./isaaclab.sh -p source/standalone/demos/quadrupeds.py
Isaac Sim Version
4.2.0
Isaac Lab Version (if applicable)
1.2
Operating System
Ubuntu 20.04
/home/intel/anaconda3/envs/isaaclab/bin/python /home/intel/IsaacLab/source/standalone/demos/hands.py
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the AppLauncher.add_app_launcher_args method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Loading experience file: /home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/…/…/…/…/…/…/apps/isaaclab.python.kit
[Warning] [omni.isaac.kit.simulation_app] Modules: [‘omni.kit_app’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Starting kit application with the following args: [‘/home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py’, ‘/home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/…/…/…/…/…/…/apps/isaaclab.python.kit’, ‘–/app/tokens/exe-path=/home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True’, ‘–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–/app/fastShutdown=True’, ‘–ext-folder’, ‘/home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts’, ‘–ext-folder’, ‘/home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/apps’, ‘–/renderer/activeGpu=0’, ‘–/physics/cudaDevice=0’, ‘–portable’, ‘–/app/window/hideUi=False’]
Passing the following args to the base kit application:
Loading user config located at: ‘/home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.1/user.config.json’
[Info] [carb] Logging to file: /home/intel/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.1/kit_20241104_234753.log
2024-11-04 15:47:53 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
[0.112s] [ext: omni.blobkey-1.1.2] startup
[0.112s] [ext: omni.kit.async_engine-0.0.1] startup
[0.175s] [ext: omni.stats-1.0.1] startup
[0.175s] [ext: omni.datastore-0.0.0] startup
[0.178s] [ext: omni.client-1.2.0] startup
[0.193s] [ext: omni.ujitso.default-1.0.0] startup
[0.194s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.196s] [ext: omni.hsscclient-1.1.1] startup
[0.196s] [ext: omni.assets.plugins-0.0.0] startup
[0.196s] [ext: omni.gpu_foundation-0.0.0] startup
[0.200s] [ext: carb.windowing.plugins-1.0.0] startup
[0.204s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.161.07 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4080 SUPER | Yes: 0 | | 16622 MB | 10de | 0 |
| | | | | | 2702 | f063c87f… |
| | | | | | 1 | |
| OS: 20.04.6 LTS (Focal Fossa) ubuntu, Version: 20.04.6, Kernel: 5.15.0-124-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: Intel(R) Core™ i9-14900K | Cores: 24 | Logical: 32
| Total Memory (MB): 64057 | Free Memory: 57464
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.620s] [ext: omni.kit.pipapi-0.0.0] startup
[0.621s] [ext: omni.materialx.libs-1.0.4] startup
[0.625s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.625s] [ext: omni.usd.config-1.0.4] startup
[0.627s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.627s] [ext: omni.usd.libs-1.0.1] startup
[0.690s] [ext: omni.iray.libs-0.0.0] startup
[0.692s] [ext: omni.mdl.neuraylib-0.2.8] startup
[0.693s] [ext: omni.mdl-55.0.1] startup
[0.703s] [ext: omni.kit.usd.mdl-1.0.1] startup
[0.761s] [ext: omni.kit.telemetry-0.5.0] startup
[0.777s] [ext: omni.kit.loop-isaac-1.2.0] startup
[0.778s] [ext: omni.kit.test-1.1.0] startup
[0.808s] [ext: omni.appwindow-1.1.8] startup
[0.832s] [ext: omni.kit.renderer.core-1.0.2] startup
[0.965s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.966s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[1.023s] [ext: omni.ui-2.25.22] startup
[1.029s] [ext: omni.kit.mainwindow-1.0.3] startup
[1.029s] [ext: carb.audio-0.1.0] startup
[1.031s] [ext: omni.uiaudio-1.0.0] startup
[1.031s] [ext: omni.kit.uiapp-0.0.0] startup
[1.031s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.033s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.035s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[1.041s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[1.042s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.045s] [ext: omni.usd.schema.physx-106.1.9] startup
[1.058s] [ext: omni.usd.schema.isaac-2.1.0] startup
[1.062s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.074s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.075s] [ext: omni.usd_resolver-1.0.0] startup
[1.077s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[1.079s] [ext: usdrt.scenegraph-7.5.0] startup
