IsaacSim installation using outdated driver version
Isaac Sim Version
5.0.0
☑ 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
☑ Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 4080
  • Driver Version: 535.261.03
I am trying to do a workstation installation of IsaacSim 4.5.0. After checking compatibility with no issues, I installed IsaacSim as per the installation directions. When I run nvidia-smi, the output is:
| NVIDIA-SMI 535.261.03 Driver Version: 535.261.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4080 … On | 00000000:01:00.0 Off | N/A |
| 0% 36C P8 11W / 320W | 234MiB / 16376MiB | 0% Default |
| | | N/A |
This matches with the version detected in the compatibility checker. However, when I run isaac-sim.sh, the following output regarding the driver version is generated:
| Driver Version: 535.05.03 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4080 SUPER | Yes: 0 | | 16376 MB | 10de | 0 |
| | | | | | 2702 | 7c1db92d.. |
| | | | | | 1 | |
| OS: 20.04.6 LTS (Focal Fossa) ubuntu, Version: 20.04.6, Kernel: 5.15.0-139-generic
| Processor: AMD Ryzen 9 7900X 12-Core Processor
| Cores: 12 | Logical Cores: 24
| Total Memory (MB): 63470 | Free Memory: 13861
| Total Page/Swap (MB): 2047 | Free Page/Swap: 17592186044413
2025-08-15 18:20:34 \[8,533ms\] \[Error\] \[gpu.foundation.plugin\] The currently installed NVIDIA graphics driver is unsupported or has known issues.
Reason for failure: The minimum Omniverse RTX requirement
Installed driver: 535.5
The unsupported driver range: [0.0, 535.129)
The recommended drivers: 535.129.03 (GameReady, Studio, RTX/Quadro, Grid/vGPU)
The latest driver version may also work but is not fully tested.
2025-08-15 18:20:34 [8,533ms] [Error] [carb.scenerenderer-rtx.plugin] rtx driver verification failed.
What I’ve Tried
I cannot find any extraneous 535.05 driver installations on my system that this might be loaded from. How can I resolve this issue?
Please try installing Isaac Sim 5.0 by following the instructions on Installation — Isaac Sim Documentation. If you still encoutner any issues, please provide the full log.
Unfortunately, I’m running on Ubuntu 20.04, which appears to be below the minimum requirement for Isaac Sim 5.0.
When I run the Isaac Sim Compatibility Checker, the results look as follows:
I then follow the Workstation Installation instructions. After running the ./post_install.sh and ./isaac-sim.selector.sh, the application launches, with some errors and warnings. If I continue through the tutorial, adding a ground plane, cube, and lighting source, nothing renders in the scene, which remains completely black.
The full log when running isaac-sim.selector.sh:
Loading user config located at: ‘/home/czeitler/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/user.config.json’
[Info] [carb] Logging to file: /home/czeitler/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250819_134005.log
[0.101s] [ext: omni.kit.async_engine-0.0.1] startup
[0.462s] [ext: omni.metrics.core-0.0.1] startup
[0.463s] [ext: omni.client.lib-1.0.0] startup
[0.479s] [ext: omni.blobkey-1.1.2] startup
[0.479s] [ext: omni.stats-1.0.1] startup
[0.480s] [ext: omni.datastore-0.0.0] startup
[0.483s] [ext: omni.client-1.2.2] startup
[0.487s] [ext: omni.ujitso.default-1.0.0] startup
[0.488s] [ext: omni.hsscclient-1.1.1] startup
2025-08-19 18:40:06 [472ms] [Warning] [omni.datastore] OmniHub is inaccessible
[0.490s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.492s] [ext: omni.assets.plugins-0.0.0] startup
[0.493s] [ext: omni.gpu_foundation-0.0.0] startup
[0.498s] [ext: carb.windowing.plugins-1.0.0] startup
[0.505s] [ext: omni.kit.renderer.init-0.0.0] startup
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 2702 | 7c1db92d.. |
| | | | | | 1 | |
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Total Memory (MB): 63470 | Free Memory: 8761
| Total Page/Swap (MB): 2047 | Free Page/Swap: 17592186044414
2025-08-19 18:40:06 [826ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled.
