I met a problem when I mitigate the IsaacGym example. I tried to use UR10 instead of franka to realize UR_attractor like franka_attractor. Whereas all the robot stuck like the picture. They cannot move following the target points. I have no idea where the error is.
import math
from isaacgym import gymapi
from isaacgym import gymutil
# Initialize gym
gym = gymapi.acquire_gym()
# Parse arguments
args = gymutil.parse_arguments(description="UR10 Attractor Example")
# configure sim
sim_params = gymapi.SimParams()
sim_params.dt = 1.0 / 60.0
sim_params.substeps = 2
if args.physics_engine == gymapi.SIM_FLEX:
sim_params.flex.solver_type = 5
sim_params.flex.num_outer_iterations = 4
sim_params.flex.num_inner_iterations = 15
sim_params.flex.relaxation = 0.75
sim_params.flex.warm_start = 0.8
elif args.physics_engine == gymapi.SIM_PHYSX:
sim_params.physx.solver_type = 1
sim_params.physx.num_position_iterations = 4
sim_params.physx.num_velocity_iterations = 1
sim_params.physx.num_threads = args.num_threads
sim_params.physx.use_gpu = args.use_gpu
sim_params.use_gpu_pipeline = False
if args.use_gpu_pipeline:
print("WARNING: Forcing CPU pipeline.")
sim = gym.create_sim(args.compute_device_id, args.graphics_device_id, args.physics_engine, sim_params)
if sim is None:
print("*** Failed to create sim")
quit()
# Create viewer
viewer = gym.create_viewer(sim, gymapi.CameraProperties())
if viewer is None:
print("*** Failed to create viewer")
quit()
# Add ground plane
plane_params = gymapi.PlaneParams()
gym.add_ground(sim, plane_params)
# Load ur10 asset
asset_root = "../../assets"
ur10_asset_file = "urdf/ur_description/robot/ur10.urdf"
asset_options = gymapi.AssetOptions()
asset_options.fix_base_link = True
asset_options.flip_visual_attachments = True
asset_options.armature = 0.01
print("Loading asset '%s' from '%s'" % (ur10_asset_file, asset_root))
ur10_asset = gym.load_asset(
sim, asset_root, ur10_asset_file, asset_options)
# Set up the env grid
num_envs = 36
spacing = 2.0
env_lower = gymapi.Vec3(-spacing, 0.0, -spacing)
env_upper = gymapi.Vec3(spacing, spacing, spacing)
# Some common handles for later use
envs = []
ur10_handles = []
ur10_hand = "tool0"
# Attractor setup
attractor_handles = []
attractor_properties = gymapi.AttractorProperties()
attractor_properties.stiffness = 5e5
attractor_properties.damping = 5e3
# Make attractor in all axes
attractor_properties.axes = gymapi.AXIS_ALL
pose = gymapi.Transform()
pose.p = gymapi.Vec3(0, 0.0, 0.0)
pose.r = gymapi.Quat(-0.707107, 0.0, 0.0, 0.707107)
# Create helper geometry used for visualization
# Create an wireframe axis
axes_geom = gymutil.AxesGeometry(0.1)
# Create an wireframe sphere
sphere_rot = gymapi.Quat.from_euler_zyx(0.5 * math.pi, 0, 0)
sphere_pose = gymapi.Transform(r=sphere_rot)
sphere_geom = gymutil.WireframeSphereGeometry(0.03, 12, 12, sphere_pose, color=(1, 0, 0))
print("Creating %d environments" % num_envs)
num_per_row = int(math.sqrt(num_envs))
for i in range(num_envs):
# create env
env = gym.create_env(sim, env_lower, env_upper, num_per_row)
envs.append(env)
# add ur10
ur10_handle = gym.create_actor(env, ur10_asset, pose, "ur10", i, 2)
body_dict = gym.get_actor_rigid_body_dict(env, ur10_handle)
