Isaacsim 4.5 crash
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTX3090 and RTX3090
  • Driver Version: 570.86.15
Topic Description
Detailed Description
After installing isaacsim according to the documentation, when I run the command ‘./python.sh standalone_examples/tutorials/getting_started.py’ . the software crashes
Steps to Reproduce
  1. Entering the Isaacsim environment through Miniconda
  2. cd isaacsim
  3. ./python.sh standalone_examples/tutorials/getting_started.py
Error Messages
[5.534s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
2025-04-22 02:32:05 [5,638ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.core.simulation_manager’ in ‘/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager’ failed to load.
At:
/home/xcmg/isaacsim/kit/kernel/py/omni/ext/_impl/_internal.py(213): startup
/home/xcmg/isaacsim/kit/kernel/py/omni/ext/_impl/_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
/home/xcmg/isaacsim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py(427): _start_app
/home/xcmg/isaacsim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py(212): init
/home/xcmg/isaacsim/standalone_examples/tutorials/getting_started.py(13):
2025-04-22 02:32:05 [5,638ms] [Error] [omni.ext.plugin] [ext: isaacsim.core.simulation_manager-0.3.3] Failed to startup python extension.
[5.776s] [ext: omni.kit.scripting-106.5.2] startup
[5.784s] [ext: omni.kit.stage_templates-1.2.6] startup
[5.787s] [ext: isaacsim.core.prims-0.3.7] startup
2025-04-22 02:32:05 [5,780ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.core.prims. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/kit/kernel/py/omni/ext/_impl/custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “/home/xcmg/isaacsim/kit/python/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/home/xcmg/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/init.py”, line 10, in
from .impl import *
File “/home/xcmg/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/init.py”, line 10, in
from .articulation import Articulation
File “/home/xcmg/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 21, in
import torch
ModuleNotFoundError: No module named ‘torch’
2025-04-22 02:32:05 [5,780ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.core.prims’ in ‘/home/xcmg/isaacsim/exts/isaacsim.core.prims’ failed to load.
At:
2025-04-22 02:32:05 [5,780ms] [Error] [omni.ext.plugin] [ext: isaacsim.core.prims-0.3.7] Failed to startup python extension.
2025-04-22 02:32:05 [5,909ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.core.api. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/init.py”, line 11, in
from isaacsim.core.api.physics_context.physics_context import PhysicsContext
File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/physics_context/init.py”, line 9, in
File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/physics_context/physics_context.py”, line 13, in
from isaacsim.core.simulation_manager import SimulationManager
File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/init.py”, line 1, in
from .impl.extension import Extension
File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/init.py”, line 1, in
from .extension import *
File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/extension.py”, line 7, in
from .simulation_manager import SimulationManager
File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/simulation_manager.py”, line 6, in
import isaacsim.core.utils.torch as torch_utils
File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/torch/init.py”, line 9, in
from .maths import *
File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/torch/maths.py”, line 13, in
import torch
2025-04-22 02:32:05 [6,164ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.core.cloner’ in ‘/home/xcmg/isaacsim/exts/isaacsim.core.cloner’ failed to load.
At:
2025-04-22 02:32:06 [6,601ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.core’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.core’ failed to load.
At:
2025-04-22 02:32:06 [6,601ms] [Error] [omni.ext.plugin] [ext: omni.isaac.core-4.0.3] Failed to startup python extension.
