Hello!
I’m new to the domain and just setup my nano B01.
Everything worked great until i connected a camera.
Without camera connected to a CSI port:
HDMI monitor - fine
USB keyboard/mouse - fine
Wifi - fine
I have 2 waveshare IMX219-160 cams and whenever i connect one of them to the board,
keyboard and mouse do not work
screen resolution changed
wifi does not work
I’ve seen that dmesg output is most likely required I’ve attached it. Luckily that worked via screen command.
I have no idea, what exactly to look for in the logs.
Would be great to get a hint for the cause.
Are both cams broken? Is the Nano broken?
Many thanks in advance.
[Sa Jan 22 17:27:25 2022] Booting Linux on physical CPU 0x0
[Sa Jan 22 17:27:25 2022] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5496-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021
[Sa Jan 22 17:27:25 2022] Boot CPU: AArch64 Processor [411fd071]
[Sa Jan 22 17:27:25 2022] OF: fdt:memory scan node memory@80000000, reg size 32,
[Sa Jan 22 17:27:25 2022] OF: fdt: - 80000000 , 7ee00000
[Sa Jan 22 17:27:25 2022] OF: fdt: - 100000000 , 7f200000
[Sa Jan 22 17:27:25 2022] Found tegra_fbmem: 00140000@92ca9000
[Sa Jan 22 17:27:25 2022] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[Sa Jan 22 17:27:25 2022] bootconsole [uart8250] enabled
[Sa Jan 22 17:27:25 2022] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[Sa Jan 22 17:27:25 2022] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[Sa Jan 22 17:27:25 2022] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[Sa Jan 22 17:27:25 2022] cma: Reserved 64 MiB at 0x00000000fac00000
[Sa Jan 22 17:27:25 2022] On node 0 totalpages: 1039872
[Sa Jan 22 17:27:25 2022] DMA zone: 8192 pages used for memmap
[Sa Jan 22 17:27:25 2022] DMA zone: 0 pages reserved
[Sa Jan 22 17:27:25 2022] DMA zone: 519168 pages, LIFO batch:31
[Sa Jan 22 17:27:25 2022] Normal zone: 8136 pages used for memmap
[Sa Jan 22 17:27:25 2022] Normal zone: 520704 pages, LIFO batch:31
[Sa Jan 22 17:27:25 2022] psci: probing for conduit method from DT.
[Sa Jan 22 17:27:25 2022] psci: PSCIv1.0 detected in firmware.
[Sa Jan 22 17:27:25 2022] psci: Using standard PSCI v0.2 function IDs
[Sa Jan 22 17:27:25 2022] psci: MIGRATE_INFO_TYPE not supported.
[Sa Jan 22 17:27:25 2022] psci: SMC Calling Convention v1.1
[Sa Jan 22 17:27:25 2022] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[Sa Jan 22 17:27:25 2022] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[Sa Jan 22 17:27:25 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[Sa Jan 22 17:27:25 2022] CPU features: enabling workaround for ARM erratum 832075
[Sa Jan 22 17:27:25 2022] Speculative Store Bypass Disable mitigation not required
[Sa Jan 22 17:27:25 2022] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[Sa Jan 22 17:27:25 2022] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[Sa Jan 22 17:27:25 2022] log_buf_len individual max cpu contribution: 32768 bytes
[Sa Jan 22 17:27:25 2022] log_buf_len total cpu_extra contributions: 98304 bytes
[Sa Jan 22 17:27:25 2022] log_buf_len min size: 32768 bytes
[Sa Jan 22 17:27:25 2022] log_buf_len: 131072 bytes
[Sa Jan 22 17:27:25 2022] early log buf free: 29760(90%)
[Sa Jan 22 17:27:25 2022] PID hash table entries: 4096 (order: 3, 32768 bytes)
[Sa Jan 22 17:27:25 2022] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[Sa Jan 22 17:27:25 2022] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[Sa Jan 22 17:27:25 2022] Memory: 3567192K/4159488K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 117160K reserved, 475136K cma-reserved)
[Sa Jan 22 17:27:25 2022] Virtual kernel memory layout:
[Sa Jan 22 17:27:25 2022] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[Sa Jan 22 17:27:25 2022] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[Sa Jan 22 17:27:25 2022] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[Sa Jan 22 17:27:25 2022] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[Sa Jan 22 17:27:25 2022] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[Sa Jan 22 17:27:25 2022] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[Sa Jan 22 17:27:25 2022] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[Sa Jan 22 17:27:25 2022] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[Sa Jan 22 17:27:25 2022] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[Sa Jan 22 17:27:25 2022] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[Sa Jan 22 17:27:25 2022] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[Sa Jan 22 17:27:25 2022] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[Sa Jan 22 17:27:25 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[Sa Jan 22 17:27:25 2022] Preemptible hierarchical RCU implementation.
[Sa Jan 22 17:27:25 2022] Build-time adjustment of leaf fanout to 64.
[Sa Jan 22 17:27:25 2022] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[Sa Jan 22 17:27:25 2022] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[Sa Jan 22 17:27:25 2022] NR_IRQS:64 nr_irqs:64 0
[Sa Jan 22 17:27:25 2022] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[Sa Jan 22 17:27:25 2022] t210 clock and reset probe
[Sa Jan 22 17:27:25 2022] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[Sa Jan 22 17:27:25 2022] clk_cbus_recalc_rate: no gbus parent
[Sa Jan 22 17:27:25 2022] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[Sa Jan 22 17:27:25 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[Sa Jan 22 17:27:25 2022] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[Sa Jan 22 17:27:25 2022] Console: colour dummy device 80x25
[Sa Jan 22 17:27:25 2022] console [tty0] enabled
[Sa Jan 22 17:27:25 2022] bootconsole [uart8250] disabled
[Sa Jan 22 17:27:25 2022] kmemleak: Kernel memory leak detector disabled
[Sa Jan 22 17:27:25 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[Sa Jan 22 17:27:25 2022] pid_max: default: 32768 minimum: 301
[Sa Jan 22 17:27:25 2022] Security Framework initialized
[Sa Jan 22 17:27:25 2022] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[Sa Jan 22 17:27:25 2022] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[Sa Jan 22 17:27:25 2022] ftrace: allocating 47077 entries in 184 pages
[Sa Jan 22 17:27:25 2022] sched-energy: CPU device node has no sched-energy-costs
[Sa Jan 22 17:27:25 2022] ASID allocator initialised with 65536 entries
[Sa Jan 22 17:27:25 2022] tegra-id: chipid=22117.
[Sa Jan 22 17:27:25 2022] tegra-id: opt_subrevision=0.
