Issue installing DeepStream
I setup Jetpack on my Jetson Xavier NX using the apt-get method (not the old SDK Manager method). I’m now trying to run deepstream but am having issues installing it.
  1. The docker container fails with an error: ‘exec user process caused exec format error’.
  2. The docs on the online instructions only say how to install via SDK-Manager or if you already have the installation binary (the docs do tell you how to install using debian but assume you have the binary). Where can I find the installation binary?
Any help would be appreciated.
Thanks,
Iqbal
That usually happens when you’re trying to run an image/executable of the wrong architecture. Try deepstream-l4t instead of deepstream. The tags are different as well so you will have to look them up.
Thx for the tip! I found the correct container image: https://ngc.nvidia.com/catalog/containers/nvidia:deepstream-l4t
Yw!