[6.728s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-04-22 02:32:06 [6,721ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.core_nodes. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.core_nodes/omni/isaac/core_nodes/init.py”, line 11, in
from .impl import BaseResetNode, BaseWriterNode, WriterRequest
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.core_nodes/omni/isaac/core_nodes/impl/init.py”, line 15, in
from .base_writer_node import BaseWriterNode, WriterRequest
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.core_nodes/omni/isaac/core_nodes/impl/base_writer_node.py”, line 10, in
from isaacsim.core.nodes.impl.base_writer_node import BaseWriterNode, WriterRequest
File “/home/xcmg/isaacsim/exts/isaacsim.core.nodes/isaacsim/core/nodes/init.py”, line 9, in
from .impl import BaseResetNode, BaseWriterNode, Extension, WriterRequest
File “/home/xcmg/isaacsim/exts/isaacsim.core.nodes/isaacsim/core/nodes/impl/init.py”, line 15, in
File “/home/xcmg/isaacsim/exts/isaacsim.core.nodes/isaacsim/core/nodes/impl/base_writer_node.py”, line 14, in
File “/home/xcmg/isaacsim/extscache/omni.replicator.core-1.11.35+106.5.0.lx64.r.cp310/omni/replicator/core/init.py”, line 3, in
from .scripts import (
File “/home/xcmg/isaacsim/extscache/omni.replicator.core-1.11.35+106.5.0.lx64.r.cp310/omni/replicator/core/scripts/init.py”, line 3, in
from . import (
File “/home/xcmg/isaacsim/extscache/omni.replicator.core-1.11.35+106.5.0.lx64.r.cp310/omni/replicator/core/scripts/backends/init.py”, line 21, in
from .s3 import S3Backend
File “/home/xcmg/isaacsim/extscache/omni.replicator.core-1.11.35+106.5.0.lx64.r.cp310/omni/replicator/core/scripts/backends/s3.py”, line 22, in
from botocore.exceptions import ClientError, NoCredentialsError
ModuleNotFoundError: No module named ‘botocore’
2025-04-22 02:32:06 [6,721ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.core_nodes’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.core_nodes’ failed to load.
At:
2025-04-22 02:32:06 [6,873ms] [Error] [omni.ext.plugin] [ext: isaacsim.robot_motion.motion_generation-8.0.6] Failed to startup python extension.
[7.003s] [ext: isaacsim.asset.browser-1.3.4] startup
2025-04-22 02:32:06 [7,001ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.asset.browser. Error: No module named ‘urllib3.exceptions’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.asset.browser/isaacsim/asset/browser/init.py”, line 11, in
from .extension import AssetBrowserExtension, get_instance
File “/home/xcmg/isaacsim/exts/isaacsim.asset.browser/isaacsim/asset/browser/extension.py”, line 18, in
from .window import AssetBrowserWindow
File “/home/xcmg/isaacsim/exts/isaacsim.asset.browser/isaacsim/asset/browser/window.py”, line 18, in
from .delegate import AssetDetailDelegate
File “/home/xcmg/isaacsim/exts/isaacsim.asset.browser/isaacsim/asset/browser/delegate.py”, line 20, in
from .context_menu import ContextMenu
File “/home/xcmg/isaacsim/exts/isaacsim.asset.browser/isaacsim/asset/browser/context_menu.py”, line 16, in
import requests
File “/home/xcmg/isaacsim/exts/omni.pip.cloud/pip_prebundle/requests/init.py”, line 45, in
from .exceptions import RequestsDependencyWarning
File “/home/xcmg/isaacsim/exts/omni.pip.cloud/pip_prebundle/requests/exceptions.py”, line 7, in
from urllib3.exceptions import HTTPError as BaseHTTPError
ModuleNotFoundError: No module named ‘urllib3.exceptions’
2025-04-22 02:32:06 [7,001ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.asset.browser’ in ‘/home/xcmg/isaacsim/exts/isaacsim.asset.browser’ failed to load.
At:
2025-04-22 02:32:06 [7,131ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.robot_motion.lula_test_widget’ in ‘/home/xcmg/isaacsim/exts/isaacsim.robot_motion.lula_test_widget’ failed to load.
At:
2025-04-22 02:32:06 [7,131ms] [Error] [omni.ext.plugin] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] Failed to startup python extension.
