IsaacSim Editor unable to start
I downloaded the Isaac SDK 2019.2 and the Isaac Sim 1.2 and followed all the instructions here at least 3 separate times:
https://docs.nvidia.com/isaac/isaac_sim/quickstart.html
However, each time, after starting the Isaac Sim Editor, waiting for all the shaders to compile, and attempting to press play on the editor interface, I get the following error:
[2020.01.25-03.26.42:710][585]LogShaderCompilers: Display: Shaders left to compile 3
[2020.01.25-03.31.14:656][408]LogVulkanRHI: Error: VulkanRHI::vkQueueSubmit(Queue, 1, &SubmitInfo, Fence->GetHandle()) failed, VkResult=-4
at /home/poxter/UnrealEngine/Engine/Source/Runtime/VulkanRHI/Private/VulkanQueue.cpp:67
with error VK_ERROR_DEVICE_LOST
Fatal error: [File:/home/poxter/UnrealEngine/Engine/Source/Runtime/VulkanRHI/Private/VulkanUtil.cpp] [Line: 609]
Signal 11 caught.
Malloc Size=131076 LargeMemoryPoolOffset=131092
CommonUnixCrashHandler: Signal=11
Malloc Size=65535 LargeMemoryPoolOffset=196655
Malloc Size=1285472 LargeMemoryPoolOffset=1482144
Malloc Size=68112 LargeMemoryPoolOffset=1550272
Malloc Size=166630 LargeMemoryPoolOffset=1716918
LogPlatformFile: Not using cached read wrapper
LogTaskGraph: Started task graph with 4 named threads and 11 total threads with 1 sets of task threads.
This seems to be a similar issue to https://devtalk.nvidia.com/default/topic/1068687/vk_error_device_lost-please-help/
but I would prefer a solution that does not require switching from Unreal Engine.
Update: Changing the system-wide open file limit to 250000 and then to 500000 increased the amount of time I was able to spend in the editor before it crashed (around 45 seconds). I am not sure whether I should increase it more since the Build Readme file says that UE4 only needs around 16000.
Hi generalpoxter, can you please try with isaac SDK 2019.3?
