Hi, I’m currently working on a project involving an AR0521-based stereo camera setup, streaming data from a Jetson AGX ORIN custom carrier board to a Windows PC via network streaming. Here are the specifics of my setup:
- Camera: AR0521
- Platform: Jetson AGX ORIN
- MIPI Output: 1920x1080 resolution, two-lane, 10-bit raw output with NVIDIA ISP
- Software: Jetpack 5.1 (L4T35.2.1)
I’m using a gstreamer-based application to merge the streams from the left and right cameras and transmit them to the Windows PC. The application works flawlessly in a loop for local streaming within the ORIN itself. However, when attempting network streaming, I encounter an abnormal termination issue after the third iteration of starting and stopping the API in a loop.
The error message I receive from the application is as follows:
NvMMLiteVideoEncDoWork:NvEncNvVicconvertsurfaceFormat Failed
NvVideoEncTransferOutputBufferToBlock: Do Work failed line# 680
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=691
We had also tried removing the gstreamer cache as mentioned in another nvidia topic using below command. But it doesn’t help in my case.
rm .cache/gstreamer-1.0/registry.aarch64.bin
Reproduction Rate: 8/10
Note: The iteration may differ sometimes from 2-11 after which the above same error stopping the process.
Currently, the only workaround I’ve found is to terminate the application and restart the nvargus-daemon.service
once the error occurs.
Expected Result: I expect the gstreamer network transfer application to open and close in a loop continuously without any issue
Gstreamer Pipeline:
Sender: nveglstreamsrc name=glst_source ! video/x-raw(memory:NVMM),format=RGBA,width=3840,height=1080,framerate=60/1 ! nvvidconv flip-method=6 ! video/x-raw,format=I420 ! nvvidconv ! nvv4l2h264enc ! rtph264pay pt=96 mtu=1400 ! udpsink port=5000 host=192.168.52.3 sync=false async=false name=vrtpsink
Receiver:gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! avdec_h264 ! queue ! videoconvert ! fpsdisplaysink sync=false