props = gym.get_actor_rigid_body_states(env, ur10_handle, gymapi.STATE_POS)
hand_handle = body = gym.find_actor_rigid_body_handle(env, ur10_handle, ur10_hand)
# Initialize the attractor
attractor_properties.target = props['pose'][:][body_dict[ur10_hand]]
attractor_properties.target.p.y -= 0.1
attractor_properties.target.p.z = 0.1
attractor_properties.rigid_handle = hand_handle
# Draw axes and sphere at attractor location
gymutil.draw_lines(axes_geom, gym, viewer, env, attractor_properties.target)
gymutil.draw_lines(sphere_geom, gym, viewer, env, attractor_properties.target)
ur10_handles.append(ur10_handle)
attractor_handle = gym.create_rigid_body_attractor(env, attractor_properties)
attractor_handles.append(attractor_handle)
# get joint limits and ranges for ur10
ur10_dof_props = gym.get_actor_dof_properties(envs[0], ur10_handles[0])
ur10_lower_limits = ur10_dof_props['lower']
ur10_upper_limits = ur10_dof_props['upper']
ur10_ranges = ur10_upper_limits - ur10_lower_limits
ur10_mids = 0.5 * (ur10_upper_limits + ur10_lower_limits)
ur10_num_dofs = len(ur10_dof_props)
# override default stiffness and damping values
ur10_dof_props['stiffness'].fill(1000.0)
ur10_dof_props['damping'].fill(1000.0)
# Give a desired pose for first 2 robot joints to improve stability
ur10_dof_props["driveMode"][0:2] = gymapi.DOF_MODE_POS
ur10_dof_props["driveMode"][7:] = gymapi.DOF_MODE_POS
ur10_dof_props['stiffness'][7:] = 1e10
ur10_dof_props['damping'][7:] = 0.5
gym.set_actor_dof_properties(envs[i], ur10_handles[i], ur10_dof_props)
def update_ur10(t):
gym.clear_lines(viewer)
# Update attractor target from current ur10 state
attractor_properties = gym.get_attractor_properties(envs[i], attractor_handles[i])
pose = attractor_properties.target
pose.p.x = 0.2 * math.sin(1.5 * t - math.pi * float(i) / num_envs)
pose.p.y = 0.7 + 0.1 * math.cos(2.5 * t - math.pi * float(i) / num_envs)
pose.p.z = 0.2 * math.cos(1.5 * t - math.pi * float(i) / num_envs)
gym.set_attractor_target(envs[i], attractor_handles[i], pose)
gymutil.draw_lines(axes_geom, gym, viewer, envs[i], pose)
gymutil.draw_lines(sphere_geom, gym, viewer, envs[i], pose)
# Set updated stiffness and damping properties
# Set ur10 pose so that each joint is in the middle of its actuation range
ur10_dof_states = gym.get_actor_dof_states(envs[i], ur10_handles[i], gymapi.STATE_NONE)
for j in range(ur10_num_dofs):
ur10_dof_states['pos'][j] = ur10_mids[j]
gym.set_actor_dof_states(envs[i], ur10_handles[i], ur10_dof_states, gymapi.STATE_POS)
# Point camera at environments
cam_pos = gymapi.Vec3(-4.0, 4.0, -1.0)
cam_target = gymapi.Vec3(0.0, 2.0, 1.0)
gym.viewer_camera_look_at(viewer, None, cam_pos, cam_target)
# Time to wait in seconds before moving robot
next_ur10_update_time = 1.5
while not gym.query_viewer_has_closed(viewer):
# Every 0.01 seconds the pose of the attactor is updated
t = gym.get_sim_time(sim)
if t >= next_ur10_update_time:
update_ur10(t)
next_ur10_update_time += 0.01
# Step the physics
gym.simulate(sim)
gym.fetch_results(sim, True)
# Step rendering
gym.step_graphics(sim)
gym.draw_viewer(viewer, sim, False)
gym.sync_frame_time(sim)
print("Done")
gym.destroy_viewer(viewer)
gym.destroy_sim(sim)
