Isaac Sim | OmniGraph | Python API - Make array
We are trying to programmatically use a make array (ConstructArray), but we are unable to set anything which is not input0.
Error:
2023-06-04 13:09:54 [1,965,188ms] [Error] [omni.kit.app.plugin] [py stderr]: OmniGraphError: Failed trying to look up attribute with (/nakai_container/MovementGraph/velocity_command_duplicator.inputs:input1, node=None, graph=None)
At:
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/object_lookup.py(404): __attribute_from_info
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/object_lookup.py(411): attribute
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(649): _process_set_value
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(656): <listcomp>
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(656): _process_set_values
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(1031): __do_the_edits
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(1038): __edit
Reproduction script:
import omni.graph.core as og
keys = og.Controller.Keys
og.Controller.edit(
    {"graph_path": "/nakai_container/MovementGraph", "evaluator_name": "execution"},
        keys.CREATE_NODES: [
            ("velocity_command_duplicator", "omni.graph.nodes.ConstructArray"),
        keys.SET_VALUES: [
            ("velocity_command_duplicator.inputs:arraySize", 4),
            ("velocity_command_duplicator.inputs:arrayType", "double[]"),
            ("velocity_command_duplicator.inputs:input0",  1),
            ("velocity_command_duplicator.inputs:input1",  2),
            ("velocity_command_duplicator.inputs:input2",  3),
            ("velocity_command_duplicator.inputs:input3",  4),
In the GUI, there is the plus button for adding inputs, but how can it be done via the python api?
Hi @omers - It seems like the script is not able to find the attribute for the input1 of the velocity_command_duplicator node. This error could be caused by the node not being created properly before trying to set its input values.
To fix this issue, you can try splitting the creation and setting of values into two separate calls to the og.Controller.edit() method. Here’s the modified script:
Create the node first
og.Controller.edit(
{“graph_path”: “/nakai_container/MovementGraph”, “evaluator_name”: “execution”},
(“velocity_command_duplicator”, “omni.graph.nodes.ConstructArray”),
Set the input values for the created node
og.Controller.edit(
keys.SET_VALUES: [
(“velocity_command_duplicator.inputs:arraySize”, 4),
(“velocity_command_duplicator.inputs:arrayType”, “double”),
(“velocity_command_duplicator.inputs:input0”, 1),
(“velocity_command_duplicator.inputs:input1”, 2),
(“velocity_command_duplicator.inputs:input2”, 3),
(“velocity_command_duplicator.inputs:input3”, 4),
Let us know if it works or not.
@rthaker Thanks for the detailed response.
First part creating the node working, second part trying to edit it throws the following exception:
2023-06-18 13:47:47 [270,818ms] [Error] [omni.kit.app.plugin] [py stderr]: OmniGraphError: Failed to wrap graph in node given {'graph_path': '/nakai_container/MovementGraph', 'evaluator_name': 'execution'}
At:
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/graph_controller.py(172): __create_graph
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/graph_controller.py(106): create_graph
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(939): __do_the_edits
  /home/amram/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.graph/omni/graph/core/_impl/controller.py(878): edit
  /tmp/carb.mOqQgg/script_1687096067.py(14): <module>
Hi @omers - Can you try this other script? if it doesn’t work then I will bring this issue to the Omnigraph experts.
og.Controller.edit(
        keys.SET_VALUES: [
# Create a separate node or function to set the values of the other array elements
for i in range(1, 4):
    og.Controller.edit(
            keys.SET_VALUES: [
                (f"velocity_command_duplicator.inputs:input{i}", i + 1),
I am also experiencing the same issue. When creating a MakeArray omnigraph node using a Python script, the inputs value is not being added, and the problem was not resolved even when I used the suggested method. I would like to know if there is another way.
    og.Controller.Keys.SET_VALUES: [
        ("DifferentialController.inputs:wheelDistance", 0.53342),
        ("DifferentialController.inputs:wheelRadius", 0.24),
        ("MakeArray.inputs:arraySize", 2),
        ("MakeArray.inputs:arrayType", "token[]"),
        ("MakeArray.inputs:input0", "left_wheel"),
        ("MakeArray.inputs:input1", "right_wheel"),
        ("ArticulationController.inputs:targetPrim", "/World/Robot"),
        ("ArticulationController.inputs:usePath", False),
Same thing and it also doesn’t work for me.
Another approach is to use og.Controller.attribute().
https://docs.omniverse.nvidia.com/isaacsim/latest/advanced_tutorials/tutorial_advanced_omnigraph_scripting.html?highlight=graph#editing-a-graph
Example:
og.Controller.edit(
        keys.SET_VALUES: [
og.Controller.attribute("/nakai_container/MovementGraph/velocity_command_duplicator.inputs:input0").set(1)
og.Controller.attribute("/nakai_container/MovementGraph/velocity_command_duplicator.inputs:input1").set(2)
og.Controller.attribute("/nakai_container/MovementGraph/velocity_command_duplicator.inputs:input2").set(3)
og.Controller.attribute("/nakai_container/MovementGraph/velocity_command_duplicator.inputs:input3").set(4)
Did anyone get this to work? I’m still can’t get it to work using the examples posted.