[7.262s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-04-22 02:32:06 [7,254ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[7.265s] [ext: isaacsim.robot.manipulators-3.0.4] startup
2025-04-22 02:32:06 [7,264ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.robot.manipulators. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.robot.manipulators/isaacsim/robot/manipulators/init.py”, line 10, in
from .manipulators.single_manipulator import SingleManipulator
File “/home/xcmg/isaacsim/exts/isaacsim.robot.manipulators/isaacsim/robot/manipulators/manipulators/init.py”, line 11, in
from isaacsim.robot.manipulators.manipulators.single_manipulator import SingleManipulator
File “/home/xcmg/isaacsim/exts/isaacsim.robot.manipulators/isaacsim/robot/manipulators/manipulators/single_manipulator.py”, line 12, in
from isaacsim.core.prims import SingleArticulation, SingleRigidPrim
from .impl import *
import torch
2025-04-22 02:32:06 [7,264ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.robot.manipulators’ in ‘/home/xcmg/isaacsim/exts/isaacsim.robot.manipulators’ failed to load.
At:
2025-04-22 02:32:06 [7,264ms] [Error] [omni.ext.plugin] [ext: isaacsim.robot.manipulators-3.0.4] Failed to startup python extension.
[7.393s] [ext: isaacsim.sensors.physics-0.3.5] startup
2025-04-22 02:32:06 [7,391ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.physics. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/init.py”, line 10, in
from .scripts import *
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/scripts/init.py”, line 10, in
from .commands import *
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/scripts/commands.py”, line 15, in
from isaacsim.core.utils.prims import delete_prim
File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/prims.py”, line 25, in
from isaacsim.core.utils.types import SDF_type_to_Gf
File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/types.py”, line 12, in
import torch
2025-04-22 02:32:06 [7,392ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.physics’ in ‘/home/xcmg/isaacsim/exts/isaacsim.sensors.physics’ failed to load.
At:
2025-04-22 02:32:06 [7,392ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.physics-0.3.5] Failed to startup python extension.
[7.523s] [ext: isaacsim.gui.menu-2.0.9] startup
2025-04-22 02:32:07 [7,522ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.gui.menu. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.gui.menu/isaacsim/gui/menu/init.py”, line 10, in
File “/home/xcmg/isaacsim/exts/isaacsim.gui.menu/isaacsim/gui/menu/extension.py”, line 16, in
from .create_menu import CreateMenuExtension
File “/home/xcmg/isaacsim/exts/isaacsim.gui.menu/isaacsim/gui/menu/create_menu.py”, line 8, in
from isaacsim.core.utils.viewports import set_camera_view
File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/viewports.py”, line 19, in
from isaacsim.core.utils.prims import is_prim_path_valid, set_prim_hide_in_stage_window, set_prim_no_delete
import torch
2025-04-22 02:32:07 [7,522ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.gui.menu’ in ‘/home/xcmg/isaacsim/exts/isaacsim.gui.menu’ failed to load.
At:
2025-04-22 02:32:07 [7,522ms] [Error] [omni.ext.plugin] [ext: isaacsim.gui.menu-2.0.9] Failed to startup python extension.
[7.653s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-04-22 02:32:07 [7,648ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[7.659s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[7.671s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-04-22 02:32:07 [7,662ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-22 02:32:07 [7,662ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-22 02:32:07 [7,662ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-22 02:32:07 [7,664ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.manipulators. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.manipulators/omni/isaac/manipulators/init.py”, line 16, in
from .controllers import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.manipulators/omni/isaac/manipulators/controllers/init.py”, line 21, in
from .pick_place_controller import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.manipulators/omni/isaac/manipulators/controllers/pick_place_controller.py”, line 17, in
from isaacsim.robot.manipulators.controllers.pick_place_controller import *
from .impl import *
import torch
2025-04-22 02:32:07 [7,664ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.manipulators’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.manipulators’ failed to load.
At:
2025-04-22 02:32:07 [7,664ms] [Error] [omni.ext.plugin] [ext: omni.isaac.manipulators-3.0.3] Failed to startup python extension.
