Issac Sim Unity3D download
I am following the ISSAC set up documentation and trying to install Issac SIM unity3D. I don’t see any link to download the issac_sim_unity3d zip file in the given link (https://developer.nvidia.com/isaac/downloads) as mentioned here (Setup — ISAAC 2021.1 documentation)
Can someone please suggest where to download issac sim unity3D package from?
@goutam.gupta
I could not find the Unity3D for 2021 either.
I used the Unity3D 2020 version with the SDK 2021 version but the examples in the documentation (2021) seems to be not working as it was working in Unity3d 2020 + SDK 2020 versions.
I am not sure but what I gathered is that Omniverse Isaac SIM is the way forward (which I’m happy with). But the documentation is what confuses me - maybe that also need a thorough update.
Thanks @nvidia-xavier-orin !! I am trying to set up Isaac SIM through Omniverse launcher. But it is not working as mentioned here
(Isaac Sim Built on Omniverse — ISAAC 2021.1 documentation).
What is about Nucleus? Do we need to install that for Issac SIM to work? Can you please point me to some specific resource which will help me to understand the ecosystem.
@goutam.gupta
Please read the Isaac Sim Overview — Omniverse Robotics documentation and Native Workstation Deployment — Omniverse Robotics documentation
And yes you do need Nucleus - please read Nucleus Overview — Omniverse Nucleus documentation
I am trying to set up local nucleus server(workstation). I am getting followin glogs in the system monitor:
[2021-08-13 15:59:00,092][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7feda476a760>>
debug: 0
discovery_token: test
exe_path: /home/gkg/.local/share/ov/pkg/cache-2.4.5/System Monitor
full_name: Omniverse System Monitor
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7feda476a760>>
log_file: /home/gkg/.nvidia-omniverse/logs/System Monitor/logs.txt
log_file_count: 5
log_level: INFO
log_size: 5242880
monitor_config_dir: .
monitor_icon: /home/gkg/.local/share/ov/pkg/cache-2.4.5/System Monitor/omniverse-system-monitor-np.ico
monitor_service_port: 3085
monitor_ui_port: 3080
omni: <monitor.config.OmniConfig object at 0x7feda476a910>
omni_config_dir: /home/gkg/.nvidia-omniverse/config
omni_config_toml: /home/gkg/.nvidia-omniverse/config/omniverse.toml
process_watch_interval: 3
[2021-08-13 15:59:00,093][OT] INFO: Registering interface ‘Launcher’:
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘get_applications’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘get_app’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘start’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘stop’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘set_auto_launch’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘subscribe’
[2021-08-13 15:59:00,094][OT] INFO: Registering interface ‘Auth’:
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘get’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘set’
[2021-08-13 15:59:00,094][OT] INFO: Method: ‘get_all’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘purge’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘remove’
[2021-08-13 15:59:00,095][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘get_info’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘set_path’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘enable’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘disable’
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘clear’
[2021-08-13 15:59:00,095][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-13 15:59:00,095][OT] INFO: Method: ‘set_server’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘disable’
[2021-08-13 15:59:00,096][OT] INFO: Registering interface ‘Logs’:
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘get_loggers’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘get_log’
[2021-08-13 15:59:00,096][OT] INFO: Registering interface ‘Configure’:
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘read’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘set_sharing’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘get_features’
[2021-08-13 15:59:00,096][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘get_ports’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘set_ports’
[2021-08-13 15:59:00,096][OT] INFO: Method: ‘reset_ports’
[2021-08-13 15:59:00,096][OT] INFO: Listen.