[0.975s] [ext: omni.kit.pipapi-0.0.0] startup
[0.976s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.976s] [ext: omni.pip.compute-1.4.5] startup
[0.977s] [ext: omni.pip.cloud-1.1.7] startup
[0.979s] [ext: omni.isaac.core_archive-2.3.3] startup
[0.979s] [ext: omni.materialx.libs-1.0.6] startup
[0.984s] [ext: omni.isaac.ml_archive-2.1.2] startup
[0.984s] [ext: omni.usd.config-1.0.5] startup
[0.987s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.987s] [ext: omni.usd.libs-1.0.1] startup
[1.034s] [ext: omni.kit.telemetry-0.5.1] startup
[1.053s] [ext: omni.mdl-55.0.1] startup
[1.070s] [ext: omni.iray.libs-0.0.0] startup
[1.074s] [ext: omni.mdl.neuraylib-0.2.10] startup
[1.075s] [ext: omni.kit.usd.mdl-1.0.7] startup
[1.146s] [ext: omni.kit.loop-isaac-1.2.1] startup
[1.147s] [ext: omni.kit.test-1.1.2] startup
[1.184s] [ext: omni.appwindow-1.1.9] startup
[1.553s] [ext: omni.kit.renderer.core-1.0.2] startup
[2.087s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.089s] [ext: omni.kit.renderer.imgui-1.0.2] startup
[2.184s] [ext: omni.ui-2.26.5] startup
[2.191s] [ext: omni.kit.mainwindow-1.0.3] startup
[2.192s] [ext: carb.audio-0.1.0] startup
[2.216s] [ext: omni.uiaudio-1.0.0] startup
[2.217s] [ext: omni.kit.uiapp-0.0.0] startup
[2.217s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[2.225s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.227s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.229s] [ext: isaacsim.robot.schema-3.1.2] startup
[2.233s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.237s] [ext: omni.anim.graph.schema-106.5.0] startup
[2.241s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.253s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.254s] [ext: omni.usd_resolver-1.0.0] startup
[2.256s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[2.260s] [ext: usdrt.scenegraph-7.5.1] startup
[2.284s] [ext: omni.timeline-1.0.11] startup
[2.286s] [ext: omni.usd.core-1.4.2] startup
[2.287s] [ext: omni.resourcemonitor-107.0.0] startup
[2.289s] [ext: omni.activity.core-1.0.1] startup
[2.290s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[2.291s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[2.297s] [ext: omni.kit.actions.core-1.0.0] startup
[2.298s] [ext: omni.graph.exec-0.9.4] startup
[2.299s] [ext: omni.kit.commands-1.4.9] startup
[2.301s] [ext: omni.kit.usd_undo-0.1.8] startup
[2.301s] [ext: omni.kit.exec.core-0.13.4] startup
[2.302s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[2.303s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[2.306s] [ext: omni.usd-1.12.4] startup
[2.327s] [ext: omni.inspect-1.0.1] startup
[2.327s] [ext: omni.kit.notification_manager-1.0.9] startup
[2.328s] [ext: omni.graph.core-2.181.8] startup
[2.330s] [ext: isaacsim.core.deprecation_manager-0.2.2] startup
[2.333s] [ext: omni.usd.schema.forcefield-106.5.7] startup
[2.339s] [ext: omni.kit.asset_converter-2.8.3] startup
[2.348s] [ext: omni.usd.schema.isaac-3.0.2] startup
[2.348s] [ext: omni.anim.navigation.schema-106.4.0] startup
[2.350s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[2.351s] [ext: omni.usd.schema.physx-106.5.7] startup
[2.367s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.370s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[2.372s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[2.372s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[2.373s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[2.374s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[2.375s] [ext: omni.kit.widget.path_field-2.0.11] startup
[2.375s] [ext: omni.kit.search_core-1.0.6] startup
[2.376s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[2.379s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[2.381s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[2.381s] [ext: omni.graph.tools-1.79.1] startup
