Isaac Sim ROS2 bridge depth camera only show something when its origin is close to the object
Thank you for sharing your issue. The behavior you’re seeing in Rviz2, where the depth image is black, is also mentioned in a note on the Visualizing Results section.
To help verify if the issue is with Isaac Sim or with RViz2, could you please try running the following command and see if the depth image appears correctly?
ros2 run rqt_image_view rqt_image_view
Then, set the topic to /depth in the rqt_image_view window. Please let me know what you find.
