Hi all,
In our Python application, we utilize containerized Isaac Sim instances to generate synthetic image data. However, we are encountering issues with logging, as Isaac Sim produces an overwhelming number of messages. Here’s the situation:
Given this context, I have two questions:
Are there alternative methods to change the log level without modifying the apps/omni.isaac.sim.python.kit
file? This method is not ideal for a containerized solution.
Is there a way to completely eliminate the Isaac startup logs?
Thanks in advance!
Marvin
The messages we are able to disable via the omni.isaac.sim.python.kit file are all warnings. This is great but I would love to do this via the flags or carb settings.
The logs which are still remaining are the standard Isaac Sim startup logs. As we start multiple Isaac Sim instances in our approach, this is flooding our terminal.
[2.563s] [ext: omni.convexdecomposition-106.1.9] startup
[2.568s] [ext: omni.graph.nodes-1.146.1] startup
[2.579s] [ext: omni.physx.cooking-106.1.9] startup
[2.592s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[2.597s] [ext: omni.physx-106.1.9] startup
[2.611s] [ext: omni.kit.stage_templates-1.2.5] startup
[2.617s] [ext: omni.isaac.version-1.1.0] startup
[2.620s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[2.624s] [ext: omni.isaac.nucleus-0.3.1] startup
[2.627s] [ext: omni.physics.tensors-106.1.9] startup
[2.637s] [ext: omni.physx.stageupdate-106.1.9] startup
[2.641s] [ext: omni.graph.action_core-1.1.6] startup
[2.646s] [ext: omni.warp.core-1.2.1] startup
[2.747s] [ext: omni.physx.tensors-106.1.9] startup
[2.753s] [ext: omni.graph.scriptnode-1.20.1] startup
[2.754s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[2.761s] [ext: omni.graph.action_nodes-1.24.0] startup
[2.771s] [ext: omni.kit.ui_test-1.3.2] startup
[2.780s] [ext: omni.isaac.core-3.19.5] startup
[3.200s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[3.213s] [ext: omni.graph.action-1.102.1] startup
[3.217s] [ext: omni.kit.window.cursor-1.1.2] startup
[3.224s] [ext: omni.isaac.ui-0.16.0] startup
[3.256s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[3.296s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[3.300s] [ext: omni.syntheticdata-0.6.9] startup
[3.331s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[3.337s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[3.343s] [ext: omni.kit.numpy.common-0.1.2] startup
[3.346s] [ext: omni.warp-1.2.1] startup
[3.359s] [ext: omni.kit.window.material_graph-1.8.18] startup
[3.469s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[3.501s] [ext: omni.replicator.core-1.11.20] startup
Warp 1.2.1 initialized:
CUDA Toolkit 11.8, Driver 12.2
Devices:
“cpu” : “x86_64”
“cuda:0” : “NVIDIA A40-48Q” (48 GiB, sm_86, mempool not supported)
Kernel cache:
/root/.cache/warp/1.2.1
Warp UserWarning: Support for CUDA memory pools was not detected on devices [‘cuda:0’]. This prevents memory allocations in CUDA graphs and may result in poor performance. Is the UVM driver enabled?