When I set the array size to 2 it shows 2 in the input but the GUI still only shows a single input and input0 is just repeated in both arrays.
og.Controller.edit(
        {"graph_path": f"{ROBOT_STAGE_PATH}/ROS/DifferentialController", "evaluator_name": "execution"},
            # fmt: off
            og.Controller.Keys.CREATE_NODES: [
                ("OnPlaybackTick", "omni.graph.action.OnPlaybackTick"),
                ("Context", "omni.isaac.ros2_bridge.ROS2Context"),
                ("ROS2SubscribeTwist", "omni.isaac.ros2_bridge.ROS2SubscribeTwist"),
                ("ArticulationController", "omni.isaac.core_nodes.IsaacArticulationController"),
                ("DifferentialController", "omni.isaac.wheeled_robots.DifferentialController"),
                ("cmd_vel_z", "omni.graph.nodes.BreakVector3"),
                ("cmd_vel_x", "omni.graph.nodes.BreakVector3"),
                ("wheel_names_array", "omni.graph.nodes.ConstructArray"),
            og.Controller.Keys.CONNECT: [
                ("OnPlaybackTick.outputs:tick", "ArticulationController.inputs:execIn"),
                ("OnPlaybackTick.outputs:tick", "DifferentialController.inputs:execIn"),
                ("OnPlaybackTick.outputs:tick", "ROS2SubscribeTwist.inputs:execIn"),
                ("Context.outputs:context", "ROS2SubscribeTwist.inputs:context"),
                ("DifferentialController.outputs:velocityCommand", "ArticulationController.inputs:velocityCommand"),
                ("ROS2SubscribeTwist.outputs:angularVelocity", "cmd_vel_z.inputs:tuple"),
                ("ROS2SubscribeTwist.outputs:linearVelocity", "cmd_vel_x.inputs:tuple"),
                ("cmd_vel_z.outputs:z", "DifferentialController.inputs:angularVelocity"),
                ("cmd_vel_x.outputs:x", "DifferentialController.inputs:linearVelocity"),
                ("wheel_names_array.outputs:array", "ArticulationController.inputs:jointNames"),
                ("Context.inputs:domain_id", ROS_DOMAIN_ID),
                ("ROS2SubscribeTwist.inputs:topicName", "cmd_vel"),
                ("ArticulationController.inputs:robotPath", f"{ROBOT_STAGE_PATH}/base_footprint"),
                ("ArticulationController.inputs:targetPrim", f"{ROBOT_STAGE_PATH}/base_footprint"),
                ("DifferentialController.inputs:wheelRadius", 0.0885),
                ("DifferentialController.inputs:wheelDistance", 0.46),
                ("DifferentialController.inputs:maxLinearSpeed", 0.6),
                ("DifferentialController.inputs:maxAngularSpeed", 0.6),
                ("wheel_names_array.inputs:arraySize", 2),
                ("wheel_names_array.inputs:arrayType", "token[]"),
                ("wheel_names_array.inputs:input0", "left_wheel_joint"),
                ("wheel_names_array.inputs:input1", "right_wheel_joint"),
Could you try this?
og.Controller.edit(
            # fmt: off
og.Controller.attribute(f"{ROBOT_STAGE_PATH}/ROS/DifferentialController/wheel_names_array.inputs:input0").set("left_wheel_joint")
og.Controller.attribute(f"{ROBOT_STAGE_PATH}/ROS/DifferentialController/wheel_names_array.inputs:input1").set("right_wheel_joint")
This is isaac sim 4.2.0
I tired the code and didn’t work:
OmniGraphError: Failed trying to look up attribute with (/KR1/ROS/DifferentialController/wheel_names_array.inputs:input1, node=None, graph=None)
If still only has a single input on the graph. Does your graph have 2 inputs?
I found a way to circumvent this problem
og.Controller.edit(
            # fmt: off
                ("wheel_names_array_add", "omni.graph.nodes.ArrayInsertValue"),
                ("wheel_names_array.outputs:array", "wheel_names_array_add.inputs:array"),
                 ("wheel_names_array_add.outputs:array", "ArticulationController.inputs:jointNames"),
                ("wheel_names_array_add.inputs:index", 1),
                ("wheel_names_array_add.inputs:value", "right_wheel_joint"),
I’m currently using issac-sim version 4.2.0, and when I type:
self.control.attribute(f"/{graph_name}/make_array.inputs:arraySize").set(2)
self.control.attribute(f"/{graph_name}/make_array.inputs:arrayType").set(“token”)
I still only see input0. Is this behavior fixed in ISAAC-SIM 4.5.0?
This is still not working on IsaacSim 4.5.0.
Make Array doesn’t update the size of the input if the simulation app is started from a Python script. It does not matter how the action graph is edited (python or UI). If the action is added and array size is edited from the UI, the action block still only shows input0. If this is done from a python script it also doesn’t work and the size is not updated.
This is a major blocker as this is a very basic building block for many controllers. Could you please prioritize fixing this?
