Hi.
I am trying customizing a standalone example for reinforcement learning using IsaacSim.
I want to control robot manipulator(Frank) using RMPFlowControl and Follow Target, but some errors occurs.
In my case, I referenced a standalone example
/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/standalone_examples/api/omni.isaac.franka/follow_target.py
to the reinforcement learning example.
/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/standalone_examples/api/omni.isaac.jetbot/stable_baselines_example/env.py
I added the specific part into env.py (Added part : # 22.02.16 ---------------)
import gym
from gym import spaces
import numpy as np
import math
class JetBotEnv(gym.Env):
metadata = {"render.modes": ["human"]}
def __init__(
self,
skip_frame=1,
physics_dt=1.0 / 60.0,
rendering_dt=1.0 / 60.0,
max_episode_length=1000,
seed=0,
headless=True,
) -> None:
from omni.isaac.kit import SimulationApp
self.headless = headless
self._simulation_app = SimulationApp({"headless": self.headless, "anti_aliasing": 0})
self._skip_frame = skip_frame
self._dt = physics_dt * self._skip_frame
self._max_episode_length = max_episode_length
self._steps_after_reset = int(rendering_dt / physics_dt)
from omni.isaac.core import World
from omni.isaac.jetbot import Jetbot
# 2022.02.16 update -------------------------
from omni.isaac.franka import Franka
from omni.isaac.franka.tasks import FollowTarget
from omni.isaac.franka.controllers import RMPFlowController
from omni.isaac.core.objects import VisualCuboid
self._my_world = World(physics_dt=physics_dt, rendering_dt=rendering_dt, stage_units_in_meters=0.01)
self._my_world.scene.add_default_ground_plane()
self.franka = self._my_world.scene.add(
Franka(
prim_path="/Franka",
name="my_franka",
position=np.array([30, 30.0, 0.0]),
self.flag = 0
my_controller = RMPFlowController(name="target_follower_controller", robot_prim_path=self.franka.prim_path) #This line makes an error.
self.jetbot = self._my_world.scene.add(
Jetbot(
prim_path="/jetbot",
name="my_jetbot",
position=np.array([0, 0.0, 2.0]),
orientation=np.array([1.0, 0.0, 0.0, 0.0]),
self.goal = self._my_world.scene.add(
VisualCuboid(
prim_path="/new_cube_1",
name="visual_cube",
position=np.array([60, 30, 2.5]),
size=np.array([5, 5, 5]),
color=np.array([1.0, 0, 0]),
self.seed(seed)
self.sd_helper = None
self.viewport_window = None
self._set_camera()
self.reward_range = (-float("inf"), float("inf"))
gym.Env.__init__(self)
self.action_space = spaces.Box(low=-10.0, high=10.0, shape=(2,), dtype=np.float32)
self.observation_space = spaces.Box(low=0, high=255, shape=(128, 128, 3), dtype=np.uint8)
return
def get_dt(self):
return self._dt
def step(self, action):
previous_jetbot_position, _ = self.jetbot.get_world_pose()
for i in range(self._skip_frame):
from omni.isaac.core.utils.types import ArticulationAction
self.jetbot.apply_wheel_actions(ArticulationAction(joint_velocities=action * 10.0))
self._my_world.step(render=False)
observations = self.get_observations()
info = {}
done = False
if self._my_world.current_time_step_index - self._steps_after_reset >= self._max_episode_length:
done = True
goal_world_position, _ = self.goal.get_world_pose()
current_jetbot_position, _ = self.jetbot.get_world_pose()
previous_dist_to_goal = np.linalg.norm(goal_world_position - previous_jetbot_position)
current_dist_to_goal = np.linalg.norm(goal_world_position - current_jetbot_position)
reward = previous_dist_to_goal - current_dist_to_goal
return observations, reward, done, info
def reset(self):
self._my_world.reset()
# randomize goal location in circle around robot
alpha = 2 * math.pi * np.random.rand()
r = 100 * math.sqrt(np.random.rand()) + 20
self.goal.set_world_pose(np.array([math.sin(alpha) * r, math.cos(alpha) * r, 2.5]))
return observations
def get_observations(self):
self._my_world.render()
# wait_for_sensor_data is recommended when capturing multiple sensors, in this case we can set it to zero as we only need RGB
gt = self.sd_helper.get_groundtruth(
["rgb"], self.viewport_window, verify_sensor_init=False, wait_for_sensor_data=0
return gt["rgb"][:, :, :3]
def render(self, mode="human"):
return
def close(self):
self._simulation_app.close()
return
def seed(self, seed=None):
self.np_random, seed = gym.utils.seeding.np_random(seed)
np.random.seed(seed)
return [seed]
def _set_camera(self):
import omni.kit
from omni.isaac.synthetic_utils import SyntheticDataHelper
camera_path = "/jetbot/chassis/rgb_camera/jetbot_camera"
if self.headless:
viewport_handle = omni.kit.viewport.get_viewport_interface()
viewport_handle.get_viewport_window().set_active_camera(str(camera_path))
viewport_window = viewport_handle.get_viewport_window()
self.viewport_window = viewport_window
viewport_window.set_texture_resolution(128, 128)
else:
viewport_handle = omni.kit.viewport.get_viewport_interface().create_instance()
new_viewport_name = omni.kit.viewport.get_viewport_interface().get_viewport_window_name(viewport_handle)
viewport_window = omni.kit.viewport.get_viewport_interface().get_viewport_window(viewport_handle)
viewport_window.set_active_camera(camera_path)
viewport_window.set_window_pos(1000, 400)
viewport_window.set_window_size(420, 420)
self.sd_helper = SyntheticDataHelper()
self.sd_helper.initialize(sensor_names=["rgb"], viewport=self.viewport_window)
self.sd_helper.get_groundtruth(["rgb"], self.viewport_window)
return
and it made this error.
File "train.py", line 18, in <module>
my_env = JetBotEnv(headless=False)
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/standalone_examples/api/omni.isaac.jetbot/stable_baselines_example/env_franka.py", line 58, in __init__
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.franka/omni/isaac/franka/controllers/rmpflow_controller.py", line 27, in __init__
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/rmpflow_controller.py", line 50, in __init__
self._mg.initialize(self._config, self._robot_prim, int(1.0 / physics_dt))
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/motion_generation.py", line 76, in initialize
self._configure_position_control()
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/motion_generation.py", line 354, in _configure_position_control
self._zero_robot_velocity()
File "/home/idim/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/motion_generation.py", line 345, in _zero_robot_velocity
dof_states["vel"] = np.zeros_like(dof_states["vel"])
TypeError: 'NoneType' object is not subscriptable
I’ve been studying omni api (such as world.get_task() etc) , but it is quite hard.
Could you let me know how to use RMPFlowControl and FollowTarget or show me the some examples of this function ?
Thank you !