[2021-08-13 15:59:00,097][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-13 16:53:32,535][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7fb9a257a760>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7fb9a257a760>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7fb9a257a7f0>
[2021-08-13 16:53:32,541][OT] INFO: Registering interface ‘Launcher’:
[2021-08-13 16:53:32,545][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-13 16:53:32,551][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-13 16:53:33,602][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Discovery Service/omni-discovery-service – {‘SERVICE_REDIRECT_TO_PUBLIC_ADDR’: ‘False’, ‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Discovery Service/logs.txt’}
[2021-08-13 16:53:33,619][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-13 16:53:35,529][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Cache/omni-cache-service – {‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Cache/ov_cache_server.log’}
[2021-08-13 16:53:36,317][OT] INFO: Method: ‘get_applications’
[2021-08-13 16:53:36,318][OT] INFO: Method: ‘get_app’
[2021-08-13 16:53:36,319][OT] INFO: Method: ‘start’
[2021-08-13 16:53:36,321][OT] INFO: Method: ‘stop’
[2021-08-13 16:53:36,322][OT] INFO: Method: ‘set_auto_launch’
[2021-08-13 16:53:36,323][OT] INFO: Method: ‘subscribe’
[2021-08-13 16:53:36,324][OT] INFO: Registering interface ‘Auth’:
[2021-08-13 16:53:36,325][OT] INFO: Method: ‘get’
[2021-08-13 16:53:36,334][OT] INFO: Method: ‘set’
[2021-08-13 16:53:36,335][OT] INFO: Method: ‘get_all’
[2021-08-13 16:53:36,336][OT] INFO: Method: ‘purge’
[2021-08-13 16:53:36,337][OT] INFO: Method: ‘remove’
[2021-08-13 16:53:36,338][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-13 16:53:36,341][OT] INFO: Method: ‘get_info’
[2021-08-13 16:53:36,342][OT] INFO: Method: ‘set_path’
[2021-08-13 16:53:36,343][OT] INFO: Method: ‘enable’
[2021-08-13 16:53:36,346][OT] INFO: Method: ‘disable’
[2021-08-13 16:53:36,347][OT] INFO: Method: ‘clear’
[2021-08-13 16:53:36,349][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-13 16:53:36,351][OT] INFO: Method: ‘get_info’
[2021-08-13 16:53:36,352][OT] INFO: Method: ‘set_server’
[2021-08-13 16:53:36,354][OT] INFO: Method: ‘enable’
[2021-08-13 16:53:36,356][OT] INFO: Method: ‘disable’
[2021-08-13 16:53:36,357][OT] INFO: Registering interface ‘Logs’:
[2021-08-13 16:53:36,358][OT] INFO: Method: ‘get_loggers’
[2021-08-13 16:53:36,359][OT] INFO: Method: ‘get_log’
[2021-08-13 16:53:36,360][OT] INFO: Registering interface ‘Configure’:
[2021-08-13 16:53:36,362][OT] INFO: Method: ‘read’
[2021-08-13 16:53:36,363][OT] INFO: Method: ‘set_sharing’
[2021-08-13 16:53:36,364][OT] INFO: Method: ‘get_features’
[2021-08-13 16:53:36,364][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-13 16:53:36,365][OT] INFO: Method: ‘get_ports’
[2021-08-13 16:53:36,367][OT] INFO: Method: ‘set_ports’
[2021-08-13 16:53:36,369][OT] INFO: Method: ‘reset_ports’
[2021-08-13 16:53:36,370][OT] INFO: Listen.
[2021-08-13 17:05:59,866][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f10a1850760>>
debug: 0
exe_path: /home/gkg/.local/share/ov/pkg/nucleus-workstation-2021.2.0/System Monitor
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f10a1850760>>
log_file_count: 5
log_level: INFO
log_size: 5242880
monitor_icon: /home/gkg/.local/share/ov/pkg/nucleus-workstation-2021.2.0/System Monitor/omniverse-system-monitor-np.ico
omni: <monitor.config.OmniConfig object at 0x7f10a18507f0>
[2021-08-13 17:05:59,870][OT] INFO: Registering interface ‘Launcher’:
[2021-08-13 17:05:59,876][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-13 17:05:59,881][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-13 17:05:59,884][OT] INFO: Registered port 8891 for Cache
[2021-08-13 17:05:59,885][OT] INFO: Registered port 8892 for Cache API
[2021-08-13 17:06:00,756][OT] INFO: Method: ‘get_applications’
[2021-08-13 17:06:00,757][OT] INFO: Method: ‘get_app’
[2021-08-13 17:06:00,758][OT] INFO: Method: ‘start’
[2021-08-13 17:06:00,758][OT] INFO: Method: ‘stop’
[2021-08-13 17:06:00,759][OT] INFO: Method: ‘set_auto_launch’
[2021-08-13 17:06:00,759][OT] INFO: Method: ‘subscribe’
[2021-08-13 17:06:00,760][OT] INFO: Registering interface ‘Auth’:
[2021-08-13 17:06:00,760][OT] INFO: Method: ‘get’
[2021-08-13 17:06:00,761][OT] INFO: Method: ‘set’
[2021-08-13 17:06:00,761][OT] INFO: Method: ‘get_all’
[2021-08-13 17:06:00,761][OT] INFO: Method: ‘purge’
[2021-08-13 17:06:00,762][OT] INFO: Method: ‘remove’
[2021-08-13 17:06:00,762][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-13 17:06:00,764][OT] INFO: Method: ‘get_info’
[2021-08-13 17:06:00,764][OT] INFO: Method: ‘set_path’
[2021-08-13 17:06:00,765][OT] INFO: Method: ‘enable’
[2021-08-13 17:06:00,766][OT] INFO: Method: ‘disable’
[2021-08-13 17:06:00,766][OT] INFO: Method: ‘clear’
[2021-08-13 17:06:00,767][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-13 17:06:00,769][OT] INFO: Method: ‘get_info’
[2021-08-13 17:06:00,769][OT] INFO: Method: ‘set_server’
[2021-08-13 17:06:00,770][OT] INFO: Method: ‘enable’
[2021-08-13 17:06:00,771][OT] INFO: Method: ‘disable’
[2021-08-13 17:06:00,771][OT] INFO: Registering interface ‘Logs’:
[2021-08-13 17:06:00,772][OT] INFO: Method: ‘get_loggers’
[2021-08-13 17:06:00,772][OT] INFO: Method: ‘get_log’
[2021-08-13 17:06:00,773][OT] INFO: Registering interface ‘Configure’:
[2021-08-13 17:06:00,773][OT] INFO: Method: ‘read’
[2021-08-13 17:06:00,774][OT] INFO: Method: ‘set_sharing’
[2021-08-13 17:06:00,774][OT] INFO: Method: ‘get_features’
[2021-08-13 17:06:00,774][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-13 17:06:00,775][OT] INFO: Method: ‘get_ports’
[2021-08-13 17:06:00,776][OT] INFO: Method: ‘set_ports’
[2021-08-13 17:06:00,776][OT] INFO: Method: ‘reset_ports’
[2021-08-13 17:06:00,777][OT] INFO: Listen.
[2021-08-13 17:06:00,778][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-13 17:06:00,793][OT] INFO: Stopped the web UI.
[2021-08-13 17:06:00,795][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3080): address already in use
File “source/monitor/web.py”, line 40, in run
File “_build/python_lib/aiohttp/web_runner.py”, line 100, in start
File “_build/python/lib/python3.8/asyncio/base_events.py”, line 1463, in create_server
OSError: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3080): address already in use
[2021-08-13 17:06:00,796][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
File “source/monitor/service/runner.py”, line 33, in run
File “_build/idl.py/idl/service/init.py”, line 75, in run
File “_build/idl.py/idl/connection/transport/ws.py”, line 709, in start
File “_build/python_lib/websockets/server.py”, line 969, in await_impl
OSError: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
[2021-08-17 10:17:57,429][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f1a93a9f640>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f1a93a9f640>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7f1a93a9f7f0>
[2021-08-17 10:17:57,430][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 10:17:57,431][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7fa5f7cb5730>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7fa5f7cb5730>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7fa5f7cb57c0>
[2021-08-17 10:17:57,432][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 10:17:57,432][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 10:17:57,433][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 10:17:57,433][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 10:17:57,433][OT] INFO: Registered port 8891 for Cache
[2021-08-17 10:17:57,433][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 10:17:57,434][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 10:17:57,435][OT] INFO: Registered port 8891 for Cache
[2021-08-17 10:17:57,435][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 10:17:57,551][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Discovery Service/omni-discovery-service – {‘SERVICE_REDIRECT_TO_PUBLIC_ADDR’: ‘False’, ‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Discovery Service/logs.txt’}
[2021-08-17 10:17:57,553][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 10:17:57,564][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Discovery Service/omni-discovery-service – {‘SERVICE_REDIRECT_TO_PUBLIC_ADDR’: ‘False’, ‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Discovery Service/logs.txt’}
