Isaac Sim RMPFlow and Lula Trayectory Generation Extension
I have some errors when loading the Lula Trajectory Generation and Lula RMPFlow extensions, the problem is similar for both cases, as you can see in the screenshot:
When I tried this command to enable the extension I got this error:
I need help and assistance please
You haven’t added your extension to kit.
from omni.isaac.kit import SimulationApp
import os
experience = f'{os.environ["EXP_PATH"]}/user.isaac.sim.kit'
simulation_app = SimulationApp({"headless": False}, experience=experience)
you can copy $ISAAC_PATH/apps/omni.isaac.sim.python.kit to user.isaac.sim.kit
than add your extension path below [setting.app.exts], and your extension name below [dependencies]
Hello, thanks for the help, could you be a little more specific to be able to apply this solution, in which file you include the PATH.
Well. The code below is what I should do when i first download isaac-sim and use my custom extension.
cd $HOME/.local/share/ov/pkg/isaac_sim-2023.1.0
conda env create -f environment.yml # create a env named isaac-sim
conda activate isaac-sim
source setup_conda_env.sh # you sholud check what have done in this
cd $ISAAC_PATH/apps
cp omni.isaac.sim.python.kit my.isaac.sim.kit
# open my.isaac.sim.kit
# add your extension path to L485 [setting.app.exts]
# add your extension name to L600 same as others
About how to create an extension ,see writing-a-custom-python-extension
after you execute
The simulation app will import extensions depens on user.isaac.sim.kit
you can check code in it for more details
Otherwise you might run into these errors
cannot find extension name ***
no module named omni.isaac.***
