildCi' = 'gl'
2024-11-05 18:27:25 [240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildConfig' = 'release'
2024-11-05 18:27:25 [241ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabJobName' = 'kit-build-release-linux-x86_64'
2024-11-05 18:27:25 [243ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabJobStage' = 'kit-build'
2024-11-05 18:27:25 [244ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabPipelineID' = '18272252'
2024-11-05 18:27:25 [246ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildHash' = '10a4b5c0'
2024-11-05 18:27:25 [248ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildMajor' = '106'
2024-11-05 18:27:25 [249ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildMinor' = '1'
2024-11-05 18:27:25 [251ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildNumber' = '140981'
2024-11-05 18:27:25 [252ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildPatch' = '0'
2024-11-05 18:27:25 [254ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildVersion' = '106.1.0'
2024-11-05 18:27:25 [256ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'commandLine' = './kit/kit ./apps/omni.isaac.sim.kit --ext-folder ./apps'
2024-11-05 18:27:25 [258ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'cpuId' = 'Intel64 Family 23 Model 49 Stepping 0'
2024-11-05 18:27:25 [259ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'cpuName' = 'AMD EPYC 7R32'
2024-11-05 18:27:25 [261ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'cpuVendor' = 'AuthenticAMD'
2024-11-05 18:27:25 [262ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'desktopOrigin' = '(0, 0)'
2024-11-05 18:27:25 [264ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'desktopSize' = '2650x920'
2024-11-05 18:27:25 [265ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'displayCount' = '2'
2024-11-05 18:27:25 [266ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'displayRes_0' = '1848x920x32bit@60Hz'
2024-11-05 18:27:25 [268ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'displayRes_1' = '800x600x32bit@60Hz'
2024-11-05 18:27:25 [269ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'email' = ''
2024-11-05 18:27:25 [270ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'environmentName' = 'Individual'
2024-11-05 18:27:25 [272ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'experience' = 'Isaac Sim'
2024-11-05 18:27:25 [273ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'externalBuild' = '1'
2024-11-05 18:27:25 [275ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'gpuDriver_0' = '550.54'
2024-11-05 18:27:25 [276ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'gpuVRAM_0' = '24146608128'
2024-11-05 18:27:25 [278ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'gpu_0' = 'NVIDIA A10G'
2024-11-05 18:27:25 [279ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'kitRendererDriverVersion' = '550.54'
2024-11-05 18:27:25 [280ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'memoryStats' = '(avail/total) RAM: 27.2254/30.9708GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB'
2024-11-05 18:27:25 [282ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'nvidia-smi' = '
==============NVSMI LOG==============
Timestamp                                 : Tue Nov  5 18:27:22 2024
Driver Version                            : 550.54.15
CUDA Version                              : 12.4
Attached GPUs                             : 1
GPU 00000000:00:1E.0
    Product Name                          : NVIDIA A10G
    Product Brand                         : NVIDIA
    Product Architecture                  : Ampere
    Display Mode                          : Enabled
    Display Active                        : Disabled
    Persistence Mode                      : Enabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : 1323822060700
    GPU UUID                              : GPU-45864731-fc8c-7b87-7397-63ed2d7f18de
    Minor Number                          : 0
    VBIOS Version                         : 94.02.75.00.01
    MultiGPU Board                        : No
    Board ID                              : 0x1e
    Board Part Number                     : 900-2G133-A840-000
    GPU Part Number                       : 2237-892-A1
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : G133.0210.00.04
        OEM Object                        : 2.0
        ECC Object                        : 6.16
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Virtualization Mode
        Virtualization Mode               : Pass-Through
        Host VGPU Mode                    : N/A
        vGPU Heterogeneous Mode           : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : N/A
    GSP Firmware Version                  : 550.54.15
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x00
        Device                            : 0x1E
        Domain                            : 0x0000
        Base Classcode                    : 0x3
        Sub Classcode                     : 0x2
        Device Id                         : 0x223710DE
        Bus Id                            : 00000000:00:1E.0
        Sub System Id                     : 0x152F10DE
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 4
                Device Current            : 4
                Device Max                : 4
                Host Max                  : N/A
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 9 KB/s
        Rx Throughput                     : 2 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : 0 %
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Not Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 23028 MiB
        Reserved                          : 525 MiB
        Used                              : 578 MiB
        Free                              : 21924 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 6 MiB