[Sa Jan 22 17:27:25 2022] Tegra Speedo/IDDQ fuse revision 4
[Sa Jan 22 17:27:25 2022] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[Sa Jan 22 17:27:25 2022] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[Sa Jan 22 17:27:25 2022] Tegra: CPU Speedo Value 2044, SoC Speedo Value 1953, GPU Speedo Value 2045
[Sa Jan 22 17:27:25 2022] Tegra: CPU IDDQ Value 1904, SoC IDDQ Value 2148, GPU IDDQ Value 2355
[Sa Jan 22 17:27:25 2022] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[Sa Jan 22 17:27:25 2022] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[Sa Jan 22 17:27:25 2022] DTB Build time: Jul 26 2021 12:16:29
[Sa Jan 22 17:27:25 2022] CPU1: Booted secondary processor [411fd071]
[Sa Jan 22 17:27:25 2022] CPU2: Booted secondary processor [411fd071]
[Sa Jan 22 17:27:25 2022] CPU3: Booted secondary processor [411fd071]
[Sa Jan 22 17:27:25 2022] Brought up 4 CPUs
[Sa Jan 22 17:27:25 2022] SMP: Total of 4 processors activated.
[Sa Jan 22 17:27:25 2022] CPU features: detected feature: 32-bit EL0 Support
[Sa Jan 22 17:27:25 2022] CPU: All CPU(s) started at EL2
[Sa Jan 22 17:27:25 2022] alternatives: patching kernel code
[Sa Jan 22 17:27:25 2022] devtmpfs: initialized
[Sa Jan 22 17:27:25 2022] Initilizing CustomIPI irq domain
[Sa Jan 22 17:27:25 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[Sa Jan 22 17:27:25 2022] futex hash table entries: 1024 (order: 4, 65536 bytes)
[Sa Jan 22 17:27:25 2022] pinctrl core: initialized pinctrl subsystem
[Sa Jan 22 17:27:25 2022] OS set in device tree is not L4T.
[Sa Jan 22 17:27:25 2022] regulator-dummy: no parameters
[Sa Jan 22 17:27:25 2022] Initializing plugin-manager
[Sa Jan 22 17:27:25 2022] Plugin module not found
[Sa Jan 22 17:27:25 2022] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[Sa Jan 22 17:27:25 2022] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[Sa Jan 22 17:27:25 2022] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[Sa Jan 22 17:27:25 2022] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[Sa Jan 22 17:27:25 2022] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[Sa Jan 22 17:27:25 2022] NET: Registered protocol family 16
[Sa Jan 22 17:27:25 2022] pstore: using zlib compression
[Sa Jan 22 17:27:25 2022] console [pstore-1] enabled
[Sa Jan 22 17:27:25 2022] pstore: Registered ramoops as persistent store backend
[Sa Jan 22 17:27:25 2022] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[Sa Jan 22 17:27:25 2022] cpuidle: using governor menu
[Sa Jan 22 17:27:25 2022] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[Sa Jan 22 17:27:25 2022] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[Sa Jan 22 17:27:25 2022] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[Sa Jan 22 17:27:25 2022] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[Sa Jan 22 17:27:25 2022] Serial: AMBA PL011 UART driver
[Sa Jan 22 17:27:25 2022] tegra_powergate_init: DONE
[Sa Jan 22 17:27:25 2022] Tegra reboot handler registered.
[Sa Jan 22 17:27:25 2022] iommu: Adding device tegra-carveouts to group 0
[Sa Jan 22 17:27:25 2022] platform tegra-carveouts: domain=ffffffc0f941e3d8 allocates as[0]=ffffffc0f94300a8
[Sa Jan 22 17:27:25 2022] iommu: Adding device smmu_test to group 1
[Sa Jan 22 17:27:25 2022] platform smmu_test: domain=ffffffc0f941e618 allocates as[0]=ffffffc0f9430110
[Sa Jan 22 17:27:25 2022] mc: mapped MMIO address: 0xffffff8008041000 -> 0x70019000
[Sa Jan 22 17:27:25 2022] mc: mapped MMIO address: 0xffffff8008067000 -> 0x7001c000
[Sa Jan 22 17:27:25 2022] mc: mapped MMIO address: 0xffffff800807b000 -> 0x7001d000
[Sa Jan 22 17:27:25 2022] nv-tegra-mc 70019000.mc: No mssnvlink node
[Sa Jan 22 17:27:25 2022] mc-err: mcerr ops are set to t21x
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70090000.xusb to group 2
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70006000.serial to group 3
[Sa Jan 22 17:27:25 2022] platform 70006000.serial: domain=ffffffc0f9447cd8 allocates as[0]=ffffffc0f9430178
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70006040.serial to group 4
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70006200.serial to group 5
[Sa Jan 22 17:27:25 2022] iommu: Adding device sound to group 6
[Sa Jan 22 17:27:25 2022] platform sound: domain=ffffffc0f94c5258 allocates as[0]=ffffffc0f94301e0
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000d400.spi to group 7
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000d600.spi to group 8
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70410000.spi to group 9
[Sa Jan 22 17:27:25 2022] iommu: Adding device 50000000.host1x to group 10
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54080000.vi to group 11
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54600000.isp to group 12
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54680000.isp to group 13
[Sa Jan 22 17:27:25 2022] iommu: Adding device tegradc.0 to group 14
[Sa Jan 22 17:27:25 2022] platform tegradc.0: domain=ffffffc0f94d1198 allocates as[0]=ffffffc0f9430248
[Sa Jan 22 17:27:25 2022] platform tegradc.0: IOVA linear map 0x0000000092ca9000(140000)
[Sa Jan 22 17:27:25 2022] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[Sa Jan 22 17:27:25 2022] iommu: Adding device tegradc.1 to group 15
[Sa Jan 22 17:27:25 2022] platform tegradc.1: domain=ffffffc0f94d13d8 allocates as[0]=ffffffc0f94302b0
[Sa Jan 22 17:27:25 2022] platform tegradc.1: IOVA linear map 0x0000000092ca9000(140000)
[Sa Jan 22 17:27:25 2022] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54340000.vic to group 16