[2021-08-17 10:17:57,566][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 10:17:57,748][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Cache/omni-cache-service – {‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Cache/ov_cache_server.log’}
[2021-08-17 10:17:57,782][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Cache/omni-cache-service – {‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Cache/ov_cache_server.log’}
[2021-08-17 10:17:57,874][OT] INFO: Method: ‘get_applications’
[2021-08-17 10:17:57,874][OT] INFO: Method: ‘get_app’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘start’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘stop’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘subscribe’
[2021-08-17 10:17:57,875][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘get’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘set’
[2021-08-17 10:17:57,875][OT] INFO: Method: ‘get_all’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘purge’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘remove’
[2021-08-17 10:17:57,876][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘get_info’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘set_path’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘enable’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘disable’
[2021-08-17 10:17:57,876][OT] INFO: Method: ‘clear’
[2021-08-17 10:17:57,877][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 10:17:57,877][OT] INFO: Method: ‘get_info’
[2021-08-17 10:17:57,877][OT] INFO: Method: ‘set_server’
[2021-08-17 10:17:57,877][OT] INFO: Method: ‘enable’
[2021-08-17 10:17:57,877][OT] INFO: Method: ‘disable’
[2021-08-17 10:17:57,877][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 10:17:57,877][OT] INFO: Method: ‘get_loggers’
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘get_log’
[2021-08-17 10:17:57,878][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘read’
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘set_sharing’
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘get_features’
[2021-08-17 10:17:57,878][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘get_ports’
[2021-08-17 10:17:57,878][OT] INFO: Method: ‘set_ports’
[2021-08-17 10:17:57,879][OT] INFO: Method: ‘reset_ports’
[2021-08-17 10:17:57,879][OT] INFO: Listen.
[2021-08-17 10:17:57,894][OT] INFO: Method: ‘get_applications’
[2021-08-17 10:17:57,894][OT] INFO: Method: ‘get_app’
[2021-08-17 10:17:57,894][OT] INFO: Method: ‘start’
[2021-08-17 10:17:57,894][OT] INFO: Method: ‘stop’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘subscribe’
[2021-08-17 10:17:57,895][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘get’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘set’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘get_all’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘purge’
[2021-08-17 10:17:57,895][OT] INFO: Method: ‘remove’
[2021-08-17 10:17:57,896][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 10:17:57,896][OT] INFO: Method: ‘get_info’
[2021-08-17 10:17:57,896][OT] INFO: Method: ‘set_path’
[2021-08-17 10:17:57,896][OT] INFO: Method: ‘enable’
[2021-08-17 10:17:57,896][OT] INFO: Method: ‘disable’
[2021-08-17 10:17:57,897][OT] INFO: Method: ‘clear’
[2021-08-17 10:17:57,897][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 10:17:57,897][OT] INFO: Method: ‘get_info’
[2021-08-17 10:17:57,897][OT] INFO: Method: ‘set_server’
[2021-08-17 10:17:57,897][OT] INFO: Method: ‘enable’
[2021-08-17 10:17:57,897][OT] INFO: Method: ‘disable’
[2021-08-17 10:17:57,897][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 10:17:57,898][OT] INFO: Method: ‘get_loggers’
[2021-08-17 10:17:57,898][OT] INFO: Method: ‘get_log’
[2021-08-17 10:17:57,898][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 10:17:57,898][OT] INFO: Method: ‘read’
[2021-08-17 10:17:57,898][OT] INFO: Method: ‘set_sharing’
[2021-08-17 10:17:57,898][OT] INFO: Method: ‘get_features’
[2021-08-17 10:17:57,898][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 10:17:57,899][OT] INFO: Method: ‘get_ports’
[2021-08-17 10:17:57,899][OT] INFO: Method: ‘set_ports’
[2021-08-17 10:17:57,899][OT] INFO: Method: ‘reset_ports’
[2021-08-17 10:17:57,899][OT] INFO: Listen.
[2021-08-17 10:17:57,900][OT] INFO: Stopped the web UI.
