Hi NVIDIA Isaac Lab community,
I’m building a lightweight tool called IsaacLab Auto-Exporter to simplify the process of bringing a URDF robot into Isaac Lab.
The goal is simple:
URDF
Parse
Validate
Generate Isaac Lab configuration
Generate spawn script
Download ZIP
The user uploads a URDF and receives a ready-to-run Isaac Lab project containing:
- robot_cfg.py
- actuator_cfg.py
- spawn_robot.py
- metadata.json
- README.md
- original URDF
I’ve implemented the URDF parsing, validation, metadata inference, Isaac Lab configuration generation, and ZIP export pipeline.
One issue I specifically addressed was actuator damping. Instead of relying only on heuristic defaults, the exporter now reads the URDF’s native value when available.
For example, with the Allegro Hand URDF, the exporter correctly extracts:
damping = 0.015
and records that the value came directly from the URDF.
The current implementation is intentionally offline and heuristic-based — no LLM or cloud service is required.
I’d really appreciate feedback from Isaac Lab users/developers on the generated project structure and workflow.
In particular:
- Is this generated ArticulationCfg / actuator configuration approach compatible with current Isaac Lab practices?
- Are there important URDF → Isaac Lab parameters that I should not be missing?
- Is there anything in the generated spawn workflow that you would change?
- Would this be useful as a developer tool for quickly testing URDF robots in Isaac Lab?
I’m particularly interested in feedback on what would make this genuinely useful for the Isaac Lab community rather than just another URDF converter.