[Sa Jan 22 17:27:25 2022] iommu: Adding device 544c0000.nvenc to group 17
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54500000.tsec to group 18
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54100000.tsecb to group 19
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54480000.nvdec to group 20
[Sa Jan 22 17:27:25 2022] iommu: Adding device 54380000.nvjpg to group 21
[Sa Jan 22 17:27:25 2022] iommu: Adding device 546c0000.i2c to group 22
[Sa Jan 22 17:27:25 2022] iommu: Adding device 57000000.gpu to group 23
[Sa Jan 22 17:27:25 2022] platform 57000000.gpu: domain=ffffffc0f953b3d8 allocates as[0]=ffffffc0f9430318
[Sa Jan 22 17:27:25 2022] platform 57000000.gpu: domain=ffffffc0f953b3d8 allocates as[1]=ffffffc0f9430380
[Sa Jan 22 17:27:25 2022] platform 57000000.gpu: domain=ffffffc0f953b3d8 allocates as[2]=ffffffc0f94303e8
[Sa Jan 22 17:27:25 2022] platform 57000000.gpu: domain=ffffffc0f953b3d8 allocates as[3]=ffffffc0f9430450
[Sa Jan 22 17:27:25 2022] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[Sa Jan 22 17:27:25 2022] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[Sa Jan 22 17:27:25 2022] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[Sa Jan 22 17:27:25 2022] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[Sa Jan 22 17:27:25 2022] tegra-pmc: ### PMC reset status reg: 0x0
[Sa Jan 22 17:27:25 2022] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[Sa Jan 22 17:27:25 2022] tegra-pmc: Clear bootloader IO dpd settings
[Sa Jan 22 17:27:25 2022] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[Sa Jan 22 17:27:25 2022] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[Sa Jan 22 17:27:25 2022] iommu: Adding device 70012000.se to group 24
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000c000.i2c to group 25
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000c400.i2c to group 26
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000c500.i2c to group 27
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000c700.i2c to group 28
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000d000.i2c to group 29
[Sa Jan 22 17:27:25 2022] iommu: Adding device 7000d100.i2c to group 30
[Sa Jan 22 17:27:25 2022] iommu: Adding device sdhci-tegra.0 to group 31
[Sa Jan 22 17:27:25 2022] platform sdhci-tegra.0: domain=ffffffc0f954c558 allocates as[0]=ffffffc0f94304b8
[Sa Jan 22 17:27:25 2022] iommu: Adding device 700d0000.xudc to group 32
[Sa Jan 22 17:27:25 2022] vdd-ac-bat: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-5v0-sys: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-5v0-hdmi: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[Sa Jan 22 17:27:25 2022] vdd-1v8-sys: 1800 mV
[Sa Jan 22 17:27:25 2022] vdd-fan: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-fan: supplied by vdd-5v0-sys
[Sa Jan 22 17:27:25 2022] vdd-usb-vbus: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-usb-vbus: supplied by vdd-5v0-sys
[Sa Jan 22 17:27:25 2022] vdd-usb-vbus2: 5000 mV
[Sa Jan 22 17:27:25 2022] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[Sa Jan 22 17:27:25 2022] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[Sa Jan 22 17:27:25 2022] GPIO line 6 (system-suspend-gpio) hogged as output/high
[Sa Jan 22 17:27:25 2022] GPIO line 151 (camera-control-output-low) hogged as output/low
[Sa Jan 22 17:27:25 2022] GPIO line 152 (camera-control-output-low) hogged as output/low
[Sa Jan 22 17:27:25 2022] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[Sa Jan 22 17:27:25 2022] eventlib_kernel: keventlib is initialized, test id: 0
[Sa Jan 22 17:27:25 2022] SCSI subsystem initialized
[Sa Jan 22 17:27:25 2022] libata version 3.00 loaded.
[Sa Jan 22 17:27:25 2022] usbcore: registered new interface driver usbfs
[Sa Jan 22 17:27:25 2022] usbcore: registered new interface driver hub
[Sa Jan 22 17:27:25 2022] usbcore: registered new device driver usb
[Sa Jan 22 17:27:25 2022] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[Sa Jan 22 17:27:25 2022] vdd-core: 600 <--> 1162 mV at 1075 mV
[Sa Jan 22 17:27:25 2022] random: fast init done
[Sa Jan 22 17:27:25 2022] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[Sa Jan 22 17:27:25 2022] vdd-ddr-1v1: 1150 mV
[Sa Jan 22 17:27:25 2022] vdd-pre-reg-1v35: 1350 mV
[Sa Jan 22 17:27:25 2022] vdd-1v8: 1800 mV
[Sa Jan 22 17:27:25 2022] avdd-sys-1v2: 1200 mV
[Sa Jan 22 17:27:25 2022] vdd-pex-1v0: 1050 mV
[Sa Jan 22 17:27:25 2022] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[Sa Jan 22 17:27:25 2022] max77620-ldo3: at 3100 mV
[Sa Jan 22 17:27:25 2022] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[Sa Jan 22 17:27:25 2022] max77620-ldo5: at 3100 mV
[Sa Jan 22 17:27:25 2022] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[Sa Jan 22 17:27:25 2022] avdd-1v05-pll: 1050 mV
[Sa Jan 22 17:27:25 2022] avdd-io-hdmi-dp: 1050 mV
[Sa Jan 22 17:27:25 2022] GPIO line 505 (spmic-default-output-high) hogged as output/high
[Sa Jan 22 17:27:25 2022] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[Sa Jan 22 17:27:25 2022] max77620 4-003c: max77620 probe successful
[Sa Jan 22 17:27:25 2022] media: Linux media interface: v0.10
[Sa Jan 22 17:27:25 2022] Linux video capture interface: v2.00
[Sa Jan 22 17:27:25 2022] pps_core: LinuxPPS API ver. 1 registered
[Sa Jan 22 17:27:25 2022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Sa Jan 22 17:27:25 2022] PTP clock support registered
[Sa Jan 22 17:27:25 2022] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[Sa Jan 22 17:27:25 2022] Advanced Linux Sound Architecture Driver Initialized.