[3.729s] [ext: omni.isaac.lula-3.0.1] startup
[3.744s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[3.753s] [ext: omni.isaac.core_nodes-1.16.3] startup
[3.786s] [ext: omni.isaac.motion_generation-7.1.0] startup
[3.814s] [ext: omni.isaac.manipulators-2.1.0] startup
[3.819s] [ext: omni.isaac.franka-0.4.1] startup
[3.824s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[3.842s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[3.850s] [ext: omni.isaac.cortex-0.3.9] startup
[3.852s] [ext: omni.graph.window.core-1.113.1] startup
[3.892s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[3.918s] [ext: omni.isaac.cortex.sample_behaviors-1.0.6] startup
[3.921s] [ext: omni.graph.window.generic-1.26.0] startup
[3.955s] [ext: omni.isaac.menu-0.7.3] startup
[3.970s] [ext: omni.kit.widget.live-2.1.8] startup
[3.985s] [ext: omni.kit.actions.window-1.1.1] startup
[4.025s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[4.216s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[4.244s] [ext: omni.kit.ui.actions-1.0.2] startup
[4.247s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[4.251s] [ext: omni.kit.menu.common-1.1.7] startup
[4.257s] [ext: omni.kit.selection-0.1.4] startup
[4.261s] [ext: omni.isaac.kit-1.13.2] startup
[4.262s] [ext: omni.isaac.block_world-1.0.0] startup
[4.275s] [ext: omni.kit.window.stage-2.5.10] startup
[4.299s] [ext: omni.isaac.debug_draw-1.1.0] startup
[4.309s] [ext: omni.kit.menu.edit-1.1.24] startup
[4.323s] [ext: omni.kit.menu.file-1.1.14] startup
[4.327s] [ext: omni.kit.profiler.window-2.2.3] startup
[4.362s] [ext: omni.kit.menu.stage-1.2.5] startup
[4.366s] [ext: omni.isaac.occupancy_map-1.0.3] startup
[4.389s] [ext: omni.importer.mjcf-1.1.1] startup
[4.404s] [ext: omni.graph.window.action-1.28.0] startup
[4.417s] [ext: omni.kit.property.camera-1.0.8] startup
[4.426s] [ext: omni.kit.property.light-1.0.10] startup
[4.430s] [ext: omni.kit.property.geometry-1.3.1] startup
[4.437s] [ext: omni.hydra.scene_api-0.1.2] startup
[4.444s] [ext: omni.kit.property.audio-1.0.14] startup
[4.457s] [ext: omni.kit.property.render-1.1.2] startup
[4.459s] [ext: omni.kit.property.transform-1.5.9] startup
[4.464s] [ext: omni.kit.property.material-1.10.8] startup
[4.472s] [ext: omni.kit.widget.layers-1.8.0] startup
[4.490s] [ext: omni.kit.property.isaac-0.2.3] startup
[4.497s] [ext: omni.kit.property.bundle-1.3.1] startup
[4.498s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[4.513s] [ext: omni.kit.property.layer-1.1.8] startup
[4.517s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[4.519s] [ext: omni.isaac.scene_blox-0.1.2] startup
[4.523s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[4.526s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[4.528s] [ext: omni.kit.viewport.actions-106.0.2] startup
[4.534s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
[4.541s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[4.549s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[4.553s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[4.557s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[4.569s] [ext: omni.sensors.tiled-0.0.6] startup
[4.572s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[4.578s] [ext: omni.isaac.range_sensor-3.1.2] startup
[4.596s] [ext: omni.usdphysics.ui-106.1.9] startup
[4.629s] [ext: omni.physx.commands-106.1.9] startup
[4.634s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[4.644s] [ext: omni.isaac.sensor-12.9.1] startup
[4.739s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[4.745s] [ext: omni.physx.ui-106.1.9] startup
[4.811s] [ext: omni.isaac.quadruped-2.0.1] startup
[4.824s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[4.835s] [ext: omni.physx.demos-106.1.9] startup
[4.867s] [ext: omni.kit.property.physx-106.1.9] startup
[4.974s] [ext: omni.kit.widget.calendar-1.0.8] startup
[4.978s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[4.989s] [ext: omni.fabric.commands-1.1.5] startup
[4.993s] [ext: omni.physx.vehicle-106.1.9] startup