[2021-08-17 10:17:57,900][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3080): address already in use
[2021-08-17 10:17:57,901][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
[2021-08-17 11:05:47,674][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f10db4b2730>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f10db4b2730>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7f10db4b27c0>
[2021-08-17 11:05:47,676][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 11:05:47,679][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 11:05:47,683][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 11:05:47,684][OT] INFO: Registered port 8891 for Cache
[2021-08-17 11:05:47,685][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 11:05:48,245][OT] INFO: Method: ‘get_applications’
[2021-08-17 11:05:48,245][OT] INFO: Method: ‘get_app’
[2021-08-17 11:05:48,246][OT] INFO: Method: ‘start’
[2021-08-17 11:05:48,246][OT] INFO: Method: ‘stop’
[2021-08-17 11:05:48,247][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 11:05:48,248][OT] INFO: Method: ‘subscribe’
[2021-08-17 11:05:48,248][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 11:05:48,249][OT] INFO: Method: ‘get’
[2021-08-17 11:05:48,249][OT] INFO: Method: ‘set’
[2021-08-17 11:05:48,250][OT] INFO: Method: ‘get_all’
[2021-08-17 11:05:48,251][OT] INFO: Method: ‘purge’
[2021-08-17 11:05:48,251][OT] INFO: Method: ‘remove’
[2021-08-17 11:05:48,252][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 11:05:48,253][OT] INFO: Method: ‘get_info’
[2021-08-17 11:05:48,253][OT] INFO: Method: ‘set_path’
[2021-08-17 11:05:48,254][OT] INFO: Method: ‘enable’
[2021-08-17 11:05:48,254][OT] INFO: Method: ‘disable’
[2021-08-17 11:05:48,255][OT] INFO: Method: ‘clear’
[2021-08-17 11:05:48,255][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 11:05:48,256][OT] INFO: Method: ‘get_info’
[2021-08-17 11:05:48,257][OT] INFO: Method: ‘set_server’
[2021-08-17 11:05:48,257][OT] INFO: Method: ‘enable’
[2021-08-17 11:05:48,258][OT] INFO: Method: ‘disable’
[2021-08-17 11:05:48,258][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 11:05:48,259][OT] INFO: Method: ‘get_loggers’
[2021-08-17 11:05:48,259][OT] INFO: Method: ‘get_log’
[2021-08-17 11:05:48,259][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 11:05:48,260][OT] INFO: Method: ‘read’
[2021-08-17 11:05:48,260][OT] INFO: Method: ‘set_sharing’
[2021-08-17 11:05:48,261][OT] INFO: Method: ‘get_features’
[2021-08-17 11:05:48,261][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 11:05:48,262][OT] INFO: Method: ‘get_ports’
[2021-08-17 11:05:48,262][OT] INFO: Method: ‘set_ports’
[2021-08-17 11:05:48,263][OT] INFO: Method: ‘reset_ports’
[2021-08-17 11:05:48,263][OT] INFO: Listen.
[2021-08-17 11:05:48,266][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 11:05:48,278][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
[2021-08-17 11:05:48,280][OT] INFO: Stopped the web UI.
