Thanks for your reply! I attached 2 config file’s contents below.
- cuphycontroller config file
l2adapter_filename: l2_adapter_config_F08_CG1.yaml
aerial_metrics_backend_address: 127.0.0.1:8081
# CPU core shared by all low-priority threads
low_priority_core: 23
nic_tput_alert_threshold_mbps: 85000
cuphydriver_config:
standalone: 0
validation: 0
num_slots: 8
log_level: DBG
profiler_sec: 0
dpdk_thread: 23
dpdk_verbose_logs: 0
accu_tx_sched_res_ns: 500
accu_tx_sched_disable: 0 #Flag applicable only for CX6-DX : BF3/CX7 HW and beyond support accurate send scheduling directly on timestamp, for CX6-DX this is implemented via software emulation
fh_stats_dump_cpu_core: -1
pdump_client_thread: -1
use_green_contexts: 0 # Experimental feature; disabled by default
mps_sm_pusch: 82
#mps_sm_pusch: 88
mps_sm_pucch: 20
mps_sm_prach: 2
mps_sm_ul_order: 20
#mps_sm_ul_order: 24
mps_sm_pdsch: 102
mps_sm_pdcch: 10
mps_sm_pbch: 2
mps_sm_gpu_comms: 16
mps_sm_srs: 16
pdsch_fallback: 0
dpdk_file_prefix: cuphycontroller
nics:
- nic: 0000:01:00.0
mtu: 1514
cpu_mbufs: 196608
uplane_tx_handles: 64
txq_count: 60
rxq_count: 20
txq_size: 8192
rxq_size: 16384
gpu: 0
cus_port_failover: 0
gpus:
- 0
# Set GPUID to the GPU sharing the PCIe switch as NIC
# run nvidia-smi topo -m to find out which GPU
workers_ul: [5,6]
workers_dl: [11,12,13]
debug_worker: -1
workers_sched_priority: 95
prometheus_thread: -1
start_section_id_srs: 3072
start_section_id_prach: 2048
enable_ul_cuphy_graphs: 1
enable_dl_cuphy_graphs: 1
ul_order_timeout_cpu_ns: 8000000
ul_order_timeout_log_interval_ns: 1000000000
ul_order_timeout_gpu_ns: 3000000
ul_order_timeout_gpu_log_enable: 0
cplane_disable: 0
gpu_init_comms_dl: 1
cell_group: 1
cell_group_num: 2
fix_beta_dl: 1
pusch_sinr: 2
pusch_rssi: 1
pusch_tdi: 1
pusch_cfo: 1
pusch_dftsofdm: 0
pusch_to: 1
pusch_select_eqcoeffalgo: 1
pusch_select_chestalgo: 1
pusch_tbsizecheck: 1
pusch_subSlotProcEn: 1
pusch_deviceGraphLaunchEn: 1
pusch_waitTimeOutPreEarlyHarqUs: 5000
pusch_waitTimeOutPostEarlyHarqUs: 5000
puxch_polarDcdrListSz: 8
enable_cpu_task_tracing: 0
enable_prepare_tracing: 0
disable_empw: 0 #1=>Disables Multi packet WQE feature
cqe_tracer_config:
enable_dl_cqe_tracing: 0
cqe_trace_cell_mask: 1 #[64 bit mask: Bit0->Cell0, Bit1->Cell1...]
