Please provide the following info:
Hardware Platform: [DRIVE AGX Xavier™ Developer Kit]
Software Version: [DRIVE Software 10]
Host Machine Version: [native Ubuntu 18.04]
SDK Manager Version: [Example: 1.2.0.6733]
Dear Nvidia,
I just encountered such issue with logs attached below:
Summary: Flash Xavier A+B in parallel, could not start with generic installer
Log:
- NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP.log (2.7 KB)
- pdkinstaller.log (46.8 KB)
The log actually shows:
*"Could not fetch board revision. This option requires target board to be detected. *
Failed to bind partitions!"
However, by checking “lsusb” in terminal, the target board is apparently detected!
"dongyao@dongyao-HP-ZBook-15-G4:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
*Bus 001 Device 003: ID 05c8:0397 Cheng Uei Precision Industry Co., Ltd (Foxlink) *
Bus 001 Device 072: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 071: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 070: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 001 Device 069: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
*Bus 001 Device 068: ID 0424:2807 Standard Microsystems Corp. *
*Bus 001 Device 004: ID 8087:0a2b Intel Corp. *
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub"
So how to solve this issue?
Sincerely thanks