[2021-08-17 11:05:48,280][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3080): address already in use
[2021-08-17 11:05:53,564][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7f99271a65b0>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7f99271a65b0>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7f99271a6760>
[2021-08-17 11:05:53,568][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 11:05:53,572][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 11:05:53,577][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 11:05:53,579][OT] INFO: Registered port 8891 for Cache
[2021-08-17 11:05:53,580][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 11:05:54,111][OT] INFO: Method: ‘get_applications’
[2021-08-17 11:05:54,112][OT] INFO: Method: ‘get_app’
[2021-08-17 11:05:54,112][OT] INFO: Method: ‘start’
[2021-08-17 11:05:54,113][OT] INFO: Method: ‘stop’
[2021-08-17 11:05:54,113][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 11:05:54,114][OT] INFO: Method: ‘subscribe’
[2021-08-17 11:05:54,114][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 11:05:54,115][OT] INFO: Method: ‘get’
[2021-08-17 11:05:54,115][OT] INFO: Method: ‘set’
[2021-08-17 11:05:54,116][OT] INFO: Method: ‘get_all’
[2021-08-17 11:05:54,116][OT] INFO: Method: ‘purge’
[2021-08-17 11:05:54,116][OT] INFO: Method: ‘remove’
[2021-08-17 11:05:54,117][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 11:05:54,118][OT] INFO: Method: ‘get_info’
[2021-08-17 11:05:54,118][OT] INFO: Method: ‘set_path’
[2021-08-17 11:05:54,118][OT] INFO: Method: ‘enable’
[2021-08-17 11:05:54,118][OT] INFO: Method: ‘disable’
[2021-08-17 11:05:54,119][OT] INFO: Method: ‘clear’
[2021-08-17 11:05:54,119][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 11:05:54,120][OT] INFO: Method: ‘get_info’
[2021-08-17 11:05:54,120][OT] INFO: Method: ‘set_server’
[2021-08-17 11:05:54,120][OT] INFO: Method: ‘enable’
[2021-08-17 11:05:54,121][OT] INFO: Method: ‘disable’
[2021-08-17 11:05:54,121][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 11:05:54,121][OT] INFO: Method: ‘get_loggers’
[2021-08-17 11:05:54,122][OT] INFO: Method: ‘get_log’
[2021-08-17 11:05:54,122][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 11:05:54,123][OT] INFO: Method: ‘read’
[2021-08-17 11:05:54,123][OT] INFO: Method: ‘set_sharing’
[2021-08-17 11:05:54,123][OT] INFO: Method: ‘get_features’
[2021-08-17 11:05:54,124][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 11:05:54,124][OT] INFO: Method: ‘get_ports’
[2021-08-17 11:05:54,125][OT] INFO: Method: ‘set_ports’
[2021-08-17 11:05:54,125][OT] INFO: Method: ‘reset_ports’
[2021-08-17 11:05:54,126][OT] INFO: Listen.
[2021-08-17 11:05:54,127][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 11:05:54,134][OT] INFO: Stopped the web UI.
[2021-08-17 11:05:54,136][OT] ERROR: unknown encoding: idna
File “_build/python/lib/python3.8/asyncio/base_events.py”, line 1429, in create_server
File “_build/python/lib/python3.8/asyncio/base_events.py”, line 1369, in _create_server_getaddrinfo
File “_build/python/lib/python3.8/asyncio/base_events.py”, line 1365, in _ensure_resolved
File “_build/python/lib/python3.8/asyncio/base_events.py”, line 825, in getaddrinfo
File “_build/python/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “_build/python/lib/python3.8/socket.py”, line 918, in getaddrinfo
LookupError: unknown encoding: idna
[2021-08-17 11:05:54,138][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
[2021-08-17 11:44:50,985][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7fa8060b3640>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7fa8060b3640>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7fa8060b37f0>
[2021-08-17 11:44:50,986][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 11:44:50,988][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 11:44:50,989][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 11:44:50,989][OT] INFO: Registered port 8891 for Cache
[2021-08-17 11:44:50,989][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 11:44:51,124][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Discovery Service/omni-discovery-service – {‘SERVICE_REDIRECT_TO_PUBLIC_ADDR’: ‘False’, ‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Discovery Service/logs.txt’}
[2021-08-17 11:44:51,126][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 11:44:51,340][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Cache/omni-cache-service – {‘SERVICE_HOST’: ‘127.0.0.1’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Cache/ov_cache_server.log’}
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘get_applications’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘get_app’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘start’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘stop’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘subscribe’
[2021-08-17 11:44:51,435][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘get’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘set’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘get_all’
[2021-08-17 11:44:51,435][OT] INFO: Method: ‘purge’
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘remove’
[2021-08-17 11:44:51,436][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘get_info’
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘set_path’
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘enable’
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘disable’
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘clear’
[2021-08-17 11:44:51,436][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 11:44:51,436][OT] INFO: Method: ‘set_server’
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘disable’
[2021-08-17 11:44:51,437][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘get_loggers’
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘get_log’
[2021-08-17 11:44:51,437][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘read’
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘set_sharing’
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘get_features’
[2021-08-17 11:44:51,437][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘get_ports’
[2021-08-17 11:44:51,437][OT] INFO: Method: ‘set_ports’
[2021-08-17 11:44:51,438][OT] INFO: Method: ‘reset_ports’
[2021-08-17 11:44:51,438][OT] INFO: Listen.