[1.102s] [ext: omni.timeline-1.0.10] startup
[1.102s] [ext: omni.usd.core-1.4.1] startup
[1.104s] [ext: omni.resourcemonitor-105.0.1] startup
[1.105s] [ext: omni.activity.core-1.0.1] startup
[1.106s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[1.107s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[1.114s] [ext: omni.kit.actions.core-1.0.0] startup
[1.115s] [ext: omni.graph.exec-0.9.4] startup
[1.115s] [ext: omni.kit.commands-1.4.9] startup
[1.117s] [ext: omni.kit.usd_undo-0.1.8] startup
[1.117s] [ext: omni.kit.exec.core-0.13.4] startup
[1.119s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[1.120s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[1.122s] [ext: omni.usd-1.12.2] startup
[1.146s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[1.147s] [ext: omni.isaac.kit-1.13.2] startup
[1.147s] [ext: omni.kit.widget.options_button-1.0.3] startup
[1.148s] [ext: omni.warp.core-1.2.1] startup
[1.248s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[1.248s] [ext: omni.kit.widget.path_field-2.0.10] startup
[1.249s] [ext: omni.kit.menu.core-1.0.4] startup
[1.249s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[1.250s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[1.250s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[1.251s] [ext: omni.kit.search_core-1.0.5] startup
[1.251s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[1.252s] [ext: omni.ui.scene-1.10.3] startup
[1.255s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[1.257s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[1.257s] [ext: omni.volume-0.5.0] startup
[1.259s] [ext: omni.ujitso.client-0.0.0] startup
[1.259s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[1.260s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[1.261s] [ext: omni.kit.notification_manager-1.0.9] startup
[1.262s] [ext: omni.kit.clipboard-1.0.4] startup
[1.262s] [ext: omni.hydra.rtx-1.0.0] startup
[1.272s] [ext: omni.kit.window.filepicker-2.10.40] startup
[1.278s] [ext: omni.kit.usd.layers-2.1.36] startup
[1.283s] [ext: omni.kit.menu.utils-1.5.27] startup
[1.287s] [ext: omni.kit.window.file_importer-1.1.12] startup
[1.288s] [ext: omni.kit.context_menu-1.8.1] startup
[1.289s] [ext: omni.hydra.engine.stats-1.0.2] startup
[1.290s] [ext: omni.kit.material.library-1.5.6] startup
[1.292s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[1.293s] [ext: omni.kit.raycast.query-1.0.5] startup
[1.295s] [ext: omni.kit.viewport.registry-104.0.6] startup
[1.296s] [ext: omni.kit.hydra_texture-1.3.9] startup
[1.298s] [ext: omni.kit.widget.settings-1.2.2] startup
[1.299s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[1.299s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[1.299s] [ext: omni.kit.window.drop_support-1.0.3] startup
[1.300s] [ext: omni.kit.widget.viewport-106.1.0] startup
[1.301s] [ext: omni.kit.window.preferences-1.6.0] startup
[1.306s] [ext: omni.kit.window.property-1.11.3] startup
[1.307s] [ext: omni.inspect-1.0.1] startup
[1.308s] [ext: omni.kit.viewport.window-107.0.6] startup
[1.316s] [ext: omni.graph.tools-1.79.0] startup
[1.326s] [ext: omni.graph.core-2.179.2] startup
[1.328s] [ext: omni.kit.viewport.utility-1.0.17] startup
[1.329s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[1.329s] [ext: omni.graph-1.140.0] startup
[1.350s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[1.351s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[1.355s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[1.357s] [ext: omni.kit.widget.prompt-1.0.7] startup
[1.359s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[1.360s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[1.363s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[1.365s] [ext: omni.kit.stage_template.core-1.1.22] startup
[1.366s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[1.367s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[1.367s] [ext: omni.kit.widget.filter-1.1.4] startup
[1.369s] [ext: omni.kit.window.file-1.3.54] startup
[1.370s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[1.372s] [ext: omni.kit.widget.graph-1.12.15] startup
[1.375s] [ext: omni.kit.widget.stage-2.11.2] startup
[1.380s] [ext: omni.kit.window.content_browser-2.9.18] startup
[1.388s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[1.389s] [ext: omni.kit.window.extensions-1.4.11] startup