        Free                              : 32762 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 0 %
        Memory                            : 0 %
        Encoder                           : 1 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 2
        Average FPS                       : 3
        Average Latency                   : 626
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
            SRAM Correctable              : 0
            SRAM Uncorrectable Parity     : 0
            SRAM Uncorrectable SEC-DED    : 0
            DRAM Correctable              : 0
            DRAM Uncorrectable            : 0
        Aggregate
            SRAM Threshold Exceeded       : No
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                       : 0
            SRAM SM                       : 0
            SRAM Microcontroller          : 0
            SRAM PCIE                     : 0
            SRAM Other                    : 0
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows
        Correctable Error                 : 0
        Uncorrectable Error               : 0
        Pending                           : No
        Remapping Failure Occurred        : No
        Bank Remap Availability Histogram
            Max                           : 192 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
        GPU Current Temp                  : 25 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 98 C
        GPU Slowdown Temp                 : 95 C
        GPU Max Operating Temp            : 88 C
        GPU Target Temperature            : N/A
        Memory Current Temp               : N/A
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Power Draw                        : 58.38 W
        Current Power Limit               : 300.00 W
        Requested Power Limit             : 300.00 W
        Default Power Limit               : 300.00 W
        Min Power Limit                   : 100.00 W
        Max Power Limit                   : 300.00 W
    GPU Memory Power Readings
        Power Draw                        : N/A
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 1710 MHz
        SM                                : 1710 MHz
        Memory                            : 6250 MHz
        Video                             : 1500 MHz
    Applications Clocks
        Graphics                          : 1710 MHz
        Memory                            : 6251 MHz
    Default Applications Clocks
        Graphics                          : 1710 MHz
        Memory                            : 6251 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1710 MHz
        SM                                : 1710 MHz
        Memory                            : 6251 MHz
        Video                             : 1500 MHz
    Max Customer Boost Clocks
        Graphics                          : 1710 MHz
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : 962.500 mV
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 1535
            Type                          : C
            Used GPU Memory               : 563 MiB
2024-11-05 18:27:25 [283ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osDistro' = 'ubuntu'
2024-11-05 18:27:25 [285ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osName' = '22.04.5 LTS (Jammy Jellyfish)'
2024-11-05 18:27:25 [287ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'osVersion' = '22.04.5'
2024-11-05 18:27:25 [289ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'portableMode' = '0'
2024-11-05 18:27:25 [291ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'primaryDisplayRes' = '1848x920x32bit@60Hz'
2024-11-05 18:27:25 [292ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'runEnvironment' = 'Individual'
2024-11-05 18:27:25 [294ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'runningInContainer' = '0'
2024-11-05 18:27:25 [295ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_debugSymbols' = '0'
2024-11-05 18:27:25 [296ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIncludeOverrides' = '0'
2024-11-05 18:27:25 [298ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIntermediates' = '0'
2024-11-05 18:27:25 [299ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_obfuscateCode' = '1'
2024-11-05 18:27:25 [300ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_optimizationLevel' = '1'
2024-11-05 18:27:25 [302ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'systemInfo' = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 2237      | 45864731.. |
|     |                                  |        |     |            | 0         |            |
2024-11-05 18:27:25 [303ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'telemetrySessionId' = '14352199190293090517'
2024-11-05 18:27:25 [305ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'terminatedByAbort' = '0'
2024-11-05 18:27:25 [306ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'userId' = 'default'
2024-11-05 18:27:25 [308ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'workingDirectory' = '/home/<username>/.local/share/ov/pkg/isaac-sim-4.2.0'
2024-11-05 18:27:25 [309ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-11-05 18:27:25 [311ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'upload_file_minidump' = '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip'
2024-11-05 18:27:26 [1,668ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip', code:200, response:
2024-11-05 18:27:26 [1,669ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]     9ba151f0-9ba3-11ef-a45d-02c180df6437
2024-11-05 18:27:26 [1,671ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save)
2024-11-05 18:27:26 [1,672ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip' with 10 retries remaining.
2024-11-05 18:27:26 [1,674ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip.toml'
2024-11-05 18:27:26 [1,676ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.dmp.zip.toml' with 10 retries remaining.
2024-11-05 18:27:26 [1,677ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     dump file size is 0 bytes, file is readable.
2024-11-05 18:27:26 [1,679ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 2912 thread 2912
2024-11-05 18:27:26 [1,681ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2024-11-05 18:27:26 [1,683ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  BuildGitlabJobID = '110521993'
2024-11-05 18:27:26 [1,685ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '173.5+release.6562.3a7379eb.gl'
2024-11-05 18:27:26 [1,687ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Tue Nov  5 18:27:24 2024 GMT'
2024-11-05 18:27:26 [1,688ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2024-11-05 18:27:26 [1,690ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = '09d9750c-314c-409b-d2e1a18b-0fdde60f'
2024-11-05 18:27:26 [1,691ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  LastUploadStatus = '200'
2024-11-05 18:27:26 [1,693ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2024-11-05 18:27:26 [1,694ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim/4.2/09d9750c-314c-409b-d2e1a18b-0fdde60f.py.txt''
2024-11-05 18:27:26 [1,696ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  RetryCount = '0'
2024-11-05 18:27:26 [1,697ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  StartupTime = '1730831237'
2024-11-05 18:27:26 [1,699ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UploadSuccessful = '0'
2024-11-05 18:27:26 [1,700ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UptimeSeconds = '8'
2024-11-05 18:27:26 [1,702ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStory = ''
2024-11-05 18:27:26 [1,703ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-11-05 18:27:26 [1,705ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  Version = '106.1.0+release.140981.10a4b5c0.gl'
2024-11-05 18:27:26 [1,706ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_enabled = '1'
2024-11-05 18:27:26 [1,708ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_flags = '3'
2024-11-05 18:27:26 [1,709ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_status = 'auto-enabled'
2024-11-05 18:27:26 [1,710ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_version = '2024.1'
2024-11-05 18:27:26 [1,712ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appName = 'Isaac-Sim'
2024-11-05 18:27:26 [1,713ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appState = 'startup'
2024-11-05 18:27:26 [1,716ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appVersion = '4.2.0'
2024-11-05 18:27:26 [1,718ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  autoloadExts = ''
2024-11-05 18:27:26 [1,719ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildBranch = 'release'
2024-11-05 18:27:26 [1,721ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildCi = 'gl'
2024-11-05 18:27:26 [1,722ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildConfig = 'release'
2024-11-05 18:27:26 [1,724ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobName = 'kit-build-release-linux-x86_64'
2024-11-05 18:27:26 [1,726ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobStage = 'kit-build'
2024-11-05 18:27:26 [1,727ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabPipelineID = '18272252'
2024-11-05 18:27:26 [1,729ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildHash = '10a4b5c0'
2024-11-05 18:27:26 [1,730ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMajor = '106'
2024-11-05 18:27:26 [1,732ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMinor = '1'
2024-11-05 18:27:26 [1,733ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildNumber = '140981'
2024-11-05 18:27:26 [1,735ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildPatch = '0'
2024-11-05 18:27:26 [1,737ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildVersion = '106.1.0'
2024-11-05 18:27:26 [1,738ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  commandLine = './kit/kit ./apps/omni.isaac.sim.kit --ext-folder ./apps'
2024-11-05 18:27:26 [1,740ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuId = 'Intel64 Family 23 Model 49 Stepping 0'
2024-11-05 18:27:26 [1,741ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuName = 'AMD EPYC 7R32'
2024-11-05 18:27:26 [1,743ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  cpuVendor = 'AuthenticAMD'
2024-11-05 18:27:26 [1,744ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  desktopOrigin = '(0, 0)'
2024-11-05 18:27:26 [1,746ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  desktopSize = '2650x920'
2024-11-05 18:27:26 [1,747ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  displayCount = '2'
2024-11-05 18:27:26 [1,750ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  displayRes_0 = '1848x920x32bit@60Hz'
2024-11-05 18:27:26 [1,752ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  displayRes_1 = '800x600x32bit@60Hz'
2024-11-05 18:27:26 [1,753ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  email = ''
2024-11-05 18:27:26 [1,755ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  environmentName = 'Individual'
2024-11-05 18:27:26 [1,756ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  experience = 'Isaac Sim'
2024-11-05 18:27:26 [1,757ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  externalBuild = '1'
2024-11-05 18:27:26 [1,759ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuDriver_0 = '550.54'
2024-11-05 18:27:26 [1,760ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpuVRAM_0 = '24146608128'
2024-11-05 18:27:26 [1,762ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  gpu_0 = 'NVIDIA A10G'
2024-11-05 18:27:26 [1,763ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  kitRendererDriverVersion = '550.54'
2024-11-05 18:27:26 [1,765ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  memoryStats = '(avail/total) RAM: 27.2254/30.9708GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB'
2024-11-05 18:27:26 [1,766ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  nvidia-smi = '
