Issue for running yolov8 on Jetson orin
Hi
I have issue of running yolov8 that cuda is not working. See the attached capture from jtop/ info
CUDA:Missing
Opencv 4.5.1 with CUDA :NO
It looks like your system is setup with an old release.
Could you reflash your device with our latest software?
JetPack 6 DP or JetPack 5.1.3 should be fine.
More, our default OpenCV doesn’t enable the CUDA support.
But you can build it from the source with the below script:
