it works fine, but if I restart the device I found that i’m not able to connect in remote desktop or start connection with SSH by wifi if I don’t start the jetson with USB cable and Ethernet cable already connected.
I don’t see any connection between wifi and usb cable/ethernet cable. Are you able to use serial console to dump log and see what happens?
Some news about that? I definitively found that without starting a previous USB connection, I’m not able to use remote desktop. I don’t know how to check the issue, because if I connect with the USB to verify where is the problem, it works. Did someone has similar problem?
Sorry for late reply. I think we should narrow down this issue first.
Your problem: I found that i’m not able to connect in remote desktop or start connection with SSH by wifi if I don’t start the jetson with USB cable and Ethernet cable already connected.
Issue 1. Are you able to see wifi if you don’t have usb/ethernet cable?
Issue 2. What is the exactly one that would affect? the ethernet cable or usb cable or both of them?
Issue 3. Does wifi a must-have to reproduce this issue? What would happen if you use ethernet to connect?
I’m thinking that the issue was related to my wifi router. I changed the router and connected using ip instead host name and now it looks to work fine.