CUDA Version                              : 12.4
Attached GPUs                             : 1
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Minor Number                          : 0
    MultiGPU Board                        : No
    Board ID                              : 0x1e
    Module ID                             : 1
    Inforom Version
        OEM Object                        : 2.0
        ECC Object                        : 6.16
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU C2C Mode                          : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x00
        Device                            : 0x1E
        Domain                            : 0x0000
        Sub Classcode                     : 0x2
        GPU Link Info
            PCIe Generation
                Max                       : 4
                Current                   : 4
                Device Current            : 4
                Device Max                : 4
                Host Max                  : N/A
            Link Width
                Max                       : 16x
                Current                   : 8x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
    Fan Speed                             : 0 %
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 23028 MiB
        Reserved                          : 525 MiB
        Used                              : 578 MiB
        Free                              : 21924 MiB
    BAR1 Memory Usage
        Total                             : 32768 MiB
        Used                              : 6 MiB
        Free                              : 32762 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 0 %
        Memory                            : 0 %
        Encoder                           : 1 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 2
        Average FPS                       : 3
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : Enabled
        Pending                           : Enabled
    ECC Errors
        Volatile
        Aggregate
            SRAM L2                       : 0
            SRAM SM                       : 0
            SRAM PCIE                     : 0
            SRAM Other                    : 0
    Retired Pages
    Remapped Rows
        Pending                           : No
            Max                           : 192 bank(s)
            High                          : 0 bank(s)
            Partial                       : 0 bank(s)
            Low                           : 0 bank(s)
            None                          : 0 bank(s)
    Temperature
    GPU Power Readings
        Power Draw                        : N/A
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1710 MHz
        SM                                : 1710 MHz
        Memory                            : 6250 MHz
        Video                             : 1500 MHz
    Applications Clocks
        Graphics                          : 1710 MHz
        Memory                            : 6251 MHz
        Graphics                          : 1710 MHz
        Memory                            : 6251 MHz
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 1710 MHz
        SM                                : 1710 MHz
        Memory                            : 6251 MHz
        Video                             : 1500 MHz
        Graphics                          : 1710 MHz
    Clock Policy
        Auto Boost                        : N/A
    Voltage
    Fabric
        State                             : N/A
        Status                            : N/A
        CliqueId                          : N/A
        ClusterUUID                       : N/A
        Health
            Bandwidth                     : N/A
    Processes
        Process ID                        : 1535
            Type                          : C
2024-11-05 18:27:26 [1,768ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osDistro = 'ubuntu'
2024-11-05 18:27:26 [1,769ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osName = '22.04.5 LTS (Jammy Jellyfish)'
2024-11-05 18:27:26 [1,771ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  osVersion = '22.04.5'
2024-11-05 18:27:26 [1,772ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  portableMode = '0'
2024-11-05 18:27:26 [1,774ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  primaryDisplayRes = '1848x920x32bit@60Hz'
2024-11-05 18:27:26 [1,776ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  runEnvironment = 'Individual'
2024-11-05 18:27:26 [1,777ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  runningInContainer = '0'
2024-11-05 18:27:26 [1,779ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_debugSymbols = '0'
2024-11-05 18:27:26 [1,780ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIncludeOverrides = '0'
2024-11-05 18:27:26 [1,782ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIntermediates = '0'
2024-11-05 18:27:26 [1,785ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_obfuscateCode = '1'
2024-11-05 18:27:26 [1,786ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_optimizationLevel = '1'
2024-11-05 18:27:26 [1,788ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  systemInfo = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 2237      | 45864731.. |
|     |                                  |        |     |            | 0         |            |
2024-11-05 18:27:26 [1,789ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  telemetrySessionId = '14352199190293090517'
2024-11-05 18:27:26 [1,791ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  terminatedByAbort = '0'
2024-11-05 18:27:26 [1,792ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2024-11-05 18:27:26 [1,794ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/.local/share/ov/pkg/isaac-sim-4.2.0'
2024-11-05 18:27:26 [1,795ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 2912 backtrace follows:
2024-11-05 18:27:26 [1,870ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2024-11-05 18:27:26 [1,875ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libomni.kit.imgui_renderer.plugin.so!std::string::resize(unsigned long, char)+0x2aa (??:?)