[7.794s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
2025-04-22 02:32:07 [7,786ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-22 02:32:07 [7,787ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-22 02:32:07 [7,787ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[7.799s] [ext: omni.isaac.menu-1.0.2] startup
2025-04-22 02:32:07 [7,792ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[7.802s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-04-22 02:32:07 [7,795ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-22 02:32:07 [7,798ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-22 02:32:07 [7,800ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.motion_generation. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.motion_generation/omni/isaac/motion_generation/init.py”, line 24, in
from .articulation_kinematics_solver import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.motion_generation/omni/isaac/motion_generation/articulation_kinematics_solver.py”, line 16, in
from isaacsim.robot_motion.motion_generation.articulation_kinematics_solver import *
File “/home/xcmg/isaacsim/exts/isaacsim.robot_motion.motion_generation/isaacsim/robot_motion/motion_generation/init.py”, line 10, in
from isaacsim.robot_motion.motion_generation.articulation_kinematics_solver import ArticulationKinematicsSolver
File “/home/xcmg/isaacsim/exts/isaacsim.robot_motion.motion_generation/isaacsim/robot_motion/motion_generation/articulation_kinematics_solver.py”, line 14, in
from isaacsim.core.api.articulations import ArticulationSubset
import torch
2025-04-22 02:32:07 [7,800ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.motion_generation’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.motion_generation’ failed to load.
At:
2025-04-22 02:32:07 [7,800ms] [Error] [omni.ext.plugin] [ext: omni.isaac.motion_generation-8.0.2] Failed to startup python extension.
[7.930s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
2025-04-22 02:32:07 [7,922ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-22 02:32:07 [7,922ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[7.934s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-04-22 02:32:07 [7,924ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-04-22 02:32:07 [7,925ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[7.935s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-04-22 02:32:07 [7,926ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[7.937s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[7.941s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[7.943s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[7.950s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[7.955s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
2025-04-22 02:32:07 [7,947ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.robot.manipulators.examples. Error: No module named ‘torch’. Traceback:
File “”, line 992, in _find_and_load_unlocked
from .impl import *
import torch
2025-04-22 02:32:07 [7,947ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.robot.manipulators.examples’ in ‘/home/xcmg/isaacsim/exts/isaacsim.robot.manipulators.examples’ failed to load.
At:
2025-04-22 02:32:07 [7,947ms] [Error] [omni.ext.plugin] [ext: isaacsim.robot.manipulators.examples-1.0.3] Failed to startup python extension.
[8.078s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[8.085s] [ext: omni.sensors.tiled-0.0.6] startup
[8.089s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[8.096s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[8.104s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[8.109s] [ext: isaacsim.sensors.physx-2.2.4] startup
2025-04-22 02:32:07 [8,107ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.physx. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physx/isaacsim/sensors/physx/init.py”, line 10, in
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physx/isaacsim/sensors/physx/scripts/init.py”, line 13, in
from .rotating_lidar_physX import RotatingLidarPhysX
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.physx/isaacsim/sensors/physx/scripts/rotating_lidar_physX.py”, line 15, in
from isaacsim.core.api.sensors.base_sensor import BaseSensor
import torch
2025-04-22 02:32:07 [8,107ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.physx’ in ‘/home/xcmg/isaacsim/exts/isaacsim.sensors.physx’ failed to load.
At:
2025-04-22 02:32:07 [8,107ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.physx-2.2.4] Failed to startup python extension.
[8.238s] [ext: isaacsim.sensors.rtx-13.6.3] startup
2025-04-22 02:32:07 [8,236ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.rtx. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.rtx/isaacsim/sensors/rtx/init.py”, line 10, in
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.rtx/isaacsim/sensors/rtx/scripts/init.py”, line 10, in
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.rtx/isaacsim/sensors/rtx/scripts/commands.py”, line 17, in
import torch
2025-04-22 02:32:07 [8,236ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.rtx’ in ‘/home/xcmg/isaacsim/exts/isaacsim.sensors.rtx’ failed to load.
At:
2025-04-22 02:32:07 [8,236ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.rtx-13.6.3] Failed to startup python extension.
[8.262s] [ext: isaacsim.sensors.camera-0.2.9] startup
2025-04-22 02:32:07 [8,261ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.camera. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.camera/isaacsim/sensors/camera/init.py”, line 10, in
from .camera import *
File “/home/xcmg/isaacsim/exts/isaacsim.sensors.camera/isaacsim/sensors/camera/camera.py”, line 17, in
from . import (
2025-04-22 02:32:07 [8,261ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.camera’ in ‘/home/xcmg/isaacsim/exts/isaacsim.sensors.camera’ failed to load.