[5.018s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[5.035s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[5.040s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[5.041s] [ext: omni.kit.widget.timeline-105.0.1] startup
[5.048s] [ext: omni.kit.window.commands-0.2.6] startup
[5.050s] [ext: omni.physx.camera-106.1.9] startup
[5.065s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[5.075s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[5.082s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[5.083s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[5.085s] [ext: omni.kit.window.toolbar-1.6.1] startup
[5.089s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[5.092s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[5.097s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[5.109s] [ext: omni.physx.cct-106.1.9] startup
[5.126s] [ext: omni.physx.graph-106.1.9] startup
[5.161s] [ext: omni.physx.supportui-106.1.9] startup
[5.190s] [ext: omni.physx.telemetry-106.1.9] startup
[5.198s] [ext: omni.graph.ui_nodes-1.26.0] startup
[5.206s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[5.207s] [ext: omni.isaac.universal_robots-0.3.5] startup
[5.213s] [ext: omni.kit.window.console-0.2.13] startup
[5.229s] [ext: omni.kit.window.script_editor-1.7.6] startup
[5.237s] [ext: omni.kit.menu.create-1.0.16] startup
[5.246s] [ext: omni.graph.bundle.action-2.4.1] startup
[5.249s] [ext: omni.physx.bundle-106.1.9] startup
[5.251s] [ext: omni.rtx.window.settings-0.6.17] startup
[5.259s] [ext: omni.kit.window.status_bar-0.1.7] startup
[5.267s] [ext: omni.kit.window.title-1.1.5] startup
[5.269s] [ext: omni.replicator.isaac-1.15.2] startup
[5.316s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[5.330s] [ext: omni.rtx.settings.core-0.6.3] startup
[5.354s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[5.370s] [ext: semantics.schema.editor-0.3.8] startup
[5.382s] [ext: semantics.schema.property-1.0.4] startup
[5.392s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[5.393s] [ext: omni.isaac.utils-1.0.1] startup
[5.400s] [ext: omni.isaac.cloner-0.8.1] startup
[5.402s] [ext: omni.importer.urdf-1.14.1] startup
[5.462s] [ext: omni.kit.window.stats-0.1.6] startup
[5.470s] [ext: omni.isaac.sim.python-4.2.0] startup
[5.473s] Simulation App Starting
[7.501s] app ready
[8.360s] Simulation App Startup Complete
ahaidu
October 2, 2024, 2:39pm
3
Hi Marvin,
here are some possible relevant carb settings, can you check if any of them solve what you are trying to achieve?
# App
import carb.settings
carb.settings.get_settings().set("/app/enableDeveloperWarnings", False)
carb.settings.get_settings().set("/app/scripting/ignoreWarningDialog", True)
# UI Console
carb.settings.get_settings().set("/exts/omni.kit.window.console/logFilter/verbose", False)
carb.settings.get_settings().set("/exts/omni.kit.window.console/logFilter/info", False)
carb.settings.get_settings().set("/exts/omni.kit.window.console/logFilter/warning", False)
carb.settings.get_settings().set("/exts/omni.kit.window.console/logFilter/error", False)
carb.settings.get_settings().set("/exts/omni.kit.window.console/logFilter/fatal", False)
# Log
carb.settings.get_settings().set("/log/debugConsoleLevel", "Fatal") # verbose"|"info"|"warning"|"error"|"fatal"
carb.settings.get_settings().set("/log/enabled", False)
carb.settings.get_settings().set("/log/outputStreamLevel", "Error")
carb.settings.get_settings().set("/log/fileLogLevel", "Error")
Thanks Adrei!
I added all of them after creating my Isaac Sim instance:
# start isaac
kit = SimulationApp(launch_config=isaac_config_data["ISAAC_CONFIG"])
# App
# UI Console
# Log
But once I remove my modifications in the python.kit file I again get all warnings, such as
2024-10-02 14:42:29 [28,635ms] [Warning] [omni.replicator.core.ogn.python._impl.nodes.OgnGetPrims] No prims found with given inputs:
or
2024-10-02 14:42:16 [15,794ms] [Warning] [omni.usd] Warning: in AppendProperty at line 858 of /builds/omniverse/usd-ci/USD/pxr/usd/sdf/path.cpp – Can only append a property ‘png’ to a prim path ()
