• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
I am using Jetson Orin NX, and when I have 6 cameras with FHD at 30FPS. When I run the test3 sample application with 2 cams it works fine, but when I increase the number of cameras to 3 or above it starts to throw the stream format not found, dropping the frame Error.
I have tried to pass the same rtsp url 3 time, still I get the same error.
Can you guide me on this.
I have a substream with 480x704 and the pipeline works with 6 cameras on substreams.