[2021-08-17 12:00:55,150][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Discovery Service/omni-discovery-service – {‘SERVICE_REDIRECT_TO_PUBLIC_ADDR’: ‘True’, ‘SERVICE_HOST’: ‘0.0.0.0’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Discovery Service/logs.txt’}
[2021-08-17 12:00:55,253][OT] INFO: /home/gkg/.local/share/ov/pkg/cache-2.4.5/Cache/omni-cache-service – {‘SERVICE_HOST’: ‘0.0.0.0’, ‘SERVICE_LOG_FILE’: ‘/home/gkg/.nvidia-omniverse/logs/Cache/ov_cache_server.log’}
[2021-08-17 12:01:51,656][OT] INFO: create_config_toml: <bound method MonitorConfig.create_config_toml of <monitor.config.MonitorConfig object at 0x7ffb744cf6a0>>
debug: 0
get_log_dir: <bound method MonitorConfig.get_log_dir of <monitor.config.MonitorConfig object at 0x7ffb744cf6a0>>
log_file_count: 5
log_level: INFO
log_size: 5242880
omni: <monitor.config.OmniConfig object at 0x7ffb744cf850>
[2021-08-17 12:01:51,657][OT] INFO: Registering interface ‘Launcher’:
[2021-08-17 12:01:51,657][OT] INFO: Found application Discovery Service [discovery_service – <class ‘monitor.service.launcher.apps.discovery.DiscoveryServiceApp’>].
[2021-08-17 12:01:51,658][OT] INFO: Found application Cache [cache – <class ‘monitor.service.launcher.apps.cache.CacheApp’>].
[2021-08-17 12:01:51,659][OT] INFO: Registered port 8891 for Cache
[2021-08-17 12:01:51,659][OT] INFO: Registered port 8892 for Cache API
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘get_applications’
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘get_app’
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘start’
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘stop’
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘set_auto_launch’
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘subscribe’
[2021-08-17 12:01:51,761][OT] INFO: Registering interface ‘Auth’:
[2021-08-17 12:01:51,761][OT] INFO: Method: ‘get’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘set’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘get_all’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘purge’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘remove’
[2021-08-17 12:01:51,762][OT] INFO: Registering interface ‘LocalCache’:
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘get_info’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘set_path’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘enable’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘disable’
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘clear’
[2021-08-17 12:01:51,762][OT] INFO: Registering interface ‘RemoteCache’:
[2021-08-17 12:01:51,762][OT] INFO: Method: ‘set_server’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘disable’
[2021-08-17 12:01:51,763][OT] INFO: Registering interface ‘Logs’:
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘get_loggers’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘get_log’
[2021-08-17 12:01:51,763][OT] INFO: Registering interface ‘Configure’:
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘read’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘set_sharing’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘get_features’
[2021-08-17 12:01:51,763][OT] INFO: Registering class ‘PortRegistry’ that implements interface ‘Ports’:
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘get_ports’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘set_ports’
[2021-08-17 12:01:51,763][OT] INFO: Method: ‘reset_ports’
[2021-08-17 12:01:51,763][OT] INFO: Listen.
[2021-08-17 12:01:51,763][OT] INFO: Running the web UI on http://localhost:3080
[2021-08-17 12:01:51,765][OT] INFO: Stopped the web UI.
[2021-08-17 12:01:51,765][OT] ERROR: unknown encoding: idna
[2021-08-17 12:01:51,766][OT] ERROR: [Errno 98] error while attempting to bind on address (‘127.0.0.1’, 3085): address already in use
I am getting followin gerror in the omniverse app :
“The collaboration service appears to be unresponsive. Please chekc your system monitor and be sure web services are enabled. if they are enabled, restart the service and try again”
Any help to resolve this issue will be very useful.
As you probably already know, Isaac Sim Unity3D is no longer supported. The current thread of conversation warrants a discussion in the Omniverse/Isaac Sim dev forum.