[2.397s] [ext: omni.kit.widget.search_delegate-1.0.6] startup
[2.399s] [ext: omni.kit.widget.options_button-1.0.3] startup
[2.399s] [ext: omni.kit.clipboard-1.0.5] startup
[2.400s] [ext: omni.graph-1.140.2] startup
[2.478s] [ext: omni.kit.menu.core-1.1.2] startup
[2.478s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[2.479s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[2.481s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[2.482s] [ext: omni.ui.scene-1.11.2] startup
[2.485s] [ext: omni.kit.widget.versioning-1.4.9] startup
[2.487s] [ext: omni.kit.usd.layers-2.2.0] startup
[2.492s] [ext: omni.kit.window.filepicker-2.11.7] startup
[2.499s] [ext: omni.kit.widget.filter-1.1.4] startup
[2.501s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[2.503s] [ext: omni.kit.context_menu-1.8.3] startup
[2.505s] [ext: omni.kit.window.file_importer-1.1.14] startup
[2.507s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[2.508s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[2.510s] [ext: omni.kit.stage_template.core-1.1.22] startup
[2.511s] [ext: omni.kit.widget.stage-2.11.6] startup
[2.518s] [ext: omni.hydra.engine.stats-1.0.3] startup
[2.521s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[2.522s] [ext: omni.kit.window.file-1.3.57] startup
[2.524s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[2.525s] [ext: omni.index.libs-380600.1777.0] startup
[2.525s] [ext: omni.volume-0.5.0] startup
[2.529s] [ext: omni.ujitso.client-0.0.0] startup
[2.529s] [ext: omni.index-1.0.1] startup
[2.530s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[2.530s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[2.531s] [ext: omni.hydra.rtx-1.0.0] startup
2025-08-19 18:40:08 [2,519ms] [Warning] [omni.log] Source: omni.hydra was already registered.
[2.543s] [ext: omni.kit.viewport.registry-104.0.6] startup
[2.543s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[2.545s] [ext: omni.kit.raycast.query-1.0.5] startup
[2.548s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[2.551s] [ext: omni.kit.hydra_texture-1.4.0] startup
[2.553s] [ext: omni.kit.menu.utils-1.7.7] startup
[2.557s] [ext: omni.kit.window.drop_support-1.0.4] startup
[2.558s] [ext: omni.kit.widget.viewport-107.0.7] startup
[2.561s] [ext: omni.kit.material.library-1.5.15] startup
[2.565s] [ext: omni.convexdecomposition-106.5.7] startup
[2.568s] [ext: omni.kit.viewport.window-107.0.8] startup
[2.580s] [ext: omni.kit.window.property-1.11.5] startup
[2.582s] [ext: omni.kit.window.content_browser-2.10.3] startup
[2.593s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[2.594s] [ext: omni.kit.widget.prompt-1.0.7] startup
[2.595s] [ext: omni.kit.widget.settings-1.2.2] startup
[2.597s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[2.598s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[2.601s] [ext: omni.usdphysics-106.5.7] startup
[2.603s] [ext: omni.kvdb-106.5.7] startup
[2.604s] [ext: omni.kit.window.preferences-1.7.0] startup
[2.608s] [ext: omni.physx.foundation-106.5.7] startup
[2.609s] [ext: omni.localcache-106.5.7] startup
[2.610s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[2.612s] [ext: omni.physx.cooking-106.5.7] startup
[2.617s] [ext: omni.kit.viewport.utility-1.0.18] startup
[2.618s] [ext: omni.kit.property.usd-4.2.16] startup
[2.624s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[2.626s] [ext: omni.physx-106.5.7] startup
[2.634s] [ext: omni.ui_query-1.1.7] startup
[2.636s] [ext: omni.kit.window.extensions-1.4.25] startup
[2.640s] [ext: omni.graph.action_core-1.1.7] startup
[2.641s] [ext: isaacsim.core.version-2.0.2] startup
[2.643s] [ext: omni.graph.ui-1.91.0] startup
[2.655s] [ext: omni.physx.stageupdate-106.5.7] startup
[2.659s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.662s] [ext: isaacsim.storage.native-1.0.6] startup
[2.663s] [ext: omni.graph.action_nodes-1.40.1] startup
[2.666s] [ext: omni.isaac.dynamic_control-1.3.15] startup
2025-08-19 18:40:08 [2,657ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[2.675s] [ext: omni.kit.window.cursor-1.1.4] startup
[2.678s] [ext: omni.graph.image.core-0.6.0] startup
[2.679s] [ext: omni.physics.tensors-106.5.7] startup
[2.685s] [ext: omni.warp.core-1.5.0] startup
[2.801s] [ext: omni.graph.image.nodes-1.3.0] startup
[2.803s] [ext: omni.physx.tensors-106.5.7] startup
[2.809s] [ext: isaacsim.core.utils-2.2.8] startup
[2.823s] [ext: omni.graph.action-1.120.0] startup
[2.829s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[2.844s] [ext: omni.graph.nodes-1.162.1] startup
[2.851s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
[3.744s] [ext: omni.kit.widget.graph-1.12.17] startup
[3.749s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[3.750s] [ext: omni.warp-1.5.0] startup
[3.755s] [ext: omni.syntheticdata-0.6.10] startup
[3.776s] [ext: isaacsim.core.prims-0.3.7] startup
[3.806s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[3.811s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[3.863s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[3.870s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[3.877s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[3.895s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[3.900s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[3.904s] [ext: omni.kit.window.stage-2.5.11] startup
[3.907s] [ext: omni.kit.ui_test-1.3.3] startup
[3.909s] [ext: omni.kit.window.material_graph-1.8.19] startup
[3.921s] [ext: omni.kit.stage_templates-1.2.6] startup
[3.924s] [ext: omni.kit.menu.stage-1.2.5] startup
[3.925s] [ext: omni.graph.scriptnode-1.40.1] startup
[3.927s] [ext: isaacsim.gui.components-1.0.9] startup
[3.931s] [ext: isaacsim.core.api-4.2.16] startup
[3.950s] [ext: omni.replicator.core-1.11.35] startup
Warp 1.5.0 initialized:
CUDA Toolkit 11.8, Driver 12.2
Devices:
“cpu” : “x86_64”
“cuda:0” : “NVIDIA GeForce RTX 4080 SUPER” (16 GiB, sm_89, mempool enabled)
Kernel cache:
/home/czeitler/.cache/warp/1.5.0
2025-08-19 18:40:09 [3,996ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[4.015s] [ext: isaacsim.robot_motion.lula-4.0.4] startup
[4.022s] [ext: isaacsim.robot.surface_gripper-2.0.6] startup
[4.028s] [ext: isaacsim.core.nodes-2.1.4] startup
[4.037s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[4.048s] [ext: isaacsim.robot_motion.motion_generation-8.0.6] startup
[4.094s] [ext: isaacsim.robot.manipulators-3.0.4] startup
[4.124s] [ext: omni.kit.usd.collect-2.2.22] startup
[4.138s] [ext: omni.kit.browser.core-2.3.11] startup
[4.165s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
[4.167s] [ext: omni.kit.tool.collect-2.2.16] startup
[4.177s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[4.188s] [ext: isaacsim.cortex.framework-1.0.2] startup
[4.191s] [ext: isaacsim.examples.browser-0.1.8] startup
[4.198s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[4.200s] [ext: isaacsim.sensors.physics-0.3.5] startup
[4.209s] [ext: omni.kit.menu.create-1.0.17] startup
[4.213s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
[4.218s] [ext: omni.kit.scripting-106.5.2] startup
[4.241s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
[4.250s] [ext: isaacsim.examples.extension-2.0.6] startup
[4.253s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[4.258s] [ext: isaacsim.examples.interactive-4.4.8] startup
[4.312s] [ext: isaacsim.sensors.physics.examples-0.1.4] startup
[4.317s] [ext: isaacsim.replicator.behavior.ui-1.0.1] startup
[4.333s] [ext: isaacsim.sensors.camera-0.2.9] startup
[4.352s] [ext: isaacsim.robot.manipulators.ui-2.1.4] startup
[4.355s] [ext: isaacsim.sensors.camera.ui-0.1.4] startup
[4.732s] [ext: omni.debugdraw-0.1.3] startup
