During the upgrade of an AGX Orin platform from JetPack 6.2 to JetPack 7.2, I noticed a new ISP-related error in the GMSL camera driver:
Mar 24 21:45:54 CB-STT31JC-ubuntu kernel: [TS:1935462697] camera-diag: Limiting to 1 ISP instance(s) for this chip
Mar 24 21:45:54 CB-STT31JC-ubuntu kernel: [TS:1935489318] camera-diag: Failed to find ISP device node
After checking the source code, I found that this seems to be related to the nvidia,camera-devices device tree property.
However, in the source documentation, the only description I could find for this property is in:
source/nvidia-oot/Documentation/devicetree/bindings/misc/nvidia,tegra264-rce.yaml
This binding appears to be specific to Tegra264 / Thor.
For AGX Orin, what is the correct way to configure the nvidia,camera-devices property?
Is there an Orin-specific device tree binding or example available for this property?
Also, is the Failed to find ISP device node message expected on Orin under JetPack 7.2, or does it indicate that an ISP-related device tree node is missing from the platform configuration?
