I am studying Quick Start-Kaya in isaac SIM Document.
First we tested the joystick application. But I don’t know if I need to connect the joystick to the host or the jetson nano. Also, when I turn on the isaac SIM, the kaya robot does not appear on the screen when I press play and nothing happens.
Second, we tested the Object Detection application. I have a question, is it right to run isaac SIM in one terminal and “bazel run apps / kaya / unreal_sim: object_detection” in the other terminal? I got an error when I did like above.
The error is this:
wireless@ubuntu:~/Downloads/isaac-sdk-2019.2-30e21124$ bazel run apps/kaya/unreal_sim:object_detection
WARNING: /home/wireless/Downloads/isaac-sdk-2019.2-30e21124/packages/yolo/BUILD:15:12: in srcs attribute of cc_binary rule //packages/yolo:libyolo_module.so: please do not import ‘//packages_x86_64/yolo:libyolo_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
WARNING: /home/wireless/Downloads/isaac-sdk-2019.2-30e21124/packages/viewers/BUILD:14:12: in srcs attribute of cc_binary rule //packages/viewers:libviewers_module.so: please do not import ‘//packages_x86_64/viewers:libviewers_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
WARNING: /home/wireless/Downloads/isaac-sdk-2019.2-30e21124/packages/ml/BUILD:15:12: in srcs attribute of cc_binary rule //packages/ml:libml_module.so: please do not import ‘//packages_x86_64/ml:libml_module.so’ directly. You should either move the file to this package or depend on an appropriate rule there
INFO: Analysed target //apps/kaya/unreal_sim:object_detection (2 packages loaded, 65 targets configured).
INFO: Found 1 target…
Target //apps/kaya/unreal_sim:object_detection up-to-date:
bazel-genfiles/apps/kaya/unreal_sim/run_object_detection
bazel-bin/apps/kaya/unreal_sim/object_detection
INFO: Elapsed time: 0.279s, Critical Path: 0.08s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
2019-09-09 22:10:00.366 INFO engine/alice/tools/websight.cpp@166: Loading websight…
2019-09-09 22:10:00.366 WARNING engine/alice/backend/application_json_loader.cpp@98: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system’s abilities if possible.
2019-09-09 22:10:00.366 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph ‘inference’: ml, viewers, yolo,
2019-09-09 22:10:00.367 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph ‘2d_kaya’: flatsim, (viewers),
2019-09-09 22:10:00.367 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph ‘commander’: (navigation), sensors:joystick,
2019-09-09 22:10:00.367 INFO engine/alice/backend/application_json_loader.cpp@237: Modules requested by subgraph ‘odometry’: imu, (navigation),
2019-09-09 22:10:00.367 WARNING engine/alice/backend/backend.cpp@168: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2019-09-09 22:10:00.367 WARNING engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2019-09-09 22:10:00.368 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2019-09-09 22:10:00.368 INFO engine/gems/scheduler/scheduler.cpp@299: BlockerGroup: Cores = [9, 10, 11], Workers = No
2019-09-09 22:10:00.368 INFO engine/gems/scheduler/scheduler.cpp@299: WorkerGroup: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2019-09-09 22:10:00.372 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/flatsim/libflatsim_module.so’: Now has 53 components total
2019-09-09 22:10:00.377 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/imu/libimu_module.so’: Now has 57 components total
2019-09-09 22:10:00.390 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/navigation/libnavigation_module.so’: Now has 88 components total
2019-09-09 22:10:00.398 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/planner/libplanner_module.so’: Now has 96 components total
2019-09-09 22:10:00.405 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/sensors/libjoystick_module.so’: Now has 97 components total
2019-09-09 22:10:00.413 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/sight/libsight_module.so’: Now has 98 components total
2019-09-09 22:10:00.422 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/viewers/libviewers_module.so’: Now has 114 components total
2019-09-09 22:10:00.439 INFO engine/alice/backend/modules.cpp@283: Loaded module ‘packages/yolo/libyolo_module.so’: Now has 115 components total
2019-09-09 22:10:00.439 ERROR engine/alice/backend/modules.cpp@307: ml: /home/wireless/.cache/bazel/_bazel_wireless/7d44613f5127fe84c6271f7fd7b4110d/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/kaya/unreal_sim/object_detection.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/packages/ml/libml_module.so: cannot open shared object file: No such file or directory
2019-09-09 22:10:00.439 PANIC engine/alice/backend/modules.cpp@309: Could not load all required modules for application
| Isaac application terminated unexpectedly |
#01 engine/alice/tools/main(+0x8046a) [0x555cd0fc846a]
#02 engine/alice/tools/main(+0xe86d0) [0x555cd10306d0]
#03 engine/alice/tools/main(+0xe8a40) [0x555cd1030a40]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7fbd06700890]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7fbd05d9ae97]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7fbd05d9c801]
#07 engine/alice/tools/main(+0x9d1f7) [0x555cd0fe51f7]
#08 engine/alice/tools/main(+0x34bdc) [0x555cd0f7cbdc]
#09 engine/alice/tools/main(+0x350f3) [0x555cd0f7d0f3]
#10 engine/alice/tools/main(+0x352e4) [0x555cd0f7d2e4]
#11 engine/alice/tools/main(+0x15c23) [0x555cd0f5dc23]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fbd05d7db97]
#13 engine/alice/tools/main(+0x1af7a) [0x555cd0f62f7a]
Minidump written to: /tmp/da377fc9-385b-466e-f7a54ca9-292934e8.dmp
Aborted (core dumped)
This error has occurred in the terminal where “bazel run apps / kaya / unreal_sim: object_detection” was run. I would be very grateful if you help me.
