Issue for opencv
Hi all,
I tried to install OpenCV into Jetson TX1 but failed. I found that the Jetson TX1 already has the OpenCV4Tegra. If I want to install OpenCV for the Jetson TX1, should I need to remove the OpenCV4Tegra?
Thanks in advance.
Hi pcsee4,
You can refer to below topic, even it’s on TX2, but should be the same:
[url]https://devtalk.nvidia.com/default/topic/1028386/jetson-tx2/how-can-i-have-two-opencv-on-tx2/post/5231373/#5231373[/url]