cqe_trace_slot_mask: 196800 #[20 bit mask: Bit0->Slot0, Bit1->Slot1...] 196800=>All *6,*7 DL Slots
ul_rx_pkt_tracing_level: 0
enable_h2d_copy_thread: 1
h2d_copy_thread_cpu_affinity : 41
h2d_copy_thread_sched_priority : 95 #0->SCHED_OTHER, >0->Actual
split_ul_cuda_streams: 0 # 1=Put UL slot 4 and slot 5 on different streams for DDDSUUDDDD pattern
serialize_pucch_pusch: 0 # 1=Force serialization of PUSCH/PUCCH
# Note: for Early Harq (EH) order is PUSCH EH -> PUCCH -> PUSCH non EH
# for non-Early Harq order is PUCCH -> all PUSCH processing
aggr_obj_non_avail_th: 5 # Threshold for consecutive non-availability of Aggregated objects(UL/DL) or DL/UL buffers
dl_wait_th_ns:
- 500000 #H2D copy wait threshold
- 4000000 #cuPHY DL channel wait threshold
sendCPlane_timing_error_th_ns : 0
pusch_forcedNumCsi2Bits: 0
mMIMO_enable: 0
enable_srs: 0
ue_mode: 0
mCh_segment_proc_enable: 1
enable_csip2_v3: 0
pusch_aggr_per_ctx: 3
prach_aggr_per_ctx: 2
pucch_aggr_per_ctx: 4
srs_aggr_per_ctx: 2
ul_input_buffer_per_cell: 10
ul_input_buffer_per_cell_srs: 4
max_harq_pools: 384
cells:
- name: O-RU 0
cell_id: 1
ru_type: 3
# set to 00:00:00:00:00:00 to use the MAC address of the NIC port to use
src_mac_addr: 9c:63:c0:d8:ea:b6 #00:00:00:00:00:00
dst_mac_addr: 9c:63:c0:d8:eb:9a #20:04:9B:9E:27:A3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
eAxC_id_ssb_pbch: [8, 0, 1, 2]
eAxC_id_pdcch: [8, 0, 1, 2]
eAxC_id_pdsch: [8, 0, 1, 2]
eAxC_id_csirs: [8, 0, 1, 2]
eAxC_id_pusch: [8, 0, 1, 2]
eAxC_id_pucch: [8, 0, 1, 2]
eAxC_id_srs: [8, 0, 1, 2]
eAxC_id_prach: [15, 7, 0, 1]
dl_iq_data_fmt: {comp_meth: 1, bit_width: 9}
ul_iq_data_fmt: {comp_meth: 1, bit_width: 9}
section_3_time_offset: 484
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
T1a_max_up_ns: 345000
T1a_max_cp_ul_ns: 336000
Ta4_min_ns: 50000
Ta4_max_ns: 331000
Tcp_adv_dl_ns: 125000
ul_u_plane_tx_offset_ns: 280000
fh_len_range: 0
pusch_prb_stride: 273
prach_prb_stride: 12
srs_prb_stride: 273
pusch_ldpc_max_num_itr_algo_type: 1
pusch_fixed_max_num_ldpc_itrs: 10
pusch_ldpc_n_iterations: 7
pusch_ldpc_early_termination: 0
pusch_ldpc_algo_index: 0
pusch_ldpc_flags: 2
pusch_ldpc_use_half: 1
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
ul_gain_calibration: 48.68
lower_guard_bw: 845
tv_pusch: cuPhyChEstCoeffs.h5
- name: O-RU 1
cell_id: 2
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
eAxC_id_ssb_pbch: [1, 2, 4, 9]
eAxC_id_pdcch: [1, 2, 4, 9]
eAxC_id_pdsch: [1, 2, 4, 9]
eAxC_id_csirs: [1, 2, 4, 9]
eAxC_id_pusch: [1, 2, 4, 9]
eAxC_id_pucch: [1, 2, 4, 9]
eAxC_id_srs: [1, 2, 4, 9]
eAxC_id_prach: [5, 6, 7, 10]
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 2
cell_id: 3
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 3
cell_id: 4
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
eAxC_id_ssb_pbch: [0, 1, 2, 3]
eAxC_id_pdcch: [0, 1, 2, 3]
eAxC_id_pdsch: [0, 1, 2, 3]
eAxC_id_csirs: [0, 1, 2, 3]
eAxC_id_pusch: [0, 1, 2, 3]
eAxC_id_pucch: [0, 1, 2, 3]
eAxC_id_srs: [0, 1, 2, 3]
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 4
cell_id: 5
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 5
cell_id: 6
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 6
cell_id: 7
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 7
cell_id: 8
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 8
cell_id: 9
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 9
cell_id: 10
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 10
cell_id: 11
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 11
cell_id: 12
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 12
cell_id: 13
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 13
cell_id: 14
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 14
cell_id: 15
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 15
cell_id: 16
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 16
cell_id: 17
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 17
cell_id: 18
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 18
cell_id: 19
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- name: O-RU 19
cell_id: 20
ru_type: 3
nic: 0000:01:00.0
vlan: 2
pcp: 7
txq_count_uplane: 1
fs_offset_dl: 0
exponent_dl: 4
ref_dl: 0
fs_offset_ul: 0
exponent_ul: 4
max_amp_ul: 65504
mu: 1
Ta4_min_ns: 50000
Ta4_max_ns: 331000
fh_len_range: 0
srs_prb_stride: 273
pusch_ldpc_flags: 2
pusch_nMaxPrb: 273
pusch_nMaxRx: 4
lower_guard_bw: 845
- L2 adapter config file.
