IsaacGymEnvs: CUDA error: an illegal memory access was encountered --> FrankaCabinet task (modified)
I creating a simpler FrankaCabinet task in IsaacGym in which I am replacing the cabinet with just a box with a cylinder to be reached to. For the same, I have deleted all the cabinet and props parts of the code and added a custom box and cylinder assets.
When I try to run the training, I get this error:
RuntimeError: CUDA error: an illegal memory access was encountered
in the reset_idx() function:
self.progress_buf[env_ids] = 0
The error is specifically in the env_ids variable as I have tried printing it out and getting the same error.
The problem is not:
  • Incorrect device: Both- progress_buf & env_ids are stored on my GPU explicitly.
  • Out of index: Both the tensors are of equal length i.e. 4096.
  • env_ids does not have any weird misplaced integers: It is a simple array of [1,2,3..., 4096] .
  • The GPU memory should be enough as I can run much more complex examples fairly fine on my RTX3070.
Here’s my reset_idx function for reference.
def reset_idx(self, env_ids):
    env_ids_int32 = env_ids.to(dtype=torch.int32)
    # reset franka
    pos = tensor_clamp(
        self.franka_default_dof_pos.unsqueeze(0) + 0.25 * (
                torch.rand((len(env_ids), self.num_franka_dofs), device=self.device) - 0.5),
        self.franka_dof_lower_limits, self.franka_dof_upper_limits)
    self.franka_dof_pos[env_ids, :] = pos
    self.franka_dof_vel[env_ids, :] = torch.zeros_like(self.franka_dof_vel[env_ids])
    self.franka_dof_targets[env_ids, :self.num_franka_dofs] = pos
    multi_env_ids_int32 = self.global_indices[env_ids, :1].flatten()
    self.gym.set_dof_position_target_tensor_indexed(self.sim,
                                                    gymtorch.unwrap_tensor(self.franka_dof_targets),
                                                    gymtorch.unwrap_tensor(multi_env_ids_int32),
                                                    len(multi_env_ids_int32))
    self.gym.set_dof_state_tensor_indexed(self.sim,
                                          gymtorch.unwrap_tensor(self.dof_state),
                                          gymtorch.unwrap_tensor(multi_env_ids_int32), len(multi_env_ids_int32))
    if env_ids.device != self.progress_buf.device:
        env_ids = env_ids.to(self.progress_buf.device)
    # print("env_ids device: ", env_ids.device)
    # print("progress_buf device: ", self.progress_buf.device)
    # print env_ids index 0
    print(env_ids[0])
    self.reset_buf[env_ids] = 0
Also attaching the complete error code for the same:
[Error] [carb.gym.plugin] Gym cuda error: an illegal memory access was encountered: ../../../source/plugins/carb/gym/impl/Gym/GymPhysX.cpp: 6340
[Error] [carb.gym.plugin] Gym cuda error: an illegal memory access was encountered: ../../../source/plugins/carb/gym/impl/Gym/GymPhysXCuda.cu: 1001
Error executing job with overrides: ['task=FrankaReach', 'headless=True', 'max_iterations=200']
/usr/lib/python3/dist-packages/apport/report.py:13: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
  import fnmatch, glob, traceback, errno, sys, atexit, imp, stat
  File "train.py", line 220, in <module>
    launch_rlg_hydra()
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/main.py", line 94, in decorated_main
    _run_hydra(
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/utils.py", line 394, in _run_hydra
    _run_app(
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/utils.py", line 457, in _run_app
    run_and_report(
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/utils.py", line 223, in run_and_report
    raise ex
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/utils.py", line 220, in run_and_report
    return func()
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/utils.py", line 458, in <lambda>
    lambda: hydra.run(
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/_internal/hydra.py", line 132, in run
    _ = ret.return_value
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/core/utils.py", line 260, in return_value
    raise self._return_value
  File "/home/kudos/.local/lib/python3.8/site-packages/hydra/core/utils.py", line 186, in run_job
    ret.return_value = task_function(task_cfg)
  File "train.py", line 211, in launch_rlg_hydra
    runner.run({
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/torch_runner.py", line 133, in run
    self.run_train(args)
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/torch_runner.py", line 113, in run_train
    agent = self.algo_factory.create(self.algo_name, base_name='run', params=self.params)
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/common/object_factory.py", line 15, in create
    return builder(**kwargs)
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/torch_runner.py", line 37, in <lambda>
    self.algo_factory.register_builder('a2c_continuous', lambda **kwargs : a2c_continuous.A2CAgent(**kwargs))
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/algos_torch/a2c_continuous.py", line 15, in __init__
    a2c_common.ContinuousA2CBase.__init__(self, base_name, params)
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/common/a2c_common.py", line 1143, in __init__
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/common/a2c_common.py", line 129, in __init__
    self.vec_env = vecenv.create_vec_env(self.env_name, self.num_actors, **self.env_config)
  File "/home/kudos/.local/lib/python3.8/site-packages/rl_games/common/vecenv.py", line 224, in create_vec_env
    return vecenv_config[vec_env_name](config_name, num_actors, **kwargs)
  File "train.py", line 167, in <lambda>
    vecenv.register('RLGPU', lambda config_name, num_actors, **kwargs: RLGPUEnv(config_name, num_actors, **kwargs))
  File "/home/kudos/Documents/Honours/IsaacGymEnvs/isaacgymenvs/utils/rlgames_utils.py", line 246, in __init__
    self.env = env_configurations.configurations[config_name]['env_creator'](**kwargs)
  File "train.py", line 148, in <lambda>
    'env_creator': lambda **kwargs: create_isaacgym_env(**kwargs),
  File "train.py", line 122, in create_isaacgym_env
    envs = isaacgymenvs.make(
  File "/home/kudos/Documents/Honours/IsaacGymEnvs/isaacgymenvs/__init__.py", line 55, in make
    return create_rlgpu_env()
  File "/home/kudos/Documents/Honours/IsaacGymEnvs/isaacgymenvs/utils/rlgames_utils.py", line 115, in create_rlgpu_env
    env = isaacgym_task_map[task_name](
  File "/home/kudos/Documents/Honours/IsaacGymEnvs/isaacgymenvs/tasks/franka_reach.py", line 100, in __init__
    self.reset_idx(torch.arange(self.num_envs))
  File "/home/kudos/Documents/Honours/IsaacGymEnvs/isaacgymenvs/tasks/franka_reach.py", line 337, in reset_idx
Compile with `TORCH_USE_CUDA_DSA` to enable device-side assertions.
Thanks in advance!
I have tried to print out the env_ids variable separately but it causes the same error.
Interestingly, when I try to print the shape of the variable using: env_ids.shape, it prints that out without any errors.
The error code is not very helpful as there are multiple reasons for it and there isn’t much documentation for the same.
Hello,did you solve the problem? I met the same problem when i import a custom urdf file.
