Hi!
I would like to use the Synthetic Data Recorder to save some information about the environment in the simulator, like rgb image, depth image, normals, etc.
I can save rgb image, depth image, bounding boxes, but the tool does not support saving images about normals, although, it can be viewed with the Synthetic Data Visualizer.
Is there a way to do this? Or is there a plan to implement this into the Isaac sim?
It would be also nice if I could publish the normal images using a ROS camera module.
On the forum I have seen that others are asking for IMU data, that can be also an option to save (or publish as a ROS topic)
Hi @molnarszilard10 ,
We plan to support saving normals via synthetic data recorder and ROS in the upcoming release. The same plan applies to publishing IMU as a ROS topic.
In case you want to still save sensor data that can be visualized by the Synthetic Data Visualizer but not saved via Synthetic Data Recorder, refer to $ISAAC_SIM/kit/extscore/omni.syntheticdata/omni/syntheticdata/scripts/sensors.py for various sensors synthetic data output that ISAAC SIM generates (for example, get_normals()) and integrate with syntheticdata_recorder.py, syntheticdata.py and writer.py within $ISAAC_SIM/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/scripts