[4.738s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[4.744s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[4.749s] [ext: omni.anim.navigation.core-106.4.0] startup
[4.754s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[4.759s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[4.762s] [ext: omni.anim.navigation.recast-106.4.0] startup
[4.765s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[4.767s] [ext: omni.kit.widget.imageview-1.0.3] startup
[4.768s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[4.770s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[4.772s] [ext: omni.fabric.commands-1.1.5] startup
[4.774s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[4.779s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[4.781s] [ext: omni.anim.shared.core-106.0.2] startup
[4.785s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[4.795s] [ext: omni.kit.actions.window-1.1.1] startup
[4.801s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[4.802s] [ext: omni.graph.window.core-1.130.1] startup
[4.810s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[4.812s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
[4.814s] [ext: omni.kit.hotkeys.window-1.4.8] startup
[4.817s] [ext: omni.kit.viewport.actions-107.0.0] startup
[4.821s] [ext: omni.graph.window.action-1.40.0] startup
[4.825s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[4.826s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[4.829s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[4.832s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[4.835s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[4.836s] [ext: omni.mdl.usd_converter-1.0.24] startup
[4.838s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[4.840s] [ext: omni.sensors.tiled-0.0.6] startup
[4.841s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[4.845s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[4.849s] [ext: isaacsim.asset.importer.heightmap-2.0.3] startup
[4.852s] [ext: isaacsim.sensors.rtx-13.6.3] startup
[4.857s] [ext: omni.kit.widget.layers-1.8.2] startup
[4.877s] [ext: omni.physx.commands-106.5.7] startup
[4.880s] [ext: omni.usdphysics.ui-106.5.7] startup
[4.901s] [ext: omni.kit.stage.mdl_converter-1.0.7] startup
[4.904s] [ext: omni.isaac.block_world-2.0.2] startup
2025-08-19 18:40:10 [4,888ms] [Warning] [omni.isaac.block_world] [‘omni.isaac.block_world’] has been deprecated in favor of [‘isaacsim.asset.importer.heightmap’]. Please update your code accordingly.
[4.906s] [ext: isaacsim.sensors.rtx.ui-0.1.2] startup
2025-08-19 18:40:10 [4,892ms] [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path /home/czeitler/isaacsim/exts/isaacsim.sensors.rtx/data/lidar_configs
[5.235s] [ext: isaacsim.sensors.physics.ui-0.1.2] startup
[5.239s] [ext: omni.physx.ui-106.5.7] startup
[5.258s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[5.263s] [ext: omni.importer.onshape-0.8.1] startup
[5.274s] [ext: isaacsim.robot_setup.gain_tuner-2.0.3] startup
[5.278s] [ext: omni.usd.metrics.assembler.physics-106.5.0] startup
[5.282s] [ext: isaacsim.util.camera_inspector-1.0.4] startup
[5.286s] [ext: omni.isaac.gain_tuner-2.0.2] startup
[5.286s] [ext: isaacsim.robot_setup.grasp_editor-2.0.5] startup
[5.292s] [ext: isaacsim.asset.gen.omap-2.0.8] startup
[5.297s] [ext: omni.anim.curve.core-1.2.0] startup
[5.316s] [ext: isaacsim.robot.surface_gripper.ui-2.1.1] startup
[5.318s] [ext: omni.isaac.grasp_editor-2.0.2] startup
[5.318s] [ext: omni.isaac.occupancy_map-2.0.3] startup
2025-08-19 18:40:11 [5,307ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
[5.324s] [ext: omni.anim.curve.ui-1.4.0] startup
[5.334s] [ext: isaacsim.util.merge_mesh-2.0.6] startup
[5.339s] [ext: isaacsim.robot_setup.assembler-2.1.5] startup
[5.343s] [ext: omni.anim.curve.bundle-1.2.3] startup