[Sa Jan 22 17:27:25 2022] Bluetooth: Core ver 2.22
[Sa Jan 22 17:27:25 2022] NET: Registered protocol family 31
[Sa Jan 22 17:27:25 2022] Bluetooth: HCI device and connection manager initialized
[Sa Jan 22 17:27:25 2022] Bluetooth: HCI socket layer initialized
[Sa Jan 22 17:27:25 2022] Bluetooth: L2CAP socket layer initialized
[Sa Jan 22 17:27:25 2022] Bluetooth: SCO socket layer initialized
[Sa Jan 22 17:27:25 2022] tegra210_dvfs: no clock found for sdmmc2_ddr
[Sa Jan 22 17:27:25 2022] tegra210_dvfs: no clock found for sdmmc4_ddr
[Sa Jan 22 17:27:25 2022] tegra210_dvfs: no clock found for sdmmc1_ddr
[Sa Jan 22 17:27:25 2022] tegra210_dvfs: no clock found for sdmmc3_ddr
[Sa Jan 22 17:27:25 2022] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[Sa Jan 22 17:27:25 2022] vdd-3v3-sys: 3300 mV
[Sa Jan 22 17:27:25 2022] vdd-3v3-sys: supplied by vdd-5v0-sys
[Sa Jan 22 17:27:25 2022] vdd-1v8-sys: supplied by vdd-3v3-sys
[Sa Jan 22 17:27:25 2022] vdd-usb-vbus2: supplied by vdd-3v3-sys
[Sa Jan 22 17:27:25 2022] vdd-3v3-sd: 3300 mV
[Sa Jan 22 17:27:25 2022] vdd-3v3-sd: supplied by vdd-3v3-sys
[Sa Jan 22 17:27:25 2022] avdd-io-edp-1v05: 1050 mV
[Sa Jan 22 17:27:25 2022] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[Sa Jan 22 17:27:25 2022] vdd-usb-hub-en: 5000 mV
[Sa Jan 22 17:27:25 2022] vdd-usb-hub-en: supplied by vdd-1v8-sys
[Sa Jan 22 17:27:25 2022] camchar: rtcpu character device driver loaded
[Sa Jan 22 17:27:25 2022] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[Sa Jan 22 17:27:25 2022] clocksource: Switched to clocksource arch_sys_counter
[Sa Jan 22 17:27:25 2022] VFS: Disk quotas dquot_6.6.0
[Sa Jan 22 17:27:25 2022] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[Sa Jan 22 17:27:25 2022] nvmap_heap_init: nvmap_heap_init: created heap block cache
[Sa Jan 22 17:27:25 2022] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[Sa Jan 22 17:27:25 2022] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[Sa Jan 22 17:27:25 2022] cma: enabled page replacement for spfn=d7000, epfn=f0000
[Sa Jan 22 17:27:25 2022] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[Sa Jan 22 17:27:25 2022] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[Sa Jan 22 17:27:25 2022] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[Sa Jan 22 17:27:25 2022] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[Sa Jan 22 17:27:25 2022] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[Sa Jan 22 17:27:25 2022] nvmap_page_pool_init: Total RAM pages: 1010582
[Sa Jan 22 17:27:25 2022] nvmap_page_pool_init: nvmap page pool size: 126322 pages (493 MB)
[Sa Jan 22 17:27:25 2022] nvmap_background_zero_thread: PP zeroing thread starting.
[Sa Jan 22 17:27:25 2022] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[Sa Jan 22 17:27:25 2022] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[Sa Jan 22 17:27:25 2022] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[Sa Jan 22 17:27:25 2022] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[Sa Jan 22 17:27:25 2022] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[Sa Jan 22 17:27:25 2022] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[Sa Jan 22 17:27:25 2022] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[Sa Jan 22 17:27:25 2022] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[Sa Jan 22 17:27:25 2022] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[Sa Jan 22 17:27:25 2022] NET: Registered protocol family 2
[Sa Jan 22 17:27:25 2022] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[Sa Jan 22 17:27:25 2022] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[Sa Jan 22 17:27:25 2022] TCP: Hash tables configured (established 32768 bind 32768)
[Sa Jan 22 17:27:25 2022] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[Sa Jan 22 17:27:25 2022] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[Sa Jan 22 17:27:25 2022] RPC: Registered named UNIX socket transport module.
[Sa Jan 22 17:27:25 2022] RPC: Registered udp transport module.
[Sa Jan 22 17:27:25 2022] RPC: Registered tcp transport module.
[Sa Jan 22 17:27:25 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Sa Jan 22 17:27:25 2022] PCI: CLS 0 bytes, default 64
[Sa Jan 22 17:27:25 2022] Trying to unpack rootfs image as initramfs...
[Sa Jan 22 17:27:25 2022] Freeing initrd memory: 6992K
[Sa Jan 22 17:27:25 2022] host1x 50000000.host1x: initialized
[Sa Jan 22 17:27:25 2022] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[Sa Jan 22 17:27:26 2022] audit: initializing netlink subsys (disabled)
[Sa Jan 22 17:27:26 2022] audit: type=2000 audit(0.851:1): initialized
[Sa Jan 22 17:27:26 2022] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[Sa Jan 22 17:27:26 2022] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[Sa Jan 22 17:27:26 2022] ntfs: driver 2.1.32 [Flags: R/W].
[Sa Jan 22 17:27:26 2022] 9p: Installing v9fs 9p2000 file system support
[Sa Jan 22 17:27:26 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[Sa Jan 22 17:27:26 2022] io scheduler noop registered
[Sa Jan 22 17:27:26 2022] io scheduler cfq registered (default)
[Sa Jan 22 17:27:26 2022] gic 702f9000.agic: GIC IRQ controller registered
[Sa Jan 22 17:27:26 2022] iommu: Adding device 702ef000.adsp to group 33
[Sa Jan 22 17:27:26 2022] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[Sa Jan 22 17:27:26 2022] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x79c7c0e
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[Sa Jan 22 17:27:26 2022] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[Sa Jan 22 17:27:26 2022] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[Sa Jan 22 17:27:26 2022] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[Sa Jan 22 17:27:26 2022] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[Sa Jan 22 17:27:26 2022] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[Sa Jan 22 17:27:26 2022] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[Sa Jan 22 17:27:26 2022] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[Sa Jan 22 17:27:26 2022] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[Sa Jan 22 17:27:26 2022] Adding domain tsec-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] tsec 54500000.tsec: initialized
[Sa Jan 22 17:27:26 2022] tsec 54100000.tsecb: initialized
[Sa Jan 22 17:27:26 2022] Adding domain nvdec-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] nvdec 54480000.nvdec: initialized
[Sa Jan 22 17:27:26 2022] Adding domain vic03-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] Adding domain msenc-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] Adding domain nvjpg-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] falcon 54340000.vic: initialized
[Sa Jan 22 17:27:26 2022] falcon 544c0000.nvenc: initialized
[Sa Jan 22 17:27:26 2022] falcon 54380000.nvjpg: initialized
[Sa Jan 22 17:27:26 2022] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[Sa Jan 22 17:27:26 2022] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[Sa Jan 22 17:27:26 2022] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[Sa Jan 22 17:27:26 2022] display board info: id 0x0, fab 0x0
[Sa Jan 22 17:27:26 2022] generic_infoframe_type: 0x87
[Sa Jan 22 17:27:26 2022] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[Sa Jan 22 17:27:26 2022] tegra_cec 70015000.tegra_cec: probed
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: DT parsed successfully
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id=0
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: probed
[Sa Jan 22 17:27:26 2022] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[Sa Jan 22 17:27:26 2022] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[Sa Jan 22 17:27:26 2022] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[Sa Jan 22 17:27:26 2022] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[Sa Jan 22 17:27:26 2022] kfuse 7000fc00.kfuse: initialized
[Sa Jan 22 17:27:26 2022] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[Sa Jan 22 17:27:26 2022] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[Sa Jan 22 17:27:26 2022] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[Sa Jan 22 17:27:26 2022] vdd-cpu: 708 <--> 1322 mV at 708 mV
[Sa Jan 22 17:27:26 2022] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[Sa Jan 22 17:27:26 2022] vdd-gpu: applied init 1000000uV constraint
[Sa Jan 22 17:27:26 2022] vdd-gpu: 708 <--> 1323 mV at 997 mV
[Sa Jan 22 17:27:26 2022] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[Sa Jan 22 17:27:26 2022] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[Sa Jan 22 17:27:26 2022] No Device Node present for smmu client: serial8250 !!
