Isaac Sim Version
4.5.0 and 5.0
Operating System
Windows 11
GPU Information
- Model: RTX A6000
- Driver Version:
XRDevice
- Quest 3
Topic Description
Detailed Description
I am running VR in isaacsim and isaaclab with Quest3, connecting usb-c between Quest3 and my windows 11 pc.
When I run:
./isaaclab.bat -p scripts/tools/record_demos.py --task Isaac-Stack-Cube-Franka-IK-Rel-v0 --teleop_device handtracking_abs --dataset_file ./datasets/dataset.hdf5 --num_demos 10
it seems not be able to take the hand track poses, and in the AR panel → XCR: Capture and Replay, it shows error:
Capture layer is not present in windows registry, refer to README.md to install it.
But i can’t find the instruction in readme.md. Can you please let me know how to fix it? thanks!
I post here since it is actually related to underline IsaacSim.
Steps to Reproduce
- ./isaaclab.bat -p scripts/tools/record_demos.py --task Isaac-Stack-Cube-Franka-IK-Rel-v0 --teleop_device handtracking_abs --dataset_file ./datasets/dataset.hdf5 --num_demos 10
- Start AR in isaacsim
hand tracking markers is visible but it doesn't control anything, and the IsaacSim window shows error: Capture layer is not present in windows registry, refer to README.md to install it.
Error Messages
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
