Hi, I’m working with Isaac Sim via a docker container in an Azure VM, running it through a WebSocket livestream, and I’m trying to access the source code of this tutorial: 2. Isaac Sim Workflows — Omniverse Robotics documentation
However, I’m running into the following error when clicking on the “Open Source Code” button:
/bin/sh: 1: code: not found
2022-02-09 13:08:38 [27,206ms] [Warning] [omni.isaac.ui.callbacks] Could not open in VSCode. See Troubleshooting help here: https://code.visualstudio.com/docs/editor/command-line#_common-questions
In the attached image you can see the result that I get in the WebSocket livestream. Does someone know how to fix this issue?
Note that I have VSCode installed and it’s already added to the PATH in my environment variables.