At:
2025-04-22 02:32:07 [8,261ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.camera-0.2.9] Failed to startup python extension.
[8.394s] [ext: isaacsim.cortex.framework-1.0.2] startup
[8.397s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[8.408s] [ext: omni.isaac.range_sensor-4.0.2] startup
[8.411s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-04-22 02:32:07 [8,403ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[8.413s] [ext: omni.isaac.sensor-13.0.3] startup
2025-04-22 02:32:07 [8,405ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-22 02:32:07 [8,405ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-04-22 02:32:07 [8,407ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.sensor. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.sensor/omni/isaac/sensor/init.py”, line 19, in
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.sensor/omni/isaac/sensor/camera.py”, line 19, in
from isaacsim.sensors.camera import (
from . import (
2025-04-22 02:32:07 [8,407ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.sensor’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.sensor’ failed to load.
At:
2025-04-22 02:32:07 [8,407ms] [Error] [omni.ext.plugin] [ext: omni.isaac.sensor-13.0.3] Failed to startup python extension.
[8.541s] [ext: omni.isaac.cortex-1.0.2] startup
2025-04-22 02:32:08 [8,533ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-04-22 02:32:08 [8,534ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-22 02:32:08 [8,534ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
[8.544s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[8.552s] [ext: omni.debugdraw-0.1.3] startup
2025-04-22 02:32:08 [8,543ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-22 02:32:08 [8,543ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-04-22 02:32:08 [8,548ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-22 02:32:08 [8,548ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
[8.561s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-04-22 02:32:08 [8,552ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-04-22 02:32:08 [8,552ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-04-22 02:32:08 [8,555ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-22 02:32:08 [8,555ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-04-22 02:32:08 [8,557ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.universal_robots. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.universal_robots/omni/isaac/universal_robots/init.py”, line 20, in
from .kinematics_solver import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.universal_robots/omni/isaac/universal_robots/kinematics_solver.py”, line 17, in
from isaacsim.robot.manipulators.examples.universal_robots.kinematics_solver import *
from .impl import *
import torch
2025-04-22 02:32:08 [8,557ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.universal_robots’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.universal_robots’ failed to load.
At:
2025-04-22 02:32:08 [8,557ms] [Error] [omni.ext.plugin] [ext: omni.isaac.universal_robots-1.0.2] Failed to startup python extension.
[8.692s] [ext: omni.isaac.utils-2.0.2] startup
2025-04-22 02:32:08 [8,684ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-04-22 02:32:08 [8,684ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[8.696s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[8.704s] [ext: omni.fabric.commands-1.1.5] startup
[8.707s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[8.710s] [ext: omni.kit.viewport.actions-107.0.0] startup
[8.715s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[8.717s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[8.720s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[8.722s] [ext: omni.kit.widget.layers-1.8.2] startup
[8.736s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[8.739s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[8.740s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-04-22 02:32:08 [8,730ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[8.740s] [ext: omni.graph.ui_nodes-1.40.1] startup
[8.746s] [ext: omni.usdphysics.ui-106.5.7] startup
[8.781s] [ext: omni.physx.commands-106.5.7] startup
[8.788s] [ext: omni.kit.property.camera-1.0.9] startup
[8.790s] [ext: omni.hydra.scene_api-0.1.2] startup
[8.796s] [ext: omni.kit.property.geometry-1.3.3] startup
[8.800s] [ext: omni.kit.property.light-1.0.11] startup
[8.802s] [ext: omni.physx.ui-106.5.7] startup
[8.835s] [ext: omni.kit.property.material-1.10.17] startup
[8.842s] [ext: omni.kit.property.render-1.1.3] startup
[8.844s] [ext: omni.kit.property.transform-1.5.10] startup
[8.848s] [ext: omni.kit.property.audio-1.0.16] startup
