I am facing the same issue in your deepstream-test-2 sample application
In test 2 applicaiton I modified following things
pgie model has 4 classes car, bicycle, person, road_sign, I added filter-out-class-ids=0 in pgie-config file
sgie model1 is set to operate on pgie model with operate-on-class-ids=0, similarly for sgie2 model.
Now ideally the sgie models shouldn’t run since there is no class-id 0 passed from the pgie to sgies.
But when I set the process-mode to 1 for both sgies. I can see results from classification models.
Here is modified pad_probe function
def osd_sink_pad_buffer_probe(pad,info,u_data):
frame_number=0
#Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
# obj_counter[obj_meta.class_id] += 1
print(f"Detection {obj_meta.obj_label}")
l_classifier = obj_meta.classifier_meta_list
while l_classifier is not None:
try:
classifier_meta = pyds.NvDsClassifierMeta.cast(l_classifier.data)
break
l_label = classifier_meta.label_info_list
while l_label is not None:
try:
label_info = pyds.NvDsLabelInfo.cast(l_label.data)
break
print(f"Classification Result Object : {label_info.result_label} ID : {label_info.result_class_id}")
try:
l_label = l_label.next
break
try:
l_classifier = l_classifier.next
break
try:
l_obj=l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
#past tracking meta data
# l_user=batch_meta.batch_user_meta_list
# while l_user is not None:
# try:
# # Note that l_user.data needs a cast to pyds.NvDsUserMeta
# # The casting is done by pyds.NvDsUserMeta.cast()
# # The casting also keeps ownership of the underlying memory
# # in the C code, so the Python garbage collector will leave
# # it alone
# user_meta=pyds.NvDsUserMeta.cast(l_user.data)
# except StopIteration:
# break
# if(user_meta and user_meta.base_meta.meta_type==pyds.NvDsMetaType.NVDS_TRACKER_PAST_FRAME_META):
# try:
# # Note that user_meta.user_meta_data needs a cast to pyds.NvDsTargetMiscDataBatch
# # The casting is done by pyds.NvDsTargetMiscDataBatch.cast()
# # it alone
# pPastDataBatch = pyds.NvDsTargetMiscDataBatch.cast(user_meta.user_meta_data)
# break
# for miscDataStream in pyds.NvDsTargetMiscDataBatch.list(pPastDataBatch):
# print("streamId=",miscDataStream.streamID)
# print("surfaceStreamID=",miscDataStream.surfaceStreamID)
# for miscDataObj in pyds.NvDsTargetMiscDataStream.list(miscDataStream):
# print("numobj=",miscDataObj.numObj)
# print("uniqueId=",miscDataObj.uniqueId)
# print("classId=",miscDataObj.classId)
# print("objLabel=",miscDataObj.objLabel)
# for miscDataFrame in pyds.NvDsTargetMiscDataObject.list(miscDataObj):
# print('frameNum:', miscDataFrame.frameNum)
# print('tBbox.left:', miscDataFrame.tBbox.left)
# print('tBbox.width:', miscDataFrame.tBbox.width)
# print('tBbox.top:', miscDataFrame.tBbox.top)
# print('tBbox.right:', miscDataFrame.tBbox.height)
# print('confidence:', miscDataFrame.confidence)
# print('age:', miscDataFrame.age)
# try:
# l_user=l_user.next
# break
return Gst.PadProbeReturn.OK
Here is the output, there is no detected car so there should be no classification result.
Frame Number=1437 Number of Objects=5 Vehicle_count=0 Person_count=0
Detection
Classification Result Object : largevehicle ID : 1
Detection
Classification Result Object : mercedes ID : 15
Detection person
Detection person
Detection person
Detection person
Frame Number=1438 Number of Objects=6 Vehicle_count=0 Person_count=0
nvstreammux: Successfully handled EOS for source_id=0
Detection
Detection
Detection person
Detection person
Detection person
Detection person
Frame Number=1439 Number of Objects=6 Vehicle_count=0 Person_count=0
Detection
Detection
Detection person
Detection person
Detection person
Frame Number=1440 Number of Objects=5 Vehicle_count=0 Person_count=0
Detection
Classification Result Object : suv ID : 3
Detection
Classification Result Object : bmw ID : 2
Frame Number=1441 Number of Objects=2 Vehicle_count=0 Person_count=0
Can you guide me about this?
Is there any impact of process-mode=1 on operate-on-class-ids in classification models