[5.344s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.5] startup
[5.348s] [ext: omni.isaac.robot_assembler-2.0.2] startup
[5.349s] [ext: isaacsim.replicator.scene_blox-1.0.2] startup
[5.351s] [ext: omni.isaac.robot_description_editor-3.0.2] startup
[5.353s] [ext: isaacsim.replicator.synthetic_recorder-2.2.3] startup
[5.362s] [ext: isaacsim.core.throttling-2.0.2] startup
[5.365s] [ext: omni.isaac.scene_blox-1.0.2] startup
2025-08-19 18:40:11 [5,350ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[5.367s] [ext: omni.graph.ui_nodes-1.40.1] startup
[5.374s] [ext: omni.isaac.synthetic_recorder-2.0.2] startup
2025-08-19 18:40:11 [5,360ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[5.376s] [ext: omni.isaac.throttling-2.0.2] startup
2025-08-19 18:40:11 [5,360ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-08-19 18:40:11 [5,363ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[5.379s] [ext: omni.kit.browser.asset-1.3.11] startup
[5.387s] [ext: omni.graph.bundle.action-2.20.0] startup
[5.388s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-08-19 18:40:11 [5,374ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-08-19 18:40:11 [5,375ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[5.392s] [ext: omni.kit.core.collection-0.2.0] startup
[5.400s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[5.403s] [ext: omni.kit.preferences.animation-1.2.0] startup
[5.406s] [ext: omni.graph.window.generic-1.40.0] startup
[5.413s] [ext: omni.kit.property.collection-0.2.0] startup
[5.420s] [ext: omni.kit.property.layer-1.1.8] startup
[5.424s] [ext: omni.kit.search.files-1.0.4] startup
[5.427s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[5.433s] [ext: omni.kit.window.title-1.1.5] startup
[5.436s] [ext: omni.isaac.extension_templates-2.0.2] startup
2025-08-19 18:40:11 [5,421ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
[5.438s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[5.443s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[5.446s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[5.448s] [ext: omni.kit.browser.material-1.6.0] startup
[5.451s] [ext: omni.kit.property.material-1.10.17] startup
[5.458s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[5.463s] [ext: omni.kit.widgets.custom-1.0.9] startup
[5.471s] [ext: omni.kit.usdz_export-1.0.7] startup
[5.474s] [ext: omni.kit.window.material-1.6.2] startup
[5.479s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[5.480s] [ext: omni.kit.variant.editor-106.1.1] startup
[5.491s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[5.520s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[5.524s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[5.526s] [ext: omni.kit.usda_edit-1.1.14] startup
[5.535s] [ext: omni.kit.variant.presenter-107.0.0] startup
[5.538s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[5.543s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[5.548s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[5.551s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[5.554s] [ext: omni.rtx.window.settings-0.6.17] startup
[5.559s] [ext: isaacsim.asset.gen.omap.ui-2.0.4] startup
[5.569s] [ext: omni.scene.optimizer.core-106.1.10] startup
[5.626s] [ext: omni.kit.widget.live-2.1.8] startup
[5.629s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[5.629s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[5.630s] [ext: omni.isaac.occupancy_map.ui-2.0.3] startup
2025-08-19 18:40:11 [5,614ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
[5.635s] [ext: omni.kit.converter.common-503.2.1] startup
[5.659s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[5.661s] [ext: omni.kit.widget.cache_indicator-3.0.1] startup
2025-08-19 18:40:11 [5,646ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn’t do anything and can be removed.