[8.850s] [ext: isaacsim.gui.property-1.0.4] startup
[8.853s] [ext: omni.physx.demos-106.5.7] startup
[8.873s] [ext: omni.kit.property.physx-106.5.7] startup
[8.918s] [ext: omni.isaac.lula-4.0.2] startup
2025-04-22 02:32:08 [8,910ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[8.920s] [ext: omni.kit.property.bundle-1.3.2] startup
[8.922s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-04-22 02:32:08 [8,913ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-04-22 02:32:08 [8,913ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[8.924s] [ext: omni.physx.vehicle-106.5.7] startup
[8.946s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[8.953s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[8.957s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[8.960s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[8.965s] [ext: omni.kit.window.console-0.2.14] startup
[8.975s] [ext: omni.physx.camera-106.5.7] startup
[8.988s] [ext: omni.kit.window.toolbar-1.6.2] startup
[8.992s] [ext: omni.isaac.version-2.0.2] startup
2025-04-22 02:32:08 [8,983ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[8.994s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
2025-04-22 02:32:08 [8,987ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.robot.wheeled_robots. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.robot.wheeled_robots/isaacsim/robot/wheeled_robots/init.py”, line 9, in
File “/home/xcmg/isaacsim/exts/isaacsim.robot.wheeled_robots/isaacsim/robot/wheeled_robots/controllers/init.py”, line 9, in
from .ackermann_controller import AckermannController
File “/home/xcmg/isaacsim/exts/isaacsim.robot.wheeled_robots/isaacsim/robot/wheeled_robots/controllers/ackermann_controller.py”, line 13, in
from isaacsim.core.api.controllers.base_controller import BaseController
import torch
2025-04-22 02:32:08 [8,987ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.robot.wheeled_robots’ in ‘/home/xcmg/isaacsim/exts/isaacsim.robot.wheeled_robots’ failed to load.
At:
2025-04-22 02:32:08 [8,987ms] [Error] [omni.ext.plugin] [ext: isaacsim.robot.wheeled_robots-4.0.3] Failed to startup python extension.
[9.147s] [ext: omni.physx.cct-106.5.7] startup
[9.165s] [ext: omni.physx.graph-106.5.7] startup
[9.191s] [ext: isaacsim.replicator.writers-1.0.1] startup
2025-04-22 02:32:08 [9,190ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.replicator.writers. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.writers/isaacsim/replicator/writers/init.py”, line 11, in
from .scripts import DataVisualizationWriter, DOPEWriter, PoseWriter, PytorchListener, PytorchWriter, YCBVideoWriter
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.writers/isaacsim/replicator/writers/scripts/init.py”, line 9, in
from .writers.data_visualization_writer import DataVisualizationWriter
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.writers/isaacsim/replicator/writers/scripts/writers/init.py”, line 10, in
from .data_visualization_writer import *
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.writers/isaacsim/replicator/writers/scripts/writers/data_visualization_writer.py”, line 12, in
from omni.replicator.core import AnnotatorRegistry, BackendDispatch, Writer
from . import (
2025-04-22 02:32:08 [9,190ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.replicator.writers’ in ‘/home/xcmg/isaacsim/exts/isaacsim.replicator.writers’ failed to load.
At:
2025-04-22 02:32:08 [9,190ms] [Error] [omni.ext.plugin] [ext: isaacsim.replicator.writers-1.0.1] Failed to startup python extension.
[9.355s] [ext: omni.physx.supportui-106.5.7] startup
[9.375s] [ext: omni.physx.telemetry-106.5.7] startup
[9.381s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-04-22 02:32:08 [9,371ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:08 [9,373ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:08 [9,373ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:08 [9,376ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.wheeled_robots. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.wheeled_robots/omni/isaac/wheeled_robots/init.py”, line 21, in
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.wheeled_robots/omni/isaac/wheeled_robots/controllers/init.py”, line 21, in
from .ackermann_controller import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.wheeled_robots/omni/isaac/wheeled_robots/controllers/ackermann_controller.py”, line 17, in
from isaacsim.robot.wheeled_robots.controllers.ackermann_controller_deprecated import *
import torch
2025-04-22 02:32:08 [9,376ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.wheeled_robots’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.wheeled_robots’ failed to load.
