Isaac Sim ML Training
I did docker pull, and followed the instruction.
https://docs.nvidia.com/isaac/isaac/doc/tutorials/training_in_docker.html
./start.sh has been created by docker run -u $(id -u) -v $PWD:/workspace nvcr.io/nvidia/isaac-ml-training:2020.1 -s
All good to this point. And I clicked the URL at the end of the output on my terminal. http://localhost:8888/notebooks/object_detection_from_sim.ipynb?token=object-detection-from-sim
But it tells that " This site can’t be reached localhost refused to connect."
Please help me how to resolve this issue.
Here is the output of the terminal:
./start.sh
We will need your ROOT password to enable access to your display from inside Docker
access control disabled, clients can connect from any host
Starting tutorial use Ctrl-C to stop.
Authenticating with existing credentials…
WARNING! Your password will be stored unencrypted in /home/dave/.docker/config.json.
Configure a credential helper to remove this warning. See
Login Succeeded
Default 3D models were copied to user space
- Open your browser and go to: *
- http://localhost:8888/notebooks/object_detection_from_sim.ipynb?token=object-detection-from-sim *
Press Ctrl-C twice to exit
