Issue building jetson-inference from source
I’m facing issues when building jetson inference libraray from source.
I’m following this documentation: jetson-inference/docs/building-repo-2.md at master · dusty-nv/jetson-inference · GitHub
Errors happen when running command: make -j$(nproc)
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCudaMemory_GetStream(PyCudaMemory*, void*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:194:9: error: ‘PYLONG_FROM_PTR’ was not declared in this scope
return PYLONG_FROM_PTR(self->stream);
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:194:9: note: suggested alternative: ‘PYLONG_FROM_LONG’
PYLONG_FROM_LONG
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCudaMemory_GetEvent(PyCudaMemory*, void*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:223:9: error: ‘PYLONG_FROM_PTR’ was not declared in this scope
return PYLONG_FROM_PTR(self->event);
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:223:9: note: suggested alternative: ‘PYLONG_FROM_LONG’
PYLONG_FROM_LONG
In file included from /home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:23:0:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCUDA_StreamWaitEvent(PyObject*, PyObject*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1422:52: error: too few arguments to function ‘cudaError_t cudaStreamWaitEvent(cudaStream_t, cudaEvent_t, unsigned int)’
PYCUDA_ASSERT(cudaStreamWaitEvent(stream, event));
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.h:83:49: note: in definition of macro ‘PYCUDA_CHECK’
const cudaError_t _retval = cudaCheckError((x), #x, FILE, LINE);
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1422:5: note: in expansion of macro ‘PYCUDA_ASSERT’
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCUDA_StreamCreate(PyObject*, PyObject*, PyObject*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1381:12: error: ‘PYLONG_FROM_PTR’ was not declared in this scope
return PYLONG_FROM_PTR(stream);
In file included from /usr/local/cuda/include/channel_descriptor.h:61:0,
from /usr/local/cuda/include/cuda_runtime.h:95,
from /home/jetson/jetson-inference/build/aarch64/include/jetson-utils/cudaUtility.h:27,
from /home/jetson/jetson-inference/build/aarch64/include/jetson-utils/imageFormat.h:28,
from /home/jetson/jetson-inference/utils/python/bindings/PyCUDA.h:27,
/usr/local/cuda/include/cuda_runtime_api.h:2289:58: note: declared here
extern host cudart_builtin cudaError_t CUDARTAPI cudaStreamWaitEvent(cudaStream_t stream, cudaEvent_t event, unsigned int flags);
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1381:12: note: suggested alternative: ‘PYLONG_FROM_LONG’
PYLONG_FROM_LONG
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCUDA_EventCreate(PyObject*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1433:9: error: ‘PYLONG_FROM_PTR’ was not declared in this scope
return PYLONG_FROM_PTR(event);
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1433:9: note: suggested alternative: ‘PYLONG_FROM_LONG’
PYLONG_FROM_LONG
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp: In function ‘PyObject* PyCUDA_EventRecord(PyObject*, PyObject*, PyObject*)’:
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1467:12: error: ‘PYLONG_FROM_PTR’ was not declared in this scope
/home/jetson/jetson-inference/utils/python/bindings/PyCUDA.cpp:1467:12: note: suggested alternative: ‘PYLONG_FROM_LONG’
PYLONG_FROM_LONG
utils/python/bindings_python_3.6/CMakeFiles/jetson-utils-python-36.dir/build.make:62: recipe for target ‘utils/python/bindings_python_3.6/CMakeFiles/jetson-utils-python-36.dir/PyCUDA.cpp.o’ failed
make[2]: *** [utils/python/bindings_python_3.6/CMakeFiles/jetson-utils-python-36.dir/PyCUDA.cpp.o] Error 1
CMakeFiles/Makefile2:837: recipe for target ‘utils/python/bindings_python_3.6/CMakeFiles/jetson-utils-python-36.dir/all’ failed
make[1]: *** [utils/python/bindings_python_3.6/CMakeFiles/jetson-utils-python-36.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 44%] Building NVCC (Device) object CMakeFiles/jetson-inference.dir/c/jetson-inference_generated_backgroundNet.cu.o
utils/python/bindings_python_2.7/CMakeFiles/jetson-utils-python-27.dir/build.make:62: recipe for target ‘utils/python/bindings_python_2.7/CMakeFiles/jetson-utils-python-27.dir/PyCUDA.cpp.o’ failed
make[2]: *** [utils/python/bindings_python_2.7/CMakeFiles/jetson-utils-python-27.dir/PyCUDA.cpp.o] Error 1
CMakeFiles/Makefile2:782: recipe for target ‘utils/python/bindings_python_2.7/CMakeFiles/jetson-utils-python-27.dir/all’ failed
make[1]: *** [utils/python/bindings_python_2.7/CMakeFiles/jetson-utils-python-27.dir/all] Error 2
[ 44%] Built target video-viewer
How can i fix this?
Hi @cschnizler, sorry about that - cleared these errors on JetPack 4 with fixes for JetPack 4 · dusty-nv/jetson-utils@903fae3 · GitHub after having made some recent changes.
Try doing a git pull --recurse-submodules in your jetson-inference directory (or re-clone the repo if it doesn’t sync the updates to jetson-utils) and let me know if you still face the issues after building again.
It works now. Thx for the quick fixes!
Maybe you Nvidia should consider creating tags of production ready versions.
Thanks for letting me know @cschnizler - I typically cut branches for each L4T release, but yea take your point. In this case I made some bigger changes than normal a few days ago. One thing with this project, is while it started as a tutorial series, it did gain a lot of actual users and I am normally quite careful about making changes. The newer, more rapidly moving stuff I put in jetson-containers and Jetson AI Lab now.