At:
2025-04-22 02:32:08 [9,376ms] [Error] [omni.ext.plugin] [ext: omni.isaac.wheeled_robots-3.0.3] Failed to startup python extension.
[9.537s] [ext: omni.isaac.franka-1.0.2] startup
2025-04-22 02:32:09 [9,530ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:09 [9,530ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-22 02:32:09 [9,531ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:09 [9,531ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-22 02:32:09 [9,532ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-22 02:32:09 [9,537ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.franka. Error: No module named ‘torch’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.franka/omni/isaac/franka/init.py”, line 23, in
from .franka import *
File “/home/xcmg/isaacsim/extsDeprecated/omni.isaac.franka/omni/isaac/franka/franka.py”, line 16, in
from isaacsim.robot.manipulators.examples.franka.franka import *
from .impl import *
import torch
2025-04-22 02:32:09 [9,537ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.franka’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.isaac.franka’ failed to load.
At:
2025-04-22 02:32:09 [9,537ms] [Error] [omni.ext.plugin] [ext: omni.isaac.franka-1.0.2] Failed to startup python extension.
[9.554s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
2025-04-22 02:32:09 [9,547ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-22 02:32:09 [9,547ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-22 02:32:09 [9,551ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.replicator.domain_randomization. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.domain_randomization/isaacsim/replicator/domain_randomization/init.py”, line 11, in
from .scripts import context, gate, physics_view, trigger, utils
File “/home/xcmg/isaacsim/exts/isaacsim.replicator.domain_randomization/isaacsim/replicator/domain_randomization/scripts/context.py”, line 10, in
from omni.replicator.core.utils import utils
from . import (
2025-04-22 02:32:09 [9,551ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.replicator.domain_randomization’ in ‘/home/xcmg/isaacsim/exts/isaacsim.replicator.domain_randomization’ failed to load.
At:
2025-04-22 02:32:09 [9,551ms] [Error] [omni.ext.plugin] [ext: isaacsim.replicator.domain_randomization-1.0.2] Failed to startup python extension.
[9.711s] [ext: isaacsim.replicator.examples-1.1.2] startup
[9.716s] [ext: omni.kit.window.status_bar-0.1.7] startup
[9.724s] [ext: omni.rtx.window.settings-0.6.17] startup
[9.732s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[9.743s] [ext: omni.physx.bundle-106.5.7] startup
[9.744s] [ext: isaacsim.app.about-2.0.7] startup
[9.745s] [ext: omni.replicator.isaac-2.0.3] startup
2025-04-22 02:32:09 [9,735ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
2025-04-22 02:32:09 [9,736ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.replicator.isaac. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/extsDeprecated/omni.replicator.isaac/omni/replicator/isaac/init.py”, line 21, in
from isaacsim.replicator.domain_randomization.scripts import context, gate, physics_view, trigger, utils
from . import (
2025-04-22 02:32:09 [9,736ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.replicator.isaac’ in ‘/home/xcmg/isaacsim/extsDeprecated/omni.replicator.isaac’ failed to load.
At:
2025-04-22 02:32:09 [9,737ms] [Error] [omni.ext.plugin] [ext: omni.replicator.isaac-2.0.3] Failed to startup python extension.
[9.898s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
2025-04-22 02:32:09 [9,891ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
2025-04-22 02:32:09 [9,892ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.replicator.replicator_yaml. Error: No module named ‘botocore’. Traceback:
File “/home/xcmg/isaacsim/extscache/omni.replicator.replicator_yaml-2.0.10+lx64/omni/replicator/replicator_yaml/init.py”, line 1, in
from .scripts.parser import ParserError, parse
File “/home/xcmg/isaacsim/extscache/omni.replicator.replicator_yaml-2.0.10+lx64/omni/replicator/replicator_yaml/scripts/parser.py”, line 18, in
from . import (
2025-04-22 02:32:09 [9,892ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.replicator.replicator_yaml’ in ‘/home/xcmg/isaacsim/extscache/omni.replicator.replicator_yaml-2.0.10+lx64’ failed to load.