[Sa Jan 22 17:27:26 2022] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[Sa Jan 22 17:27:26 2022] iommu: Adding device serial8250 to group 35
[Sa Jan 22 17:27:26 2022] Console: switching to colour frame buffer device 80x30
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: fb registered
[Sa Jan 22 17:27:26 2022] console [ttyS0] disabled
[Sa Jan 22 17:27:26 2022] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[Sa Jan 22 17:27:26 2022] console [ttyS0] enabled
[Sa Jan 22 17:27:26 2022] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[Sa Jan 22 17:27:26 2022] serial-tegra 70006200.serial: RX in PIO mode
[Sa Jan 22 17:27:26 2022] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[Sa Jan 22 17:27:26 2022] [drm] Initialized
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: BL set VIC 0
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[Sa Jan 22 17:27:26 2022] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[Sa Jan 22 17:27:26 2022] extcon-disp-state extcon:disp-state: cable 47 state 1
[Sa Jan 22 17:27:26 2022] Extcon AUX1(HDMI) enable
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: No lt-data, using default setting
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: No hpd-gpio in DT
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: DT parsed successfully
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: Display dc.ffffff800d540000 registered with id=1
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: dpd enable lookup fail:-19
[Sa Jan 22 17:27:26 2022] brd: module loaded
[Sa Jan 22 17:27:26 2022] edid invalid
[Sa Jan 22 17:27:26 2022] loop: module loaded
[Sa Jan 22 17:27:26 2022] tegra_profiler: version: 1.145, samples/io: 49/28
[Sa Jan 22 17:27:26 2022] tegra_profiler: auth: init
[Sa Jan 22 17:27:26 2022] THERMAL EST: found 2 subdevs
[Sa Jan 22 17:27:26 2022] THERMAL EST num_resources: 0
[Sa Jan 22 17:27:26 2022] [THERMAL EST subdev 0]
[Sa Jan 22 17:27:26 2022] [THERMAL EST subdev 1]
[Sa Jan 22 17:27:26 2022] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[Sa Jan 22 17:27:26 2022] THERMAL EST: thz register success.
[Sa Jan 22 17:27:26 2022] THERMAL EST: end of probe, return err: 0
[Sa Jan 22 17:27:26 2022] sd: No Scsi addr parsed to reserve index
[Sa Jan 22 17:27:26 2022] hisi_sas: driver version v1.6
[Sa Jan 22 17:27:26 2022] tegra-qspi 70410000.spi: Prod settings list not found
[Sa Jan 22 17:27:26 2022] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[Sa Jan 22 17:27:26 2022] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[Sa Jan 22 17:27:26 2022] libphy: Fixed MDIO Bus: probed
[Sa Jan 22 17:27:26 2022] tun: Universal TUN/TAP device driver, 1.6
[Sa Jan 22 17:27:26 2022] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[Sa Jan 22 17:27:26 2022] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[Sa Jan 22 17:27:26 2022] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[Sa Jan 22 17:27:26 2022] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: probed
[Sa Jan 22 17:27:26 2022] igb: Copyright (c) 2007-2014 Intel Corporation.
[Sa Jan 22 17:27:26 2022] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[Sa Jan 22 17:27:26 2022] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[Sa Jan 22 17:27:26 2022] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[Sa Jan 22 17:27:26 2022] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[Sa Jan 22 17:27:26 2022] PPP generic driver version 2.4.2
[Sa Jan 22 17:27:26 2022] PPP BSD Compression module registered
[Sa Jan 22 17:27:26 2022] PPP Deflate Compression module registered
[Sa Jan 22 17:27:26 2022] PPP MPPE Compression module registered
[Sa Jan 22 17:27:26 2022] NET: Registered protocol family 24
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: fb registered
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver r8152
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver asix
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver ax88179_178a
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver cdc_ether
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver net1080
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver cdc_subset
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver zaurus
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver cdc_ncm
[Sa Jan 22 17:27:26 2022] VFIO - User Level meta-driver version: 0.3
[Sa Jan 22 17:27:26 2022] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[Sa Jan 22 17:27:26 2022] ehci-pci: EHCI PCI platform driver
[Sa Jan 22 17:27:26 2022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[Sa Jan 22 17:27:26 2022] ohci-pci: OHCI PCI platform driver
[Sa Jan 22 17:27:26 2022] ohci-platform: OHCI generic platform driver
[Sa Jan 22 17:27:26 2022] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[Sa Jan 22 17:27:26 2022] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[Sa Jan 22 17:27:26 2022] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[Sa Jan 22 17:27:26 2022] tegradc tegradc.1: blank - powerdown
[Sa Jan 22 17:27:26 2022] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[Sa Jan 22 17:27:26 2022] Extcon DP: HPD disabled
[Sa Jan 22 17:27:26 2022] hpd: hpd_switch 0
[Sa Jan 22 17:27:26 2022] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[Sa Jan 22 17:27:26 2022] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[Sa Jan 22 17:27:26 2022] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9118400 id
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver uas
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver usb-storage
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver usbserial
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: xHCI Host Controller
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[Sa Jan 22 17:27:26 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[Sa Jan 22 17:27:26 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sa Jan 22 17:27:26 2022] usb usb1: Product: xHCI Host Controller
