Issue Installing pyrealsense2 on NVIDIA Jetson Nano for My Final Degree Project
Dear NVIDIA Support Team,
I hope this email finds you well.
I am a student currently working on my final degree project, and I am experiencing difficulties installing the pyrealsense2 module on my NVIDIA Jetson Nano. While I have successfully installed librealsense and can run the RealSense Viewer without any issues, I have not been able to get the pyrealsense2 Python module to install or function correctly.
I have tried several installation methods suggested online, including building from source and using pip, but none have been successful. I would greatly appreciate your guidance on the correct procedure to install pyrealsense2 on the Jetson Nano.
If you need any additional information about my setup or the error messages I am encountering, please let me know. This issue is quite urgent, as my final grade depends on completing this project successfully.
Thank you very much in advance for your help and support. I look forward to your response.
Best regards,
Alfred
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
Please check the topic and give it a try:
AttributedError: module 'pyrealsense2' has no attributed 'pipeline' fault on jetson nano with realsense
The latest Jetpack release for Jetson Nano developer kit is 4.6.5:
Jetson Linux R32.7.6 | NVIDIA Developer
If you use previous version, would suggest upgrade to latest version.
And may try this:
Jetson/L4T/TRT Customized Example - eLinux.org