2025-08-19 18:40:11 [5,689ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File /home/czeitler/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
[5.705s] [ext: omni.isaac.physics_inspector-0.1.7] startup
2025-08-19 18:40:11 [5,690ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[5.707s] [ext: isaacsim.util.physics-1.1.2] startup
[5.712s] [ext: omni.kit.converter.dgn_core-503.3.2] startup
[5.758s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[5.762s] [ext: omni.kit.converter.hoops_core-504.4.1] startup
[5.766s] [ext: omni.kit.window.script_editor-1.7.8] startup
[5.769s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[5.771s] [ext: isaacsim.asset.browser-1.3.4] startup
[5.786s] [ext: omni.simready.explorer-1.1.1] startup
[5.799s] [ext: isaacsim.core.cloner-1.3.4] startup
[5.805s] [ext: omni.kit.converter.dgn-503.3.1] startup
[5.809s] [ext: omni.kit.converter.hoops-504.4.3] startup
[5.815s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[6.066s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[6.213s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-08-19 18:40:12 [6,198ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[6.214s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-08-19 18:40:12 [6,200ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[6.216s] [ext: omni.isaac.cloner-1.0.2] startup
2025-08-19 18:40:12 [6,201ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[6.219s] [ext: omni.kit.widget.calendar-1.0.8] startup
[6.225s] [ext: omni.kit.selection-0.1.5] startup
[6.227s] [ext: omni.isaac.core-4.0.3] startup
2025-08-19 18:40:12 [6,212ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-08-19 18:40:12 [6,212ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-08-19 18:40:12 [6,212ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-08-19 18:40:12 [6,212ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[6.228s] [ext: isaacsim.simulation_app-2.4.2] startup
[6.229s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-08-19 18:40:12 [6,214ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[6.232s] [ext: omni.isaac.cortex-1.0.2] startup
[6.233s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[6.236s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[6.243s] [ext: isaacsim.gui.menu-2.0.9] startup
[6.248s] [ext: omni.isaac.franka-1.0.2] startup
2025-08-19 18:40:12 [6,234ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-08-19 18:40:12 [6,234ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-08-19 18:40:12 [6,235ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[6.251s] [ext: omni.isaac.kit-2.0.3] startup
2025-08-19 18:40:12 [6,238ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[6.254s] [ext: omni.isaac.lula-4.0.2] startup
2025-08-19 18:40:12 [6,239ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[6.256s] [ext: isaacsim.sensors.physx-2.2.4] startup
[6.260s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-08-19 18:40:12 [6,245ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[6.261s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-08-19 18:40:12 [6,246ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,246ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,246ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,247ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,247ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,247ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,247ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,248ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,249ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-08-19 18:40:12 [6,249ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[6.265s] [ext: omni.isaac.menu-1.0.2] startup
2025-08-19 18:40:12 [6,250ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[6.267s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-08-19 18:40:12 [6,252ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,252ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,252ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,252ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-08-19 18:40:12 [6,253ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[6.270s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-08-19 18:40:12 [6,255ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-08-19 18:40:12 [6,255ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[6.271s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-08-19 18:40:12 [6,256ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[6.272s] [ext: omni.isaac.range_sensor-4.0.2] startup
[6.274s] [ext: omni.isaac.sensor-13.0.3] startup
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-08-19 18:40:12 [6,259ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-08-19 18:40:12 [6,260ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-08-19 18:40:12 [6,260ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-08-19 18:40:12 [6,260ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[6.276s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-08-19 18:40:12 [6,262ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[6.279s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-08-19 18:40:12 [6,265ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,265ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,265ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[6.281s] [ext: omni.isaac.utils-2.0.2] startup