[Sa Jan 22 17:27:26 2022] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[Sa Jan 22 17:27:26 2022] usb usb1: SerialNumber: 70090000.xusb
[Sa Jan 22 17:27:26 2022] hub 1-0:1.0: USB hub found
[Sa Jan 22 17:27:26 2022] hub 1-0:1.0: 5 ports detected
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[Sa Jan 22 17:27:26 2022] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[Sa Jan 22 17:27:26 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[Sa Jan 22 17:27:26 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Sa Jan 22 17:27:26 2022] usb usb2: Product: xHCI Host Controller
[Sa Jan 22 17:27:26 2022] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[Sa Jan 22 17:27:26 2022] usb usb2: SerialNumber: 70090000.xusb
[Sa Jan 22 17:27:26 2022] hub 2-0:1.0: USB hub found
[Sa Jan 22 17:27:26 2022] hub 2-0:1.0: 4 ports detected
[Sa Jan 22 17:27:26 2022] tegra-xudc-new 700d0000.xudc: device count: 1
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[Sa Jan 22 17:27:26 2022] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[Sa Jan 22 17:27:26 2022] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[Sa Jan 22 17:27:26 2022] tegra-xudc-new 700d0000.xudc: vbus state: 1
[Sa Jan 22 17:27:26 2022] tegra-xudc-new 700d0000.xudc: device mode on: 0
[Sa Jan 22 17:27:26 2022] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[Sa Jan 22 17:27:26 2022] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[Sa Jan 22 17:27:26 2022] mousedev: PS/2 mouse device common for all mice
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver xpad
[Sa Jan 22 17:27:26 2022] usb usb1: usb_suspend_both: status 0
[Sa Jan 22 17:27:26 2022] usb usb2: usb_suspend_both: status 0
[Sa Jan 22 17:27:26 2022] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[Sa Jan 22 17:27:26 2022] rtc rtc1: alarm rtc device
[Sa Jan 22 17:27:26 2022] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[Sa Jan 22 17:27:26 2022] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[Sa Jan 22 17:27:26 2022] i2c /dev entries driver
[Sa Jan 22 17:27:26 2022] i2c i2c-6: Added multiplexed i2c bus 7
[Sa Jan 22 17:27:26 2022] i2c i2c-6: Added multiplexed i2c bus 8
[Sa Jan 22 17:27:26 2022] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[Sa Jan 22 17:27:26 2022] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[Sa Jan 22 17:27:26 2022] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[Sa Jan 22 17:27:26 2022] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[Sa Jan 22 17:27:26 2022] imx219 7-0010: board setup failed
[Sa Jan 22 17:27:26 2022] imx219: probe of 7-0010 failed with error -121
[Sa Jan 22 17:27:26 2022] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[Sa Jan 22 17:27:26 2022] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[Sa Jan 22 17:27:26 2022] imx219 8-0010: board setup failed
[Sa Jan 22 17:27:26 2022] imx219: probe of 8-0010 failed with error -121
[Sa Jan 22 17:27:26 2022] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[Sa Jan 22 17:27:26 2022] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[Sa Jan 22 17:27:26 2022] tegra_aotag tegra-aotag: Registering sensor 0
[Sa Jan 22 17:27:26 2022] tegra_aotag tegra-aotag: Invalid temp readout
[Sa Jan 22 17:27:26 2022] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[Sa Jan 22 17:27:26 2022] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[Sa Jan 22 17:27:26 2022] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[Sa Jan 22 17:27:26 2022] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: Num cap clks = 6
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=cclk_g type=2
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=gpu type=4
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[Sa Jan 22 17:27:26 2022] parse_throttle_dt_data: clk=emc type=3
[Sa Jan 22 17:27:26 2022] tegra_throttle_probe: probe successful. #cdevs=4
[Sa Jan 22 17:27:26 2022] FAN dev name: pwm-fan
[Sa Jan 22 17:27:26 2022] FAN:gpio request success.
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: fan tach request irq success
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: tach period: 1000
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[Sa Jan 22 17:27:26 2022] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[Sa Jan 22 17:27:26 2022] device-mapper: uevent: version 1.0.3
[Sa Jan 22 17:27:26 2022] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[Sa Jan 22 17:27:26 2022] tegra210-cpufreq cpufreq: probe()...completed
[Sa Jan 22 17:27:26 2022] sdhci: Secure Digital Host Controller Interface driver
[Sa Jan 22 17:27:26 2022] sdhci: Copyright(c) Pierre Ossman
[Sa Jan 22 17:27:26 2022] sdhci-pltfm: SDHCI platform and OF driver helper
[Sa Jan 22 17:27:26 2022] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[Sa Jan 22 17:27:26 2022] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[Sa Jan 22 17:27:26 2022] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[Sa Jan 22 17:27:26 2022] tegra-se 70012000.se: tegra_se_probe: complete
[Sa Jan 22 17:27:26 2022] hidraw: raw HID events driver (C) Jiri Kosina
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver usbhid
[Sa Jan 22 17:27:26 2022] usbhid: USB HID core driver
[Sa Jan 22 17:27:26 2022] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x40
[Sa Jan 22 17:27:26 2022] ina3221x 6-0040: ina3221 reset failure status: 0xffffff87
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: edid read failed
[Sa Jan 22 17:27:26 2022] ina3221x: probe of 6-0040 failed with error -121
[Sa Jan 22 17:27:26 2022] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[Sa Jan 22 17:27:26 2022] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[Sa Jan 22 17:27:26 2022] nvpmodel: initialized successfully
[Sa Jan 22 17:27:26 2022] usbcore: registered new interface driver snd-usb-audio
[Sa Jan 22 17:27:26 2022] No Device Node present for smmu client: snd-soc-dummy !!