2024-11-05 18:27:26 [1,878ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libomni.kit.imgui_renderer.plugin.so!std::string::resize(unsigned long, char)+0x393 (??:?)
2024-11-05 18:27:26 [1,881ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libomni.kit.imgui_renderer.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)+0x4018 (??:?)
2024-11-05 18:27:26 [1,885ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libomni.kit.imgui_renderer.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)+0x5695 (??:?)
2024-11-05 18:27:26 [1,888ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x167d (??:?)
2024-11-05 18:27:26 [1,891ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x1966 (??:?)
2024-11-05 18:27:26 [1,897ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libomni.kit.renderer.init.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_get_insert_hint_unique_pos(std::_Rb_tree_const_iterator<std::string>, std::string const&)+0x767f (??:?)
2024-11-05 18:27:26 [1,900ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x405d (??:?)
2024-11-05 18:27:26 [1,903ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x200b (??:?)
2024-11-05 18:27:26 [1,908ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.kit.imgui_renderer.ext.plugin.so!std::string::find(char, unsigned long) const+0x1870 (??:?)
2024-11-05 18:27:26 [1,917ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.ext.plugin.so!std::string& std::vector<std::string, std::allocator<std::string> >::emplace_back<char const*&>(char const*&)+0x4c69 (??:?)
2024-11-05 18:27:26 [1,925ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.ext.plugin.so!std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&, unsigned long, unsigned long)+0x54af (??:?)
2024-11-05 18:27:26 [1,934ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.ext.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)+0x10480 (??:?)
2024-11-05 18:27:26 [1,943ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.ext.plugin.so!carbOnPluginPreStartup+0x533 (??:?)
2024-11-05 18:27:26 [1,951ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.ext.plugin.so!carbOnPluginPreStartup+0xc99c (??:?)
2024-11-05 18:27:26 [1,959ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.ext.plugin.so!carbOnPluginPreStartup+0xda03 (??:?)
2024-11-05 18:27:26 [1,966ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0x93f3 (??:?)
2024-11-05 18:27:26 [1,974ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0x9dec (??:?)
2024-11-05 18:27:26 [1,982ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.kit.app.plugin.so!_init+0x6cc7 (??:0)
2024-11-05 18:27:26 [1,985ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: kit!_init+0x6c3 (??:0)
2024-11-05 18:27:27 [2,041ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2024-11-05 18:27:27 [2,097ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2024-11-05 18:27:27 [2,101ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: kit!_start+0x29 (??:?)
For some reason, the isaac sim is not detecting the GPU, any suggestion will really helpful. Thanks !!!
Please check if I started isaac-sim and got segmentation fault is helpful.
Could you verify if it passes the Isaac Sim compatibility checker?
Thanks for the responses, I tried the link you shared, it may work for the local system but I am trying to launch it in cloud via NICE DCV(a GUI to access AWS EC2 instances), so that did not work.
Also when I launch the ISAAC SIM COMPATIBILITY CHECKER , it also crashed and displays the crashreporter GUI as it was with Isaac Sim.
Could you try installing and running other apps from the Launcher, such as “USD Composer” or “Kit” SDK?
No, that is not even displaying the crashreporter GUI. This is not working. I’m now wondering if it is even possible to use Isaac Sim via a cloud GUI. If it is then it could be really helpful to use ROS2 and Rviz2 in parallel with Isaac Sim in a much more user-friendly way.
As stated in this note on AWS Deployment, I guess this is why it doesn’t work:
The Isaac Sim container supports running our Python apps and standalone examples in headless mode only.
