Description
I used polygraphy to check the onnx model produced by mx2onnx, but the execution is failed:
[E] [graph.cpp::symbolicExecute::611] Error Code 4: Internal Error (node_of_ssdanchorgenerator0_slice_like0_ends: an IScatterLayer cannot be used to compute a shape tensor)
[E] ModelImporter.cpp:726: While parsing node number 260 [Slice -> "ssdanchorgenerator0_slice_like0"]:
[E] ModelImporter.cpp:727: --- Begin node ---
[E] ModelImporter.cpp:728: input: "ssdanchorgenerator0_anchor_0"
input: "ssdanchorgenerator0_slice_like0_starts"
input: "ssdanchorgenerator0_slice_like0_ends"
output: "ssdanchorgenerator0_slice_like0"
op_type: "Slice"
[E] ModelImporter.cpp:729: --- End node ---
[E] ModelImporter.cpp:732: ERROR: ModelImporter.cpp:185 In function parseGraph:
[6] Invalid Node - node_of_ssdanchorgenerator0_slice_like0
[E] In node 260 (parseGraph): INVALID_NODE: Invalid Node - node_of_ssdanchorgenerator0_slice_like0
[!] Could not parse ONNX correctly
[E] FAILED | Runtime: 2.718s | Command: /home/ANT.AMAZON.COM/zhdongxi/.pyenv/versions/MXNET_TEST/bin/polygraphy run mxnet_exported_corner_exp.onnx --trt
I think there is some restrictions in tensorrt that prevents some ops in ONNX model.
In this case, I tried to convert a MXNet model to ONNX and run it in tensorrt and the issued operator is called slice_like
. The implementation of this op (in ONNX) can be found here: mxnet/_op_translations_opset12.py at e2ed553f89ec46f0366e005ff0768b153bba3f94 · apache/mxnet · GitHub
I think feeding the “Shape” output to “Scatter” is causing the issue here, please correct me if I am wrong. Is there a workaround for this case? Can anybody provide some tips about it?
Environment
TensorRT Version: 8.5.1.7
GPU Type: 1080Ti
Nvidia Driver Version: 515.65.07
CUDA Version: 11.7
CUDNN Version:
Operating System + Version: Ubuntu18.04
Python Version (if applicable): 3.8.13
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
MXNet Version (if applicable): 1.9.1
ONNX Version (if applicable): 1.12.0
Relevant Files
Due to some confidential reason, I cannot post the model here, but as mentioned in the description, the issued op is slice-like
and its implementation can be found on page here: mxnet/_op_translations_opset12.py at e2ed553f89ec46f0366e005ff0768b153bba3f94 · apache/mxnet · GitHub.
Steps To Reproduce
polygraphy run MY_MODEL.onnx --trt
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