[1.392s] [ext: omni.ui_query-1.1.4] startup
[1.392s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.393s] [ext: omni.kit.property.usd-4.2.8] startup
[1.399s] [ext: omni.debugdraw-0.1.3] startup
[1.401s] [ext: omni.kvdb-106.1.9] startup
[1.402s] [ext: omni.graph.ui-1.70.2] startup
[1.411s] [ext: omni.graph.action_core-1.1.6] startup
[1.414s] [ext: omni.localcache-106.1.9] startup
[1.415s] [ext: omni.graph.action_nodes-1.24.0] startup
[1.418s] [ext: omni.usdphysics-106.1.9] startup
[1.420s] [ext: omni.physx.foundation-106.1.9] startup
[1.421s] [ext: omni.convexdecomposition-106.1.9] startup
[1.425s] [ext: omni.graph.action-1.102.1] startup
[1.426s] [ext: omni.physx.cooking-106.1.9] startup
[1.434s] [ext: omni.kit.ui.actions-1.0.2] startup
[1.435s] [ext: omni.physx-106.1.9] startup
[1.448s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[1.451s] [ext: omni.physx.stageupdate-106.1.9] startup
[1.452s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[1.453s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[1.454s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[1.456s] [ext: omni.physics.tensors-106.1.9] startup
[1.460s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[1.462s] [ext: omni.isaac.version-1.1.0] startup
[1.463s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[1.464s] [ext: omni.physx.tensors-106.1.9] startup
[1.467s] [ext: omni.kit.stage_templates-1.2.5] startup
[1.468s] [ext: omni.isaac.nucleus-0.3.1] startup
[1.469s] [ext: omni.graph.window.core-1.113.1] startup
[1.474s] [ext: omni.kit.ui_test-1.3.2] startup
[1.476s] [ext: omni.isaac.core-3.19.5] startup
[2.137s] [ext: omni.graph.window.generic-1.26.0] startup
[2.141s] [ext: omni.isaac.ui-0.16.0] startup
[2.144s] [ext: omni.kit.menu.common-1.1.7] startup
[2.146s] [ext: omni.kit.menu.create-1.0.16] startup
[2.147s] [ext: omni.isaac.menu-0.7.3] startup
[2.150s] [ext: omni.kit.actions.window-1.1.1] startup
[2.154s] [ext: omni.graph.window.action-1.28.0] startup
[2.158s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[2.161s] [ext: omni.kit.widget.layers-1.8.0] startup
[2.167s] [ext: omni.kit.window.cursor-1.1.2] startup
[2.167s] [ext: omni.kit.property.isaac-0.2.3] startup
[2.168s] [ext: omni.kit.property.layer-1.1.8] startup
[2.170s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[2.177s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[2.178s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[2.179s] [ext: omni.graph.image.core-0.4.5] startup
[2.181s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[2.183s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[2.186s] [ext: omni.kit.selection-0.1.4] startup
[2.187s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[2.188s] [ext: omni.graph.image.nodes-1.1.0] startup
[2.190s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[2.191s] [ext: omni.graph.scriptnode-1.20.1] startup
[2.192s] [ext: omni.kit.menu.edit-1.1.24] startup
[2.194s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.196s] [ext: omni.graph.nodes-1.146.1] startup
[2.203s] [ext: omni.syntheticdata-0.6.9] startup
[2.218s] [ext: omni.kit.window.material_graph-1.8.18] startup
[2.234s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[2.236s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[2.239s] [ext: omni.warp-1.2.1] startup
[2.242s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[2.252s] [ext: omni.isaac.debug_draw-1.1.0] startup
[2.260s] [ext: omni.replicator.core-1.11.20] startup
2024-11-04 15:47:56 [2,203ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
CUDA Toolkit 11.8, Driver 12.2
Devices:
“cpu” : “x86_64”
“cuda:0” : “NVIDIA GeForce RTX 4080 SUPER” (16 GiB, sm_89, mempool enabled)
Kernel cache:
/home/intel/.cache/warp/1.2.1
[2.350s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[2.354s] [ext: omni.kit.widget.live-2.1.8] startup
[2.356s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[2.357s] [ext: omni.isaac.range_sensor-3.1.2] startup
[2.390s] [ext: omni.isaac.core_nodes-1.16.3] startup
[2.406s] [ext: omni.kit.viewport.actions-106.0.2] startup
[2.414s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[2.534s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[2.535s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
2024-11-04 15:47:56 [2,449ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
