We are trying to install cuda versions 11.1 and above on A30 gpu, while doing that facing issue metioned below:
creation time: Fri Nov 26 11:34:07 2021
installer version: 460.27.04
PATH: /sbin:/bin:/usr/sbin:/usr/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–no-cc-version-check
–install-libglvnd
Using built-in stream user interface
→ Detected 40 CPUs online; setting concurrency level to 32.
→ Tagging shared libraries with chcon -t textrel_shlib_t.
ERROR: An NVIDIA kernel module ‘nvidia-drm’ appears to already be loaded in your kernel. This may be because it is in use (for example, by an X server, a CUDA program, or the NVIDIA Persistence Daemon), but this may also happen if your kernel was configured without support for module unloading. Please be sure to exit any programs that may be using the GPU(s) before attempting to upgrade your driver. If no GPU-based programs are running, you know that your kernel supports module unloading, and you still receive this message, then an error may have occurred that has corrupted an NVIDIA kernel module’s usage count, for which the simplest remedy is to reboot your computer.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the
…System details:…
NAME=“Red Hat Enterprise Linux”
VERSION=“8.4 (Ootpa)”
ID=“rhel”
ID_LIKE=“fedora”
VERSION_ID=“8.4”
PLATFORM_ID=“platform:el8”
PRETTY_NAME=“Red Hat Enterprise Linux 8.4 (Ootpa)”
ANSI_COLOR=“0;31”
CPE_NAME=“cpe:/o:redhat:enterprise_linux:8.4:GA”
REDHAT_BUGZILLA_PRODUCT=“Red Hat Enterprise Linux 8”
REDHAT_BUGZILLA_PRODUCT_VERSION=8.4
REDHAT_SUPPORT_PRODUCT=“Red Hat Enterprise Linux”
REDHAT_SUPPORT_PRODUCT_VERSION=“8.4”
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 40
On-line CPU(s) list: 0-39
Thread(s) per core: 2
Core(s) per socket: 10
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 85
Model name: Intel(R) Xeon(R) Silver 4210R CPU @ 2.40GHz
Stepping: 7
CPU MHz: 2848.110
CPU max MHz: 3200.0000
CPU min MHz: 1000.0000
BogoMIPS: 4800.00
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 1024K
L3 cache: 14080K
[3:03 pm, 30/11/2021] Shekhar Blp: ±----------------------------------------------------------------------------+
| NVIDIA-SMI 495.29.05 Driver Version: 495.29.05 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA A30 Off | 00000000:3B:00.0 Off | 0 |
| N/A 31C P0 26W / 165W | 4MiB / 24258MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 196523 G /usr/libexec/Xorg 4MiB |