#gnb_module
msg_type: scf_5g_fapi
phy_class: scf_5g_fapi
slot_advance: 3
# tick_generator_mode: 0 - poll + sleep; 1 - sleep; 2 - timer_fd
tick_generator_mode: 1
# Allowed maximum latency of SLOT FAPI messages which send from L2 to L1. Unit: slot
allowed_fapi_latency: 1
# Allowed tick interval error. Unit: us
allowed_tick_error: 10
timer_thread_config:
cpu_affinity: 29
sched_priority: 99
message_thread_config:
#core assignment
cpu_affinity: 29
# thread priority
sched_priority: 95
# Lowest TTI for Ticking
mu_highest: 1
dl_tb_loc: 1
timer_thread_wakeup_threshold: 20000
l2a_allowed_latency: 100000
enableTickDynamicSfnSlot: 0
staticPucchSlotNum: 0
staticPuschSlotNum: 0
staticPdcchSlotNum: 0
staticPdschSlotNum: 0
staticCsiRsSlotNum: 0
staticSsbPcid: -1
staticSsbSFN: -1
# SHM IPC sync mode: 0 - sync per cell, 1 - sync per TTI
ipc_sync_mode: 0
cell_group: 1
enable_precoding: 1
enable_beam_forming: 1
prepone_h2d_copy: 1
pucch_dtx_thresholds: [-100.0, -100.0, 1.0, 1.0, -100.0]
pusch_dtx_thresholds: 1.0
# Duplicate the cell configs at the first message
duplicate_config_all_cells: 0
instances:
# PHY 0
# Config dedicated yaml file for nvipc. Example: nvipc_multi_instances.yaml
nvipc_config_file: null
# Transport settings for nvIPC
transport:
type: shm
shm_config:
primary: 1
prefix: nvipc
cuda_device_id: 0
ring_len: 8192
mempool_size:
cpu_msg:
buf_size: 8192
pool_len: 4096
cpu_data:
buf_size: 576000
pool_len: 1024
cpu_large:
buf_size: 4096000
pool_len: 64
cuda_data:
buf_size: 307200
pool_len: 0
gpu_data:
buf_size: 576000
pool_len: 0
app_config:
grpc_forward: 0
debug_timing: 0
pcap_enable: 0
pcap_cpu_core: 17 # CPU core of background pcap log save thread
pcap_cache_size_bits: 29 # 2^29 = 512MB, size of /dev/shm/${prefix}_pcap
pcap_file_size_bits: 31 # 2^31 = 2GB, max size of /var/log/aerial/${prefix}_pcap. Requires pcap_file_size_bits > pcap_cache_size_bits.
pcap_max_data_size: 8000 # Max DL/UL FAPI data size to capture reduce pcap size.
- Steps I followed to run the test
- 1.5.4.5.2.1 Running the F08 Test Cases
- Server setting
- Server #1: 1 GH200
- Server #2: 1 H100
Additionally, I ran single cell end-to-end test successfuly with cli below so I think connection between servers.
sudo -E /opt/nvidia/cuBB/build/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf F08_CG1
sudo /opt/nvidia/cuBB/build/cuPHY-CP/testMAC/testMAC/test_mac F08 1C 59
sudo /opt/nvidia/cuBB/build/cuPHY-CP/ru-emulator/ru_emulator/ru_emulator F08 1C 59