[2.538s] [ext: omni.rtx.window.settings-0.6.17] startup
[2.544s] [ext: omni.sensors.tiled-0.0.6] startup
[2.546s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[2.549s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[2.552s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[2.552s] [ext: omni.kit.menu.file-1.1.14] startup
[2.553s] [ext: omni.isaac.sensor-12.9.1] startup
[2.589s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[2.592s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[2.595s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[2.605s] [ext: omni.physx.commands-106.1.9] startup
[2.607s] [ext: omni.kit.widget.calendar-1.0.8] startup
[2.608s] [ext: omni.usdphysics.ui-106.1.9] startup
[2.622s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[2.625s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[2.626s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[2.630s] [ext: omni.physx.ui-106.1.9] startup
[2.645s] [ext: omni.kit.property.material-1.10.8] startup
[2.649s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[2.650s] [ext: omni.kit.property.geometry-1.3.1] startup
[2.651s] [ext: omni.physx.demos-106.1.9] startup
[2.661s] [ext: omni.kit.property.physx-106.1.9] startup
[2.704s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[2.709s] [ext: omni.fabric.commands-1.1.5] startup
[2.711s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[2.712s] [ext: omni.physx.vehicle-106.1.9] startup
[2.722s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[2.724s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[2.724s] [ext: omni.kit.property.light-1.0.10] startup
[2.726s] [ext: omni.kit.window.stage-2.5.10] startup
[2.728s] [ext: omni.physx.camera-106.1.9] startup
[2.734s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[2.736s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[2.737s] [ext: omni.kit.window.toolbar-1.6.1] startup
[2.738s] [ext: omni.kit.widget.timeline-105.0.1] startup
[2.740s] [ext: omni.kit.menu.stage-1.2.5] startup
[2.741s] [ext: omni.physx.cct-106.1.9] startup
[2.748s] [ext: omni.physx.graph-106.1.9] startup
[2.758s] [ext: omni.hydra.scene_api-0.1.2] startup
[2.763s] [ext: omni.physx.supportui-106.1.9] startup
[2.773s] [ext: omni.physx.telemetry-106.1.9] startup
[2.775s] [ext: omni.graph.ui_nodes-1.26.0] startup
[2.778s] [ext: omni.kit.property.render-1.1.2] startup
[2.779s] [ext: omni.kit.property.transform-1.5.9] startup
[2.782s] [ext: omni.kit.property.camera-1.0.8] startup
[2.784s] [ext: omni.kit.property.audio-1.0.14] startup
[2.786s] [ext: omni.graph.bundle.action-2.4.1] startup
[2.790s] [ext: omni.physx.bundle-106.1.9] startup
[2.791s] [ext: omni.kit.window.script_editor-1.7.6] startup
[2.796s] [ext: omni.kit.property.bundle-1.3.1] startup
[2.800s] [ext: omni.kit.window.status_bar-0.1.7] startup
[2.803s] [ext: omni.kit.window.title-1.1.5] startup
[2.805s] [ext: omni.replicator.isaac-1.15.2] startup
[2.815s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[2.825s] [ext: omni.rtx.settings.core-0.6.3] startup
[2.831s] [ext: omni.kit.window.commands-0.2.6] startup
[2.835s] [ext: semantics.schema.editor-0.3.8] startup
[2.840s] [ext: semantics.schema.property-1.0.4] startup
[2.841s] [ext: omni.kit.window.console-0.2.13] startup
[2.846s] [ext: omni.kit.profiler.window-2.2.3] startup
[2.925s] [ext: omni.isaac.utils-1.0.1] startup
[2.928s] [ext: omni.isaac.cloner-0.8.1] startup
[2.928s] [ext: omni.kit.window.stats-0.1.6] startup
[2.931s] [ext: isaaclab.python-1.1.0] startup
[2.933s] Simulation App Starting
[4.129s] app ready
[4.856s] Simulation App Startup Complete
2024-11-04 15:47:58 [4,774ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
[5.150s] [ext: omni.physx.fabric-106.1.9] startup
2024-11-04 15:51:20 [206,512ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp – In </World/Origin1/Robot>: Could not open asset @http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.1/Isaac/Robots/AllegroHand/allegro_hand_instanceable.usd@ for reference introduced by @anon:0x16026740:World0.usd@</World/Origin1/Robot>. (recomposing stage on stage @anon:0x16026740:World0.usd@ <0x13f4d530>)
2024-11-04 15:51:20 [206,535ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_rigid_body_properties’ on any prims under: ‘/World/Origin1/Robot’. This might be because of the following reasons:
(1) The desired attribute does not exist on any of the prims.