[Sa Jan 22 17:27:26 2022] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[Sa Jan 22 17:27:26 2022] iommu: Adding device snd-soc-dummy to group 36
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: using fallback edid
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: blank - powerdown
[Sa Jan 22 17:27:26 2022] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[Sa Jan 22 17:27:26 2022] OPE platform probe
[Sa Jan 22 17:27:26 2022] OPE platform probe successful
[Sa Jan 22 17:27:26 2022] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[Sa Jan 22 17:27:26 2022] extcon-disp-state extcon:disp-state: cable 47 state 0
[Sa Jan 22 17:27:26 2022] Extcon AUX1(HDMI) disable
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[Sa Jan 22 17:27:26 2022] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: unblank
[Sa Jan 22 17:27:26 2022] u32 classifier
[Sa Jan 22 17:27:26 2022] Actions configured
[Sa Jan 22 17:27:26 2022] Initializing XFRM netlink socket
[Sa Jan 22 17:27:26 2022] NET: Registered protocol family 10
[Sa Jan 22 17:27:26 2022] NET: Registered protocol family 17
[Sa Jan 22 17:27:26 2022] NET: Registered protocol family 15
[Sa Jan 22 17:27:26 2022] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[Sa Jan 22 17:27:26 2022] Bluetooth: RFCOMM socket layer initialized
[Sa Jan 22 17:27:26 2022] Bluetooth: RFCOMM ver 1.11
[Sa Jan 22 17:27:26 2022] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[Sa Jan 22 17:27:26 2022] Bluetooth: HIDP socket layer initialized
[Sa Jan 22 17:27:26 2022] 9pnet: Installing 9P2000 support
[Sa Jan 22 17:27:26 2022] Key type dns_resolver registered
[Sa Jan 22 17:27:26 2022] Registered cp15_barrier emulation handler
[Sa Jan 22 17:27:26 2022] Registered setend emulation handler
[Sa Jan 22 17:27:26 2022] registered taskstats version 1
[Sa Jan 22 17:27:26 2022] Adding domain ve2-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] Adding domain ve-pd to PM domain host1x-pd
[Sa Jan 22 17:27:26 2022] isp 54600000.isp: initialized
[Sa Jan 22 17:27:26 2022] isp 54680000.isp: initialized
[Sa Jan 22 17:27:26 2022] last reset is due to power on reset
[Sa Jan 22 17:27:26 2022] KERNEL: PMC reset status reg: 0x0
[Sa Jan 22 17:27:26 2022] BL: PMC reset status reg: 0x0
[Sa Jan 22 17:27:26 2022] BL: PMIC poweroff Event Recorder: 0x40
[Sa Jan 22 17:27:26 2022] clk_cbus_recalc_rate: no gbus parent
[Sa Jan 22 17:27:26 2022] clk_cbus_round_rate: no gbus parent
[Sa Jan 22 17:27:26 2022] tegra_dvfs: GPU-cap: registered
[Sa Jan 22 17:27:26 2022] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[Sa Jan 22 17:27:26 2022] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[Sa Jan 22 17:27:26 2022] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[Sa Jan 22 17:27:26 2022] tegra_dvfs: vdd-gpu-vts: registered
[Sa Jan 22 17:27:26 2022] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[Sa Jan 22 17:27:26 2022] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[Sa Jan 22 17:27:26 2022] mmc0: new ultra high speed SDR25 SDXC card at address 59b4
[Sa Jan 22 17:27:26 2022] input: gpio-keys as /devices/gpio-keys/input/input1
[Sa Jan 22 17:27:26 2022] mmcblk0: mmc0:59b4 USD00 58.9 GiB
[Sa Jan 22 17:27:26 2022] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[Sa Jan 22 17:27:26 2022] tegra-pcie 1003000.pcie: link 0 down, retrying
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: sync windows ret = 248
[Sa Jan 22 17:27:26 2022] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:14 UTC (946688414)
[Sa Jan 22 17:27:26 2022] vi 54080000.vi: vi_probe: ++
[Sa Jan 22 17:27:26 2022] vi 54080000.vi: initialized
[Sa Jan 22 17:27:26 2022] vi 54080000.vi: subdev nvcsi--2 bound
[Sa Jan 22 17:27:26 2022] vi 54080000.vi: subdev nvcsi--1 bound
[Sa Jan 22 17:27:26 2022] mmcblk mmc0:59b4: Card claimed for testing.
[Sa Jan 22 17:27:26 2022] Disable partitions left on by BL
[Sa Jan 22 17:27:26 2022] disb
[Sa Jan 22 17:27:26 2022] bwmgr: missing cdev-type property
[Sa Jan 22 17:27:26 2022] DRAM derating cdev registered.
[Sa Jan 22 17:27:26 2022] ALSA device list:
[Sa Jan 22 17:27:26 2022] #0: tegra-hda at 0x70038000 irq 83
[Sa Jan 22 17:27:26 2022] #1: tegra-snd-t210ref-mobile-rt565x
[Sa Jan 22 17:27:26 2022] extcon-disp-state extcon:disp-state: cable 51 state 1
[Sa Jan 22 17:27:26 2022] Extcon HDMI: HPD enabled
[Sa Jan 22 17:27:26 2022] tegradc tegradc.0: hdmi: plugged
[Sa Jan 22 17:27:26 2022] Freeing unused kernel memory: 8640K
[Sa Jan 22 17:27:26 2022] Root device found: mmcblk0p1
[Sa Jan 22 17:27:26 2022] Found dev node: /dev/mmcblk0p1
[Sa Jan 22 17:27:27 2022] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[Sa Jan 22 17:27:27 2022] tegra-pcie 1003000.pcie: link 0 down, retrying
[Sa Jan 22 17:27:27 2022] tegra-pcie 1003000.pcie: link 0 down, ignoring
[Sa Jan 22 17:27:27 2022] EXT4-fs (mmcblk0p1): 22 orphan inodes deleted
[Sa Jan 22 17:27:27 2022] EXT4-fs (mmcblk0p1): recovery complete
[Sa Jan 22 17:27:27 2022] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[Sa Jan 22 17:27:27 2022] Rootfs mounted over mmcblk0p1
[Sa Jan 22 17:27:27 2022] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[Sa Jan 22 17:27:27 2022] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[Sa Jan 22 17:27:27 2022] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[Sa Jan 22 17:27:27 2022] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[Sa Jan 22 17:27:27 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: supports D1 D2
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Sa Jan 22 17:27:27 2022] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: PCI bridge to [bus 01]
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[Sa Jan 22 17:27:27 2022] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[Sa Jan 22 17:27:27 2022] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[Sa Jan 22 17:27:27 2022] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[Sa Jan 22 17:27:27 2022] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[Sa Jan 22 17:27:27 2022] aer 0000:00:02.0:pcie002: service driver aer loaded
[Sa Jan 22 17:27:27 2022] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[Sa Jan 22 17:27:27 2022] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[Sa Jan 22 17:27:27 2022] Switching from initrd to actual rootfs
[Sa Jan 22 17:27:27 2022] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[Sa Jan 22 17:27:27 2022] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:ec:a7:3d from device tree
[Sa Jan 22 17:27:27 2022] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[Sa Jan 22 17:27:27 2022] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[Sa Jan 22 17:27:27 2022] systemd[1]: System time before build time, advancing clock.
[Sa Jan 22 17:27:27 2022] ip_tables: (C) 2000-2006 Netfilter Core Team
[Sa Jan 22 17:27:27 2022] cgroup: cgroup2: unknown option "nsdelegate"
[Sa Jan 22 17:27:27 2022] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[Sa Jan 22 17:27:27 2022] systemd[1]: Detected architecture arm64.
[Sa Jan 22 17:27:28 2022] systemd[1]: Set hostname to <thomas-jetson>.
[Sa Jan 22 17:27:28 2022] tegra-xusb 70090000.xusb: entering ELPG
[Sa Jan 22 17:27:28 2022] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[Sa Jan 22 17:27:28 2022] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[Sa Jan 22 17:27:28 2022] tegra-xusb 70090000.xusb: entering ELPG done
[Sa Jan 22 17:27:28 2022] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[Sa Jan 22 17:27:28 2022] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[Sa Jan 22 17:27:28 2022] random: systemd: uninitialized urandom read (16 bytes read)
[Sa Jan 22 17:27:28 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[Sa Jan 22 17:27:28 2022] systemd[1]: Created slice System Slice.
