I have followed the documentation to install dependencies using the scrpit in engine/build/scrpits/install_dependencies.sh
but when I try to play with the tutorial in sdk/apps/tutorials/jupyter_notebook
, it showed me some error in STEP-3 of the notebook
Step-03
# Create an Isaac application
from packages.pyalice import Application, Codelet, Message
app = Application()
print('Application created')
Output
ImportError Traceback (most recent call last)
<ipython-input-3-59e69387a2e7> in <module>
1 # Create an Isaac application
----> 2 from packages.pyalice import Application, Codelet, Message
3 app = Application()
4 print('Application created')
~/Developer/isaac-sdk-2020.2/sdk/packages/pyalice/__init__.py in <module>
11 # Modules to be included upon import of package
12
---> 13 from . import Message
14 from . import Composite
15 from .Application import Application
~/Developer/isaac-sdk-2020.2/sdk/packages/pyalice/Message.py in <module>
13 from .CapnpMessages import get_capnp_proto_schemata, capnp_schema_type_id_dict
14 from capnp.lib.capnp import _DynamicStructBuilder # pylint: disable=no-name-in-module
---> 15 from .bindings import PybindMessage # pylint: disable=no-name-in-module
16 from typing import List
17
ImportError: cannot import name 'PybindMessage'