[6.283s] [ext: omni.kit.property.audio-1.0.16] startup
[6.288s] [ext: omni.kit.property.camera-1.0.9] startup
[6.290s] [ext: omni.hydra.scene_api-0.1.2] startup
[6.295s] [ext: omni.kit.property.physx-106.5.7] startup
[6.327s] [ext: omni.physx.demos-106.5.7] startup
[6.343s] [ext: omni.kit.property.geometry-1.3.3] startup
[6.347s] [ext: isaacsim.app.about-2.0.7] startup
[6.349s] [ext: omni.kit.property.light-1.0.11] startup
[6.351s] [ext: omni.kit.property.render-1.1.3] startup
[6.352s] [ext: omni.kit.property.transform-1.5.10] startup
[6.355s] [ext: omni.isaac.version-2.0.2] startup
2025-08-19 18:40:12 [6,339ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[6.356s] [ext: omni.physx.vehicle-106.5.7] startup
[6.369s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,355ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,356ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,356ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,356ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,356ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-08-19 18:40:12 [6,356ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[6.373s] [ext: omni.isaac.window.about-2.0.2] startup
2025-08-19 18:40:12 [6,358ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-08-19 18:40:12 [6,358ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[6.375s] [ext: isaacsim.sensors.physx.examples-2.2.4] startup
[6.377s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[6.382s] [ext: omni.kit.property.bundle-1.3.2] startup
[6.383s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[6.385s] [ext: omni.physx.camera-106.5.7] startup
[6.396s] [ext: omni.kit.window.toolbar-1.6.2] startup
[6.403s] [ext: omni.kit.widget.timeline-105.0.1] startup
[6.408s] [ext: omni.isaac.range_sensor.examples-2.0.3] startup
2025-08-19 18:40:12 [6,393ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-08-19 18:40:12 [6,394ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-08-19 18:40:12 [6,394ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[6.410s] [ext: isaacsim.replicator.writers-1.0.1] startup
[6.432s] [ext: isaacsim.gui.property-1.0.4] startup
[6.436s] [ext: omni.physx.cct-106.5.7] startup
[6.449s] [ext: omni.physx.graph-106.5.7] startup
[6.464s] [ext: omni.physx.supportui-106.5.7] startup
[6.484s] [ext: omni.physx.telemetry-106.5.7] startup
[6.488s] [ext: isaacsim.replicator.examples-1.1.2] startup
[6.489s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-08-19 18:40:12 [6,476ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-08-19 18:40:12 [6,477ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
[6.493s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[6.501s] [ext: omni.kit.window.console-0.2.14] startup
[6.511s] [ext: omni.kit.window.status_bar-0.1.7] startup
[6.518s] [ext: omni.kit.widget.collection-0.1.18] startup
[6.520s] [ext: omni.physx.bundle-106.5.7] startup
[6.521s] [ext: omni.replicator.isaac-2.0.3] startup
2025-08-19 18:40:12 [6,505ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[6.522s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[6.526s] [ext: omni.rtx.settings.core-0.6.3] startup
[6.534s] [ext: omni.kit.converter.jt_core-503.2.2] startup
[6.545s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[6.548s] [ext: omni.kit.window.collection-0.2.0] startup
[6.549s] [ext: isaacsim.sensors.physx.ui-2.2.1] startup
[6.550s] [ext: semantics.schema.editor-0.3.10] startup
[6.554s] [ext: omni.kit.ui.actions-1.0.2] startup
[6.556s] [ext: semantics.schema.property-1.0.5] startup
[6.557s] [ext: omni.kit.converter.jt-503.2.2] startup
[6.558s] [ext: omni.kit.quicklayout-1.0.8] startup
[6.560s] [ext: omni.kit.window.commands-0.2.7] startup
[6.561s] [ext: omni.isaac.range_sensor.ui-2.0.2] startup
2025-08-19 18:40:12 [6,545ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-08-19 18:40:12 [6,545ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[6.562s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.5] startup
[6.565s] [ext: omni.kit.menu.common-1.1.9] startup
[6.568s] [ext: isaacsim.exp.base-4.5.0] startup
[6.568s] [ext: omni.kit.converter.cad-202.2.0] startup
[6.569s] [ext: omni.kit.window.stats-0.1.7] startup
[6.570s] [ext: isaacsim.app.setup-1.3.5] startup
[6.571s] Isaac Sim Full Version: 4.5.0-rc.36
[6.571s] Writing Isaac Sim icon file
[6.571s] [ext: omni.kit.profiler.window-2.3.1] startup
[6.575s] [ext: isaacsim.exp.full-4.5.0] startup
[6.685s] [ext: isaacsim.ros2.bridge-4.1.15] startup
[6.724s] Attempting to load system rclpy
[6.724s] Could not import system rclpy: No module named ‘rclpy’
[6.724s] Attempting to load internal rclpy
[6.749s] rclpy loaded
2025-08-19 18:40:12 [6,909ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/ecoMode/enabled’
2025-08-19 18:40:13 [7,041ms] [Error] [gpu.foundation.plugin] The currently installed NVIDIA graphics driver is unsupported or has known issues.
2025-08-19 18:40:13 [7,041ms] [Error] [carb.scenerenderer-rtx.plugin] rtx driver verification failed.
2025-08-19 18:40:13 [7,041ms] [Warning] [omni.hydra.rtx] HydraEngine rtx failed creating scene renderer.
[7.084s] app ready
Please try with the Latest Production Branch Version on Unix Drivers | NVIDIA.
Thanks Vick! This cleared up the issue.