[Sa Jan 22 17:27:28 2022] systemd[1]: Listening on udev Control Socket.
[Sa Jan 22 17:27:28 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[Sa Jan 22 17:27:28 2022] systemd[1]: Created slice system-serial\x2dgetty.slice.
[Sa Jan 22 17:27:28 2022] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[Sa Jan 22 17:27:28 2022] systemd-journald[1946]: Received request to flush runtime journal from PID 1
[Sa Jan 22 17:27:28 2022] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[Sa Jan 22 17:27:29 2022] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[Sa Jan 22 17:27:29 2022] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
[Sa Jan 22 17:27:29 2022] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[Sa Jan 22 17:27:29 2022] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[Sa Jan 22 17:27:29 2022] cpu-throttle-alert cooling device registered.
[Sa Jan 22 17:27:29 2022] gpu-throttle-alert cooling device registered.
[Sa Jan 22 17:27:29 2022] hot-surface-alert cooling device registered.
[Sa Jan 22 17:27:29 2022] random: crng init done
[Sa Jan 22 17:27:29 2022] random: 7 urandom warning(s) missed due to ratelimiting
[Sa Jan 22 17:27:32 2022] using random self ethernet address
[Sa Jan 22 17:27:32 2022] using random host ethernet address
[Sa Jan 22 17:27:33 2022] Mass Storage Function, version: 2009/09/11
[Sa Jan 22 17:27:33 2022] LUN: removable file: (no medium)
[Sa Jan 22 17:27:33 2022] using random self ethernet address
[Sa Jan 22 17:27:33 2022] using random host ethernet address
[Sa Jan 22 17:27:34 2022] rndis0: HOST MAC aa:f6:be:41:f8:80
[Sa Jan 22 17:27:34 2022] rndis0: MAC aa:f6:be:41:f8:81
[Sa Jan 22 17:27:34 2022] usb0: HOST MAC aa:f6:be:41:f8:82
[Sa Jan 22 17:27:34 2022] usb0: MAC aa:f6:be:41:f8:83
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[Sa Jan 22 17:27:34 2022] l4tbr0: port 1(rndis0) entered blocking state
[Sa Jan 22 17:27:34 2022] l4tbr0: port 1(rndis0) entered disabled state
[Sa Jan 22 17:27:34 2022] device rndis0 entered promiscuous mode
[Sa Jan 22 17:27:34 2022] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[Sa Jan 22 17:27:34 2022] l4tbr0: port 2(usb0) entered blocking state
[Sa Jan 22 17:27:34 2022] l4tbr0: port 2(usb0) entered disabled state
[Sa Jan 22 17:27:34 2022] device usb0 entered promiscuous mode
[Sa Jan 22 17:27:34 2022] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[Sa Jan 22 17:27:34 2022] android_work: did not send uevent (0 0 (null))
[Sa Jan 22 17:27:34 2022] android_work: sent uevent USB_STATE=CONNECTED
[Sa Jan 22 17:27:34 2022] configfs-gadget gadget: high-speed config #1: c
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[Sa Jan 22 17:27:34 2022] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[Sa Jan 22 17:27:34 2022] android_work: sent uevent USB_STATE=CONFIGURED
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[Sa Jan 22 17:27:34 2022] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[Sa Jan 22 17:27:34 2022] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[Sa Jan 22 17:27:36 2022] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Sa Jan 22 17:27:36 2022] eth0: 0xffffff800abb7000, 00:04:4b:ec:a7:3d, IRQ 407
[Sa Jan 22 17:27:39 2022] l4tbr0: port 2(usb0) entered blocking state
[Sa Jan 22 17:27:39 2022] l4tbr0: port 2(usb0) entered forwarding state
[Sa Jan 22 17:27:39 2022] l4tbr0: port 1(rndis0) entered blocking state
[Sa Jan 22 17:27:39 2022] l4tbr0: port 1(rndis0) entered forwarding state
[Sa Jan 22 17:27:39 2022] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[Sa Jan 22 17:27:39 2022] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[Sa Jan 22 17:27:40 2022] zram: Added device: zram0
[Sa Jan 22 17:27:40 2022] zram: Added device: zram1
[Sa Jan 22 17:27:40 2022] zram: Added device: zram2
[Sa Jan 22 17:27:40 2022] zram: Added device: zram3
[Sa Jan 22 17:27:41 2022] zram0: detected capacity change from 0 to 519421952
[Sa Jan 22 17:27:41 2022] Adding 507244k swap on /dev/zram0. Priority:5 extents:1 across:507244k SS
[Sa Jan 22 17:27:41 2022] zram1: detected capacity change from 0 to 519421952
[Sa Jan 22 17:27:41 2022] Adding 507244k swap on /dev/zram1. Priority:5 extents:1 across:507244k SS
[Sa Jan 22 17:27:41 2022] zram2: detected capacity change from 0 to 519421952
[Sa Jan 22 17:27:41 2022] Adding 507244k swap on /dev/zram2. Priority:5 extents:1 across:507244k SS
[Sa Jan 22 17:27:41 2022] zram3: detected capacity change from 0 to 519421952
[Sa Jan 22 17:27:41 2022] Adding 507244k swap on /dev/zram3. Priority:5 extents:1 across:507244k SS
[Sa Jan 22 17:27:45 2022] Bridge firewalling registered
[Sa Jan 22 17:27:45 2022] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[Sa Jan 22 17:27:45 2022] Netfilter messages via NETLINK v0.30.
[Sa Jan 22 17:27:45 2022] ctnetlink v0.93: registering with nfnetlink.
[Sa Jan 22 17:27:46 2022] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[Sa Jan 22 17:27:47 2022] tegradc tegradc.0: unblank
[Sa Jan 22 17:27:47 2022] tegradc tegradc.1: blank - powerdown
[Sa Jan 22 17:27:49 2022] fuse init (API version 7.26)
[Sa Jan 22 17:27:52 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Sa Jan 22 17:27:52 2022] Bluetooth: BNEP socket layer initialized
[Sa Jan 22 17:27:55 2022] tegradc tegradc.0: unblank
[Sa Jan 22 17:27:55 2022] tegradc tegradc.1: blank - powerdown
[Sa Jan 22 17:27:56 2022] vdd-fan: disabling
[Sa Jan 22 17:27:56 2022] vdd-usb-vbus: disabling
[Sa Jan 22 17:27:56 2022] vdd-usb-vbus2: disabling
[Sa Jan 22 17:27:56 2022] vddio-sdmmc3-ap: disabling
[Sa Jan 22 17:27:56 2022] avdd-io-edp-1v05: disabling
[Sa Jan 22 17:27:56 2022] vdd-usb-hub-en: disabling