(2) The desired attribute exists on an instanced prim.
Discovered list of instanced prim paths:
2024-11-04 15:51:20 [206,535ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_articulation_root_properties’ on any prims under: ‘/World/Origin1/Robot’. This might be because of the following reasons:
2024-11-04 15:55:19 [445,475ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp – In </World/Origin2/Robot>: Could not open asset @http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.1/Isaac/Robots/ShadowHand/shadow_hand_instanceable.usd@ for reference introduced by @anon:0x16026740:World0.usd@</World/Origin2/Robot>. (recomposing stage on stage @anon:0x16026740:World0.usd@ <0x13f4d530>)
2024-11-04 15:55:19 [445,493ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_rigid_body_properties’ on any prims under: ‘/World/Origin2/Robot’. This might be because of the following reasons:
2024-11-04 15:55:19 [445,493ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_articulation_root_properties’ on any prims under: ‘/World/Origin2/Robot’. This might be because of the following reasons:
2024-11-04 15:55:19 [445,493ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_fixed_tendon_properties’ on any prims under: ‘/World/Origin2/Robot’. This might be because of the following reasons:
2024-11-04 15:55:19 [445,493ms] [Warning] [omni.isaac.lab.sim.utils] Could not perform ‘modify_joint_drive_properties’ on any prims under: ‘/World/Origin2/Robot’. This might be because of the following reasons:
File “/home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/asset_base.py”, line 92, in
lambda event, obj=weakref.proxy(self): obj._initialize_callback(event),
File “/home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/asset_base.py”, line 263, in _initialize_callback
self._initialize_impl()
File “/home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py”, line 895, in _initialize_impl
raise RuntimeError(
RuntimeError: Failed to find an articulation when resolving ‘/World/Origin1/Robot’. Please ensure that the prim has ‘USD ArticulationRootAPI’ applied.
raise RuntimeError(
RuntimeError: Failed to find an articulation when resolving ‘/World/Origin2/Robot’. Please ensure that the prim has ‘USD ArticulationRootAPI’ applied.
[INFO]: Setup complete…
File “/home/intel/IsaacLab/source/standalone/demos/hands.py”, line 164, in
main()
File “/home/intel/IsaacLab/source/standalone/demos/hands.py”, line 159, in main
run_simulator(sim, scene_entities, scene_origins)
File “/home/intel/IsaacLab/source/standalone/demos/hands.py”, line 114, in run_simulator
root_state = robot.data.default_root_state.clone()
File “/home/intel/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/assets/articulation/articulation.py”, line 107, in data
return self._data
AttributeError: ‘Articulation’ object has no attribute ‘_data’. Did you mean: ‘data’?
2024-11-04 15:55:20 [446,784ms] [Warning] [omni.graph.core.plugin] Could not find category ‘Replicator:Annotators’ for removal
2024-11-04 15:55:20 [446,784ms] [Warning] [omni.graph.core.plugin] Could not find category ‘Replicator:Core’ for removal
2024-11-04 15:55:20 [446,933ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