At:
2025-04-22 02:32:09 [9,892ms] [Error] [omni.ext.plugin] [ext: omni.replicator.replicator_yaml-2.0.10] Failed to startup python extension.
[10.054s] [ext: omni.rtx.settings.core-0.6.3] startup
[10.059s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[10.064s] [ext: isaacsim.simulation_app-2.4.2] startup
[10.065s] [ext: omni.isaac.window.about-2.0.2] startup
2025-04-22 02:32:09 [10,056ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-04-22 02:32:09 [10,057ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[10.067s] [ext: semantics.schema.editor-0.3.10] startup
[10.070s] [ext: omni.kit.ui.actions-1.0.2] startup
[10.074s] [ext: semantics.schema.property-1.0.5] startup
[10.075s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[10.080s] [ext: omni.isaac.kit-2.0.3] startup
2025-04-22 02:32:09 [10,070ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[10.080s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-04-22 02:32:09 [10,071ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[10.081s] [ext: isaacsim.core.throttling-2.0.2] startup
[10.084s] [ext: omni.kit.menu.common-1.1.9] startup
[10.086s] [ext: isaacsim.exp.base-4.5.0] startup
[10.087s] [ext: isaacsim.exp.base.python-4.5.0] startup
[10.089s] Simulation App Starting
[10.385s] app ready
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7508933632
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7433845248
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9574251 (slope: 447, intercept: 13179904)
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287216384
2025-04-22 02:32:09 [10,423ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-04-22 02:32:10 [10,661ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults-transient/meshlights/forceDisable’
2025-04-22 02:32:10 [10,766ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/post/dlss/execMode’
[15.845s] Simulation App Startup Complete
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/standalone_examples/tutorials/getting_started.py”, line 16, in
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: from isaacsim.core.api import World
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/init.py”, line 11, in
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: from isaacsim.core.api.physics_context.physics_context import PhysicsContext
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/physics_context/init.py”, line 9, in
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/physics_context/physics_context.py”, line 13, in
2025-04-22 02:32:15 [15,837ms] [Error] [omni.kit.app._impl] [py stderr]: from isaacsim.core.simulation_manager import SimulationManager
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/init.py”, line 1, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: from .impl.extension import Extension
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/init.py”, line 1, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: from .extension import *
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/extension.py”, line 7, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: from .simulation_manager import SimulationManager
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.simulation_manager/isaacsim/core/simulation_manager/impl/simulation_manager.py”, line 6, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: import isaacsim.core.utils.torch as torch_utils
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/torch/init.py”, line 9, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: from .maths import *
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: File “/home/xcmg/isaacsim/exts/isaacsim.core.utils/isaacsim/core/utils/torch/maths.py”, line 13, in
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: import torch
2025-04-22 02:32:15 [15,838ms] [Error] [omni.kit.app._impl] [py stderr]: ModuleNotFoundError: No module named ‘torch’
2025-04-22 02:32:15 [15,866ms] [Warning] [omni.graph.core.plugin] Could not find category ‘animation’ for removal
2025-04-22 02:32:15 [15,867ms] [Warning] [omni.fabric.plugin] gFabricState->gUsdStageToSimStageWithHistoryMap had 1 outstanding SimStageWithHistory(s) at shutdown
2025-04-22 02:32:15 [15,867ms] [Warning] [carb.audio.context] 1 contexts were leaked
2025-04-22 02:32:15 [15,954ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Additional Context
Remind me that I am missing some packages(torch)
But I installed it.
torch 2.5.1+cu118 pypi_0 pypi
Are you installing Isaac Sim by following the instructions in Python Environment Installation — Isaac Sim Documentation? If so, are you following Python Environment Installation — Isaac Sim Documentation to run Isaac Sim?
Could you upload the full .log file?
I operated according to the linked document,But I am using the version driver 570.86.15.
Should I submit the Isaac sim log file or the Conda environment log file
i think the full kit log from 4.5.0 should be a good starting point for the devs/mods:
Linux: ~/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5
log.zip (824.0 KB)
Did you set up by following Python Environment Installation — Isaac Sim Documentation or any documentation in Isaac Lab?
Hello!
Best regards,
